Claude Opus 5.5 is more capable than Opus 5, but its most important upgrade may be economic: Anthropic is making flagship-level intelligence cheaper enough to remain inside longer agent workflows.
The model costs $4 per million input tokens and $20 per million output tokens, while Anthropic estimates typical token-billed workloads cost about 40% less than Opus 5. It keeps a 1 million-token context window, makes adaptive thinking always on, and is explicitly positioned for long-running agentic coding and knowledge work.
The story is therefore bigger than another benchmark win. Frontier AI is moving from something developers reserve for the hardest prompt toward something agents can use repeatedly across an entire job.
What Is Claude Opus 5.5?
Claude Opus 5.5 was released on September 22, 2026 as the first model in Anthropic's Claude 5.5 family.
Anthropic says it performs at the level of Claude Fable 5.1 on most work while requiring less compute to serve than Opus 5. Its official documentation positions the model around long-running agentic coding and knowledge work.
| Claude Opus 5.5 | Specification |
| Release date | September 22, 2026 |
| API model ID | claude-opus-5-5 |
| Context window | 1 million tokens |
| Maximum output | 128K tokens |
| Input | Text and images |
| Thinking | Adaptive, always on |
| Default effort | Medium |
| Input price | $4 per million tokens |
| Output price | $20 per million tokens |
| Cache read | $0.20 per million tokens |
The headline API rates are 20% below Opus 5. Anthropic's larger estimate of roughly 40% lower typical workload cost also reflects fewer tokens, tool calls, and other efficiency gains.
The useful unit is not cost per token. It is cost per completed task.
Why Is Claude Opus 5.5 Cheaper for Agents?
Opus 5.5 reduces standard input and output pricing, but the larger change for agent workloads is cached context.
| Cost Component | Opus 5 | Opus 5.5 | Change |
| Input | $5 / MTok | $4 / MTok | 20% lower |
| Output | $25 / MTok | $20 / MTok | 20% lower |
| Cache read | $0.50 / MTok | $0.20 / MTok | 60% lower |
A coding agent may repeatedly revisit the same system instructions, tool definitions, repository context, documentation, and conversation state while completing one job.
That makes cache pricing especially important. Reusing a large stable context for $0.20 per million tokens changes the cost of keeping a capable model active through dozens of steps.
The same dynamic appeared with Anthropic's previous flagship release. Our Claude Fable 5.1 agent-cost analysis showed why cheaper cache reads can matter more to long-running agents than a simple reduction in normal prompt pricing.
For agents, the cost of remembering the job can matter almost as much as the cost of reasoning about it.
Claude Opus 5.5 vs Opus 5: What Actually Changed?
The upgrade is not a larger context window. Both models support 1 million tokens of context and up to 128K tokens of normal output.
| Feature | Claude Opus 5 | Claude Opus 5.5 |
| Context | 1M | 1M |
| Max output | 128K | 128K |
| Input / output price | $5 / $25 | $4 / $20 |
| Thinking | Adaptive | Adaptive, always on |
| Default effort | High | Medium |
| Output speed | Baseline | More than 30% faster in Anthropic's testing |
The practical upgrade is therefore efficiency: lower prices, cheaper repeated context, faster output, and stronger task performance without expanding the context specification itself.
Always-On Adaptive Thinking Changes the Runtime
Claude Opus 5.5 does not let developers disable adaptive thinking.
Instead, the model decides how much reasoning to apply within the configured effort level. The default effort is now medium rather than high.
Anthropic's Opus 5.5 documentation also notes migration changes around thinking state and forced tool use.
The design suggests a different optimization target:
- keep reasoning available throughout the workflow,
- spend more effort only when the task needs it,
- avoid maximum reasoning cost by default,
- and let developers tune effort rather than switch reasoning on and off.
Reasoning is becoming part of the model runtime rather than a special mode an application occasionally activates.
Why Does the 1M Context Window Matter for Agents?
A 1 million-token window is not new to Opus 5.5. What changes is the economics of repeatedly using it.
