How PC Build Therapy Builds an RTX Gaming PC with ZimaBoard 2
Thank you to PC Build Therapy for testing an unusual use for ZimaBoard 2: a compact gaming computer with a low-profile RTX 3050. The project demonstrates two useful configurations. The Intel N150 handles the creator’s selected retro games through Batocera using integrated graphics; adding an ASUS RTX 3050 6GB opens up the Windows gaming tests. The dedicated-GPU build also needs a suitable power supply, physical support, and active cooling.
The strongest lesson is to evaluate the complete assembly. The GPU changes graphics capability, while the CPU, system memory, expansion connection, and power budget still shape the result. This article follows the video’s progression from the original board to the finished RTX system, then explains how to interpret the reported frame rates with their settings attached.
Watch the build first: PC Build Therapy’s full ZimaBoard 2 gaming experiment shows the assembly, the power-supply requirement, and the original game footage.
Start with the hardware that stays the same
The review unit is the 8GB RAM and 32GB eMMC configuration of ZimaBoard 2. Its Intel N150 provides four CPU cores. The platform’s storage and PCIe connections make the experiment possible, but installing a graphics card leaves the underlying processor and system-memory capacity unchanged.
Part of the build What the creator uses Why it matters
Host ZimaBoard 2 with Intel N150, 8GB LPDDR5, and 32GB eMMC The CPU and system RAM remain the foundation of both test stages.
Graphics Integrated Intel graphics first; ASUS RTX 3050 6GB low-profile card later The two stages answer different questions about emulation and Windows gaming.
Mechanical support HDD cage, PCIe bracket, and extension cable The assembly needs support and cable clearance beyond the board’s dimensions.
Cooling The small board fan, alongside the GPU’s own cooling Sustained game loads make airflow part of the build.
Power The compatible 120W adapter specified by the creator The standard 60W adapter is insufficient for the demonstrated RTX configuration.
PC Build Therapy shows the Intel N150 ZimaBoard 2 with 8GB LPDDR5 and 32GB eMMC
The hardware overview identifies the 8GB/32GB board used in the experiment. Intel’s processor base-power specification describes the CPU; the complete GPU-equipped system has a larger power budget. Video frame at 2:30, courtesy of PC Build Therapy.
The video’s small-computer premise needs one practical qualification: the finished machine includes the graphics card, mounting hardware, cables, drives, and an external power adapter. Measure that complete layout before choosing a desk position or enclosure. The dimensions of the base board alone do not describe how much space the assembled computer needs.
For the broader home-server decision, JBlanked’s home lab comparison explains why application compatibility and storage connections can matter as much as a processor specification. PC Build Therapy takes the next question in a specific direction: what happens when the expansion slot is used for gaming graphics?
Establish the Batocera baseline before adding the GPU
The first gaming stage uses Batocera and the board’s integrated graphics. PC Build Therapy works through seven selected systems: Game Boy Advance, Mega Drive, Super Nintendo, PlayStation, Nintendo 64, PSP, and PlayStation 2. The examples include Castlevania: Aria of Sorrow, Comix Zone, Tekken 3, Super Mario 64, God of War: Chains of Olympus, and Need for Speed: Underground 2.
The creator describes a playable experience in the demonstrated games, including the final PS2 example. That is a useful baseline for deciding whether a GPU is needed for your own collection. It does not establish compatibility with every title in those console libraries. Emulator choice, rendering resolution, game behavior, and controller setup should stay attached to any comparison.
PC Build Therapy plays God of War Chains of Olympus in the Batocera emulation test
The PSP demonstration is part of the integrated-graphics baseline before the RTX card is installed. Test your own games and emulator settings individually, especially as the console generation becomes more demanding. Video frame at 6:05, courtesy of PC Build Therapy.
Follow the official Batocera installation guide when preparing a similar experiment. Choose the image for a compatible x86_64 PC and identify the destination drive before writing it. Flashing an operating-system image replaces the contents of its target, so preserve the existing installation and data before changing the boot setup.
