A ZimaBoard SE NAS with an RTX 3060 and USB Database Storage
Thank you to u/guitarholic2008 for sharing a ZimaBoard SE NAS build that brings together hard drives, USB storage and an RTX 3060. ZimaOS runs on the boardโ€™s eMMC, while a separate SSD holds databases for Immich and Plex. The result is a compact photo-and-media server whose storage connections reflect the decision to give the expansion slot to a GPU.
The original Reddit story and the creatorโ€™s replies also describe a difficult first boot, a replacement unit and cabling still awaiting improvement. Those details make this a useful account of an evolving personal build, rather than a finished reference configuration.
A Replacement Unit Put the NAS Project Back on Track
The first machine did not become a working server. The owner reports that its eMMC appeared in the BIOS, but attempted operating-system installations did not leave a usable boot loader. They tried multiple installation drives and another operating system before narrowing their attention to the onboard storage.
In the reply describing that investigation, changing the boot option filter to UEFI-only made the drive disappear from the available BIOS devices. The creator characterizes the original eMMC as faulty and says IceWhale quickly supplied a replacement. That is the resolution reported for this individual unit; the thread does not provide a laboratory diagnosis or establish a general failure pattern.
guitarholic2008โ€™s ZimaBoard SE NAS kit with two hard drives, an RTX 3060 and external cooling
The working assembly brings the board, drive tray, GPU and cooling hardware together. Original photograph: u/guitarholic2008, via the linked Reddit post.
This starting point matters because it separates the installation trouble from the later running configuration. The replacement is the machine described as using ZimaOS on eMMC. The post does not say the original fault was repaired by a BIOS setting, and the troubleshooting sequence should not be read as a universal fix.
The Kit Combines Several Storage Connections
The creator identifies a 1664 NAS kit and gives capacities for the attached drives. Keeping the connection types alongside those capacities explains the layout more clearly than adding the numbers into a single storage total.
Part Owner-reported configuration
Server ZimaBoard SE 1664 NAS kit; ZimaOS on eMMC
Hard drives Two 3 TB WD Red drives
Application database storage 1 TB PNY SSD connected over USB
Additional USB disk 2 TB Seagate Barracuda 2.5-inch hard drive
Expansion NVIDIA RTX 3060 with 12 GB VRAM
Power and cooling equipment Corsair AX 750 PSU, fan mounts and a USB-to-PWM fan controller
The corresponding hardware is ZimaBoard SE. The inventory records this ownerโ€™s assembled system, including equipment outside the board kit. It does not establish a particular RAID layout, protected usable capacity or backup policy for the two WD Red drives.
For another example of choosing separate jobs for small devices, our small homelab story from u/jc-21 follows a different arrangement. Here, much of the work is concentrated around one board and its attached storage.
The GPU Changes Where the SSD Can Connect
A reader asks why the SSD uses USB rather than a SATA expansion adapter. The creatorโ€™s answer exposes the practical constraint: an expansion adapter would compete with the GPU connection. In this build, retaining the RTX 3060 means using another path for the application SSD.
Side view of guitarholic2008โ€™s ZimaBoard SE build with a fan, GPU mount and attached drives
A side view shows the fan and GPU mounting around the storage assembly. Original photograph: u/guitarholic2008; the image does not supply a complete wiring diagram.
The owner reports using a powered six-port USB 3 hub for the USB drives and fan controller. They also say they intend to replace that older hub and improve cable organization. The USB arrangement is therefore part of the present setup, while cleaner cabling remains a planned change.
This is a useful expansion tradeoff to identify before buying adapters. Choosing one device for the boardโ€™s expansion connection affects how the remaining devices attach. The source does not document every cable or power connection, so the photograph should not be treated as instructions for wiring another GPU and power supply.
Photo and Media Databases Have Their Own SSD
The creator specifically says the SSD hosts databases for Immich and Plex. That gives the SSD a more defined role than simply calling it extra capacity. It holds application state used to organize a library, while the system itself boots from a different device.
The Immich backup documentation explains why both the database and uploaded photo or video files matter to a complete recovery. Knowing where one lives does not identify the location of the other. The Reddit thread does not map every media folder to a drive, so it would be incorrect to assign the full photo collection to the USB SSD.
For a container-based service, the Docker volume documentation provides the related distinction between persistent data and a containerโ€™s writable layer. A useful record for a similar server would identify the actual database path, media path and backup destination before changing an enclosure or storage connection.
Our Proxbox backup-server story offers a companion perspective on giving recovery a defined place in the homelab.
The Monitor Screenshot Documents a Moment in Operation
The creatorโ€™s ZimaOS monitor screenshot showing 16 GB RAM and an NVIDIA GeForce RTX 3060
The creatorโ€™s monitor screenshot identifies 16 GB RAM and an RTX 3060. Displayed utilization and temperature values describe this captured moment, without a documented test workload.
The screenshot provides another view of the assembled machine: its monitoring interface recognizes the GPU and shows system resources. It supports the inventory, but it does not establish how the RTX 3060 is used by Immich or Plex.
There is no specified transcode test, simultaneous-stream count or photo-processing benchmark. A GPU appearing in a dashboard is different from a documented application using that GPU successfully. The interesting confirmed detail is the ownerโ€™s physical and storage arrangement around it.
Cable Organization Is the Next Practical Improvement
The creatorโ€™s next stated change is modest: replace the old USB hub and tidy the cables. That fits the stage visible in the photographs. The project already has identifiable storage and application roles; the next iteration concerns how easily the equipment can be connected and maintained.
For someone adapting the idea, the useful takeaway is to make those relationships explicit. Label the application SSD, record which devices depend on the powered hub, and keep the operating-system location distinct from the libraryโ€™s recovery copies. These are planning lessons from the layout, not maintenance steps the owner claims to have completed.
Where does ZimaOS run in this build?
The owner says it runs on the replacement boardโ€™s eMMC. The USB SSD has a separate database role.
What is the RTX 3060 doing?
The GPU is installed and visible in monitoring. The thread does not document a specific accelerated workload or measured result.
Are the two WD Red drives mirrored?
The source lists two 3 TB drives without specifying the storage layout. Mirroring cannot be inferred from the drive count.
Was the original boot fault fixed with a BIOS change?
The creator reports receiving a replacement unit. The BIOS observations were part of investigating the original problem.
Conclusion
This ZimaBoard SE story connects expansion choices to everyday storage decisions. Giving the slot to an RTX 3060 moves the database SSD onto USB, while eMMC retains the operating system. The replacement-unit experience and unfinished cabling keep the account grounded in the actual process of getting a personal server working and making it easier to maintain.
Zima Campaign Hub