Anthropic's context-window documentation lists 1M tokens as the standard window for Opus 5.5.
For an agent, context can include far more than chat history:
- large codebases,
- API documentation,
- tool schemas,
- issue histories,
- test results,
- research documents,
- and subagent outputs.
More context is not automatically better. Irrelevant information can still increase latency, cost, and retrieval noise.
The value of a large context window is not filling one million tokens. It is keeping enough relevant working state available for a long job without continually reconstructing it.
Opus 5.5 Is Built Around Jobs, Not Just Responses
Anthropic explicitly positions Opus 5.5 for long-running agentic coding and knowledge work.
That means the interesting workloads are less like “explain this function” and more like:
- migrate a large application,
- investigate a production bug,
- refactor several connected repositories,
- delegate tasks to subagents,
- run tests and inspect failures,
- review the resulting changes,
- and continue until completion.
Anthropic's launch material includes early-user examples involving large migrations, autonomous debugging, multi-session coordination, and long code-review workflows.
Those examples are vendor-selected rather than independent benchmarks, but they clarify what Anthropic is optimizing for.
The unit of AI work is moving from the response toward the job.
Do the Opus 5.5 Benchmarks Matter?
Yes, but less in isolation than model-launch coverage often suggests.
| Benchmark | Opus 5.5 | Opus 5 |
| Terminal-Bench 4.0 | 66.4% | 52.3% |
| FrontierCode v1.1 | 54.4% | 48.0% |
| CursorBench 4.0 | 57.8% | 46.6% |
| AutomationBench | 40.0% | 26.9% |
The results indicate stronger agentic coding performance, but real agent success also depends on tool reliability, context selection, permissions, repository structure, tests, retry behavior, and completion verification.
A smarter model can still fail a real task if it receives the wrong context or cannot execute the required action.
For agents, model intelligence is one component of system reliability.
The More Useful Metric Is Cost per Successful Task
Anthropic reports that Opus 5.5 at default medium effort can outperform Opus 5 at maximum effort on FrontierCode for roughly one-fifth of the task cost in its tested configuration.
That matters because one autonomous job can require dozens of model calls, repeated cache reads, tool execution, revisions, and subagent handoffs.
A cheaper model is not necessarily cheaper if it requires more retries and human intervention. An expensive model is not necessarily expensive if it consistently finishes the job in fewer steps.
This is why our broader local AI cost analysis treats agent cost as the cost of the entire loop rather than the price of one answer.
Agent economics reward fewer failed attempts, fewer unnecessary tokens, and less supervision—not simply the lowest API rate.
Where Does Claude Fable 5.1 Still Fit?
Anthropic says Opus 5.5 reaches Fable 5.1-level performance on most work, but that does not make the models identical.
| Model | Input / Output | Default Effort | Position |
| Claude Fable 5.1 | $10 / $50 per MTok | High | Highest-end difficult work |
| Claude Opus 5.5 | $4 / $20 per MTok | Medium | High capability with stronger task economics |
| Claude Sonnet 5 | $2 / $10 per MTok | High | Lower-cost general work |
The model decision increasingly depends on task difficulty, latency, reasoning effort, token consumption, and how many times the model will be called.
Opus 5.5's role is therefore less “cheaper flagship” and more near-frontier capability that is easier to keep running continuously.
The Flagship Model Is Becoming an Everyday Workhorse
Flagship models were historically easy to justify for one difficult architecture decision or one high-value debugging problem. They were harder to justify as the engine behind an agent making hundreds of decisions.
Opus 5.5 narrows that gap.
It combines stronger agentic performance with:
- lower token pricing,
- 60% cheaper cache reads,
- faster generation,
- adaptive reasoning,
- and lower estimated cost per finished workload.
The premium model is moving from an escalation path toward a viable runtime for work that lasts hours instead of seconds.