Batocera’s games and BIOS documentation explains its user-data layout. Begin with one known game and a configured controller, confirm the save location, and test a restart. Then work toward the more demanding titles in your own collection. This creates a repeatable baseline before extra graphics hardware introduces more variables.
Give the RTX 3050 a complete power budget
Use the compatible 120W power adapter for the demonstrated RTX 3050 build. PC Build Therapy reports that the standard 60W brick produced a black screen when demanding games started. The creator also says undervolting did not resolve that power problem. This requirement appears in both the video’s explanation and its description, so it belongs before the assembly instructions.
The exact GPU variant matters. NVIDIA’s RTX 3050 specifications list 70W graphics-card power for the 6GB version and 130W for the 8GB version. The model name alone is therefore insufficient when planning another build. Verify the specific card, its power connections, and the supply arrangement supported by the host.
PC Build Therapy compares power adapters before installing the RTX 3050
The creator calls for the compatible 120W supply after reporting black screens with the standard 60W adapter under demanding games. Plan the power budget for the board, GPU, drives, and cooling together. Video frame at 8:00, courtesy of PC Build Therapy.
The ZimaBoard 120W adapter specification identifies a 12V/10A output and support for low-profile PCIe GPUs on ZimaBoard and ZimaBoard 2. Use the compatible voltage, connector, and delivery path for the actual hardware. A larger wattage printed on an unrelated adapter does not establish compatibility.
Keep the CPU’s power figure in its proper scope. Intel lists a 6W processor base power for the N150. The board’s configuration, GPU, drives, fans, and conversion losses belong to the complete system. The adapter rating describes available output capacity; actual wall consumption needs a measurement of the assembled machine under the intended workload.
Support the card, cooling, and PCIe connection together
The assembly sequence adds the small fan to the board, fastens the storage cage, attaches the PCIe support bracket, and connects the extension cable and graphics card. PC Build Therapy specifically distinguishes the longer cage-mounting screws from the screws removed during fan installation. Keep the appropriate fasteners with each part rather than assuming every screw can be reused in the next position.
Check the physical arrangement with power disconnected. Support the graphics card independently of cable tension, leave space for the GPU’s fans, and make sure the extension cable and drive leads can reach their connections without pulling. A card that fits the PCIe connection still needs a stable mounting position, an unobstructed air path, and clearance around its display outputs.
The assembled ZimaBoard 2 and ASUS RTX 3050 low-profile gaming build
The completed assembly supports the graphics card beside the storage carrier. The GPU, bracket, riser, and power adapter add to the space required by the palm-sized base board. Video frame at 10:25, courtesy of PC Build Therapy.
The expansion connection is another resource to allocate. ZimaBoard 2’s open-ended PCIe x4 slot makes the experiment possible, but the card’s physical connector does not create a desktop motherboard’s full x16 electrical link. Using this expansion path for the GPU also affects plans to attach another PCIe device. Decide where the game library will live and how its storage will connect before assembling everything around the card.
The two operating-system stages also deserve a clear boundary. The retro demonstration boots Batocera; the RTX game benchmarks use Windows. Treat those as separate boot environments when planning the machine’s role. The video demonstrates the gaming build rather than a configuration that keeps a ZimaOS NAS installation and Windows games running simultaneously.
Read the 1080p results with their settings attached
After the RTX installation, PC Build Therapy runs Time Spy and three Windows games. The table below records the values reported in the video. They describe this build and its selected workloads; game versions, drivers, background activity, and test scenes can change a later run.
Test Reported setup Creator’s result
3DMark Time Spy The completed N150 and RTX 3050 system 4,152 combined score
Counter-Strike 2 1080p, high settings 88.4 average FPS
GTA V Enhanced 1080p, high settings 57.1 average FPS
Cyberpunk 2077 1080p output, high textures, other settings described as medium/low, DLSS Balanced 47.1 average FPS; the results screen shows ray tracing disabled
Cyberpunk 2077 benchmark result showing 47.10 average FPS on the ZimaBoard 2 RTX 3050 build
The recorded Cyberpunk result shows 47.10 average FPS at 1920×1080 output with DLSS Balanced and ray tracing disabled. Keep those settings attached to the result when comparing it with another system. Video frame at 12:30, courtesy of PC Build Therapy.
