A ZimaBlade TrueNAS Storage Host in a Shelf-Sized Apartment Homelab
Thank you to u/Aromatic-Canary204 for sharing an apartment homelab in which a ZimaBlade provides a TrueNAS SCALE storage base beside a Raspberry Pi and a newly added Mac mini. The setup brings substantial disk capacity, container experimentation and environmental monitoring into a shelf-sized arrangement that still has room for physical improvement.
The original apartmentlab post describes the machines, storage and cooling controls while asking for ideas for a better organizing structure. Its value is the connection between each component and a household role, rather than the appearance of a completed rack.
The ZimaBlade Gives Storage a Place in the Apartment
The owner describes the ZimaBlade as running TrueNAS SCALE with a NAS setup. Two 14 TB Toshiba enterprise drives provide the named NAS disks, alongside a separate 4 TB media drive associated with streaming services such as Jellyfin, Navidrome and Plex.
Aromatic Canary’s apartment homelab with a ZimaBlade storage assembly beside compact computers and networking equipment
The apartment setup places the ZimaBlade storage assembly beside compact computers and networking equipment. Original photograph: u/Aromatic-Canary204, via the linked Reddit post.
Those capacities show the scale of the owner’s storage needs, but they do not identify a pool topology. The post does not state whether the two large drives are mirrored, which datasets they contain or how much protected capacity is available. A drive inventory and a data-protection design answer different questions.
The matching hardware reference is ZimaBlade. The creator does not identify its precise model or memory configuration. The system should therefore remain a ZimaBlade story without being assigned a particular edition from the photograph.
Several Small Machines Share the Work
The other computers give the storage host context. The Raspberry Pi runs Rocky Linux with MicroShift, while the Mac mini is a recent addition for remote-desktop access. Running AI models on the Mac is something the owner is considering, rather than an established workload.
Part of the setup Role or detail stated in the post
ZimaBlade TrueNAS SCALE and NAS duties
NAS disks Two 14 TB Toshiba enterprise drives
Media storage Separate 4 TB drive for streaming services
Raspberry Pi Rocky Linux with MicroShift
Mac mini Remote desktop; possible future AI experiments
Network and environment UniFi networking, three case fans and an ESP with a DHT11 sensor
The owner reports roughly forty workloads and a virtual machine running a web application firewall, along with block, object and file storage. That describes the larger setup. The post does not allocate all forty workloads to the ZimaBlade or say that each named service runs on the same operating system.
Our small homelab story from u/jc-21 offers a related example of dividing useful services among compact devices. The transferable detail is the division itself, rather than a particular machine count.
MicroShift Adds a Different Environment to Learn
The Raspberry Pi’s MicroShift installation gives this shelf more than one style of system administration. The MicroShift project focuses on bringing Kubernetes capabilities to smaller environments. Here, it is a named part of the owner’s Raspberry Pi setup; it should not be silently substituted for the software on the NAS.
That distinction makes the build interesting as a learning environment. The storage appliance and the application platform can have different update procedures and different failure symptoms. A storage share becoming unavailable is not the same event as an application workload failing to start.
The source does not publish a complete deployment diagram. It therefore cannot establish how every workload obtains storage, which node runs the firewall VM or which network paths connect the services. For someone adapting the arrangement, writing that map would make the existing division of machines easier to operate.
Media Files and Storage Services Need Clear Boundaries
The owner names several types of storage—block, object and file—alongside a dedicated media disk. These are useful categories, but they are not interchangeable descriptions of the same share. The application using the data determines how that data needs to be presented and recovered.
The TrueNAS SCALE getting-started documentation separates storage setup, data sharing and configuration tasks. It is a helpful reference for understanding the NAS role named here. The linked documentation is not evidence that this creator used a particular TrueNAS version or followed every illustrated configuration.
A reader planning a similar setup could begin by recording the media drive’s consumers and the location of important application state. That record would make a disk replacement or a software move less dependent on remembering which path belongs to which machine.
For another build that explicitly separates a small storage host from application and GPU computers, see the MiniRack V2 storage-and-AI story. Its hardware differs, while the question of where each responsibility belongs remains useful.
Cooling Is Connected to Household Automation
Three case fans sit behind the equipment, controlled through a smart plug and automated with Home Assistant. The owner also identifies an ESP and DHT11 sensor in the corner for environmental temperature monitoring. This makes room conditions part of the setup’s operating picture.
The Home Assistant automation documentation explains how triggers, conditions and actions describe automated behavior. The Reddit post does not share its automation logic or temperature thresholds, so it does not establish that a specific sensor reading directly switches these fans.
The distinction between environmental monitoring and component cooling also matters. A room or shelf sensor does not measure every drive or processor. The owner says the fans do not need to run very often, but supplies no temperature log, sustained-load test or acoustic measurement.
Likewise, the description of low power consumption is an owner impression without a stated wattage. It should remain qualitative. Converting it into an annual energy saving or comparing it numerically with a rack server would go beyond the evidence supplied.
The Next Project Is a Better Physical Structure
The creator’s requested improvement is a custom structure to organize the existing equipment. That makes this a different stage from a finished printed rack: the useful computers and storage already exist, while the enclosure or mounting plan is still open.
The photograph shows why that could be worthwhile. Drives, network cables and small computers occupy a shared shelf, with the cooling equipment behind them. A new structure would need to preserve connector access and airflow as well as give the parts a consistent arrangement.
For another builder, a sensible starting record would include device dimensions, cable exits and the space needed to remove a drive. Those are practical implications of the layout, not dimensions supplied by the creator. The source provides an inspiration and inventory, rather than a measured construction plan.
Does the ZimaBlade run ZimaOS?
The owner identifies TrueNAS SCALE on the ZimaBlade. This story does not substitute ZimaOS for that choice.
Are the two 14 TB drives a mirror?
The post does not specify a pool layout. The disk count alone does not establish mirroring or protected usable capacity.
Is the Mac mini already running local AI models?
No completed AI deployment is described. The owner names remote desktop as its present purpose and AI as a possible next use.
Are the fan-control thresholds published?
No. The owner describes Home Assistant automation and environmental sensing without providing the automation settings.
Conclusion
This apartmentlab gives ZimaBlade a clear storage role within a collection of small machines. TrueNAS, a Raspberry Pi learning environment, remote desktop and household automation share a limited physical space without becoming one undifferentiated server. The next step is organizational: make the structure and service map as understandable as the hardware inventory already is.
Zima Campaign Hub