Cheaper Frontier AI Does Not Eliminate Local Infrastructure
Opus 5.5 changes the economics of frontier inference, but it does not change where Claude runs. It remains hosted compute rather than an open-weight model users can download onto their own server.
This makes the local-versus-cloud question less useful as a binary choice.
| Workload | Natural Starting Point |
| Difficult reasoning | Frontier cloud model |
| Complex coding and review | Frontier cloud model |
| Private files and durable storage | Local infrastructure |
| Embeddings and retrieval | Often local |
| Routine automation | Local or lower-cost model |
| High-value difficult steps | Selective frontier escalation |
This is the same architectural direction visible in Perplexity Hybrid Compute: the useful boundary is increasingly defined by the task and data rather than by choosing one machine or one model for everything.
A local system can keep private files, retrieval indexes, agent memory, credentials, tools, outputs, and backups under the user's control while selectively calling Opus 5.5 for reasoning that benefits from frontier capability.
For example, an AnythingLLM RAG deployment can keep documents, embeddings, vectors, and application state on a local server while using a remote model API for inference. The model and the data layer do not have to live on the same machine.
Cheaper frontier inference makes hybrid AI more practical; it does not make local data and agent infrastructure irrelevant.
Who Should Use Claude Opus 5.5?
| Workload | Opus 5.5 Fit |
| Large codebase migration | Strong fit |
| Long-running coding agent | Strong fit |
| Complex debugging or review | Strong fit |
| Multi-tool knowledge work | Strong fit |
| Short routine chat | Often unnecessary |
| Simple classification or extraction | Cheaper models may be sufficient |
| Fully offline inference | Not supported |
Opus 5.5 makes the strongest case when failure, repeated retries, or supervision cost more than the difference between model tiers.
If a simple task is reliably completed by a cheaper model in one call, flagship reasoning adds little economic value.
Claude Opus 5.5 Makes Frontier AI an Infrastructure Question
Model releases used to be summarized by one idea: the new model scores higher, so it is better.
Opus 5.5 is more interesting because the capability gain arrives alongside cheaper repeated context, faster output, adaptive reasoning, and lower expected task cost.
Those changes determine whether a frontier model can stay inside an agent loop for an entire workflow rather than appear only for the hardest prompt.
The biggest upgrade in Claude Opus 5.5 may not be that Anthropic made its flagship model smarter. It is that Anthropic made flagship-level intelligence easier to keep running.
When was Claude Opus 5.5 released?
How much does Claude Opus 5.5 cost?
Claude Opus 5.5 costs $4 per million input tokens and $20 per million output tokens. Cache reads cost $0.20 per million tokens. Anthropic estimates typical token-billed workloads cost about 40% less than Opus 5.
Does Claude Opus 5.5 have a 1 million-token context window?
Yes. Opus 5.5 supports a 1 million-token context window and up to 128K tokens of normal output.
Is Claude Opus 5.5 better than Claude Opus 5?
Anthropic reports higher agentic coding performance, lower token prices, cheaper cache reads, and faster output for Opus 5.5. Real-world results still depend on tools, context, workflow design, and task type.
Can Claude Opus 5.5 run locally?
No. Claude Opus 5.5 is a hosted model. A local or hybrid system can still keep files, retrieval, memory, tools, and routine workloads local while selectively using Opus 5.5 through an API.
Que componentes permitem a pesquisa híbrida em ficheiros NAS?
Saiba como identificadores exatos e significado semântico conduzem a um único resultado de pesquisa NAS classificado, sem contornar permissões nem ocultar evidências insuficientes.
Que funcionalidades permitem uma seleção fiável de versões de documentos em RAG?
Veja como o RAG seleciona a revisão aplicável em vez da cópia desatualizada mais semelhante e como testar atualizações explícitas, implícitas e sobrepostas.
Que fatores fazem com que os planos dos agentes divirjam das permissões de ferramentas disponíveis?
Saiba como a descoberta, a delegação, o feedback sobre políticas e o novo planeamento mantêm os passos propostos por um agente de IA alinhados...