The Cyberpunk result is particularly easy to misread without its settings. DLSS Balanced reconstructs the output image from a lower internal rendering resolution. Keep the 1080p output target, DLSS mode, and graphics options together when comparing the result with another computer. The recorded results screen also shows frame generation disabled.
Average FPS is one part of the experience. A repeat run should also check stutter, low-frame-rate moments, loading behavior, and stability after the system has warmed up. Use the same scene or built-in benchmark for each change, record the game and driver versions, and vary one setting at a time. That helps distinguish a useful configuration change from a different test workload.
The N150 remains a four-core processor after the graphics upgrade. PC Build Therapy notes that the Time Spy CPU score is less than half the graphics score and identifies CPU-intensive games as a limitation. The results show what this combination can do; they do not quantify how much performance belongs to CPU limits versus the PCIe link. A faster graphics card would need its own measurements before being treated as an improvement worth buying.
Choose the role before turning the experiment into a daily machine
This build makes sense as a compact hardware experiment, especially when the board already has a place in a home lab. Before buying the remaining parts, compare the complete cost and footprint: GPU, support hardware, compatible power adapter, storage, and the software environment you intend to use. Check the particular games you want to play rather than judging the purchase from the RTX label.
For a daily system, validate the complete routine: a cold boot, the intended display connection, controller or keyboard input, a sustained game session, and a normal shutdown followed by another boot. Keep save files and any important data in a backup you can restore. If the machine’s main job is storing files, decide how gaming sessions and OS changes will affect its availability.
Smart Life’s private-cloud walkthrough follows the storage-first use of the same platform. For a game server that other people join, LADTech’s Minecraft hosting walkthrough covers a different job: managing a server process and remote access. Choose the workflow that matches the service you actually need.
Do I need an RTX card for the Batocera games shown?
The creator tests the selected retro games with integrated graphics before adding the RTX 3050. Start by testing your own collection with that simpler configuration. Results for one PSP or PS2 title do not establish performance across the entire console library.
Can I keep the standard 60W power adapter?
For the demonstrated RTX 3050 6GB configuration, follow the creator’s requirement for the compatible 120W adapter. The video reports black screens with the 60W brick when demanding games begin, and says undervolting did not fix the problem.
Is the complete gaming PC a 6W system?
The 6W figure is Intel’s processor base-power specification. The full computer also powers the GPU, storage, cooling, and board circuitry. Measure the complete setup to assess its consumption.
Does 6GB of GPU memory add to the board’s 8GB of system RAM?
These are separate memory pools. The GPU’s VRAM holds graphics data; the operating system and game also need system RAM. The review’s 8GB host remains an 8GB host after the card is installed.
Was Cyberpunk tested at native 1080p rendering?
The reported run targets 1920×1080 output with DLSS Balanced enabled. Preserve that distinction when comparing its 47.1 average FPS with a run using native rendering, a different DLSS mode, or different graphics settings.
Can the same setup keep my NAS available while I play Windows games?
The video demonstrates separate Batocera and Windows stages. A plan for simultaneous NAS service and gaming needs a separately designed and tested software arrangement. Establish storage access, workload isolation, and recovery before relying on one machine for both jobs.
Conclusion
PC Build Therapy demonstrates a practical progression: test retro gaming on the base board, supply the RTX configuration properly, support and cool the assembled hardware, then assess Windows performance using explicit settings. The selected games show that the compact platform can do more than its usual storage role, while the CPU, memory, power delivery, and complete footprint remain part of the decision.
Return to PC Build Therapy’s complete build and game tests for the original sequence. The creator discloses that the ZimaBoard 2, power adapter, HDD cage, and PCIe bracket were supplied for review, while the ASUS graphics card was purchased separately for this project.
Zima Campaign Hub
