What Is RAID and How Does It Work?
RAID is a way to make several physical drives behave like one storage system. Depending on how it is configured, RAID can improve speed, help a NAS survive a drive failure, improve usable capacity efficiency, or combine some of these goals.
But RAID is often misunderstood by first-time NAS buyers. It does not automatically make data safe, it does not always give you the full capacity printed on the drive labels, and it is not the same as backup. The right RAID setup depends on what you care about most: performance, usable capacity, uptime, or real recovery.
RAID Makes Multiple Drives Act Like One Storage Volume
A common home NAS setup starts with two, four, or more drives. The user does not want to manage Disk 1, Disk 2, Disk 3, and Disk 4 separately from every computer. They want one shared storage space for family files, media, backups, Docker data, or project archives.
That is the basic role of RAID. It combines multiple physical disks into a logical storage volume that the operating system or NAS software can present as one usable storage space. TechTarget describes RAID as a way of placing data on multiple disks while allowing them to appear as one logical unit, which is why multiple drives into one logical storage system is the simplest way to understand the idea.
The important part is that RAID is not one single behavior. Different RAID levels decide where data blocks go, whether a second copy is written, and whether parity information is stored for recovery. That choice changes speed, usable capacity, and what happens when a drive fails.
The Three Building Blocks: Striping, Mirroring, and Parity
RAID levels can look confusing because the names are just numbers: RAID 0, RAID 1, RAID 5, RAID 6, RAID 10. Underneath those numbers, most RAID designs are built from three basic actions: striping, mirroring, and parity.
DigitalOcean’s RAID terminology overview explains striping, mirroring, and parity as core concepts. Striping splits data across drives so they can work in parallel. Mirroring writes full copies to more than one drive. Parity stores recovery information that can help rebuild missing data after a drive failure.
Once you understand those three actions, RAID becomes less mysterious. RAID 0 is mostly striping. RAID 1 is mirroring. RAID 5 and RAID 6 use parity. RAID 10 combines mirroring and striping. The level you choose is really a trade-off between speed, usable capacity, and drive-failure resilience.
Building Block What It Does Main Trade-Off
Striping Splits data across drives More speed, no safety by itself
Mirroring Writes full copies to multiple drives Safer, but uses more capacity
Parity Stores recovery information Better capacity efficiency, slower rebuilds
RAID 0 Is Fast, but It Has No Safety Net
RAID 0 is attractive because it looks efficient. Two 4TB drives can appear close to 8TB usable, and reads or writes may be faster because data is striped across both drives. For someone trying to get more speed and capacity from a small number of disks, that sounds appealing.
The problem is that RAID 0 has no mirroring and no parity. Each file is split across multiple drives, so the array depends on every drive staying healthy. If one drive fails, the data spread across the array may become unusable.
That makes RAID 0 a poor choice for important home NAS data. It can make sense for temporary workspace, cache, scratch video editing, test data, or media that can be recreated or downloaded again. It should not be used for family photos, work files, backup targets, or the only copy of anything important.
RAID 1 Is Simple Drive-Failure Resilience
For a 2-bay home NAS, RAID 1 is often the easiest redundant setup to understand. You install two drives, and the NAS writes the same data to both. If one drive fails, the other still has a full copy.
The trade-off is capacity. Two 8TB drives in RAID 1 do not give you 16TB of usable storage. They give you roughly one drive of usable capacity, because the second drive is used as the mirror. For many households, that trade-off is acceptable because the goal is not maximum capacity; the goal is surviving a single drive failure without losing access immediately.
RAID 1 is a good default for simple 2-bay NAS storage, but it is not a backup. The deeper RAID 0 and RAID 1 trade-off is really about speed and capacity versus safer everyday storage.
RAID 5 and RAID 6 Use Parity to Balance Capacity and Resilience
Once a NAS has three or four drives, mirroring everything can feel expensive. This is where RAID 5 and RAID 6 become common. They use parity so the system can recover from a failed drive without sacrificing as much usable capacity as full mirroring.
RAID 5 uses single parity and can usually tolerate one drive failure. RAID 6 uses dual parity and can usually tolerate two drive failures. The cost is parity overhead, more complex writes, and longer rebuilds after a failed drive is replaced.
For a 4-bay home NAS, RAID 5 or RAID 6 can be reasonable depending on the data, drive size, and backup plan. RAID 5 gives more usable capacity. RAID 6 gives a larger safety margin during drive failure and rebuild. Neither one removes the need for separate backup.
RAID 10 Combines Mirroring and Striping
RAID 10 often sounds like the “better” RAID because it combines two familiar ideas: RAID 1 mirroring and RAID 0 striping. In practice, it usually starts with mirrored drive pairs, then stripes data across those pairs.
This gives RAID 10 strong performance and good resilience, especially for workloads with many reads and writes. It can be useful for virtual machines, databases, home lab storage, and other workloads where write behavior matters more than simply maximizing usable capacity.
The trade-off is drive cost. RAID 10 usually requires at least four drives, and usable capacity is roughly half of total raw capacity. For a normal family NAS used for photos, documents, media, and backups, RAID 10 may be more than necessary. For a write-heavy home lab, it can make more sense.
Common RAID Levels Compared
Most home users do not need to memorize every RAID level. They need to understand what each common option is trying to optimize: speed, simple mirroring, parity efficiency, stronger fault tolerance, or performance plus resilience.
NI’s overview of common RAID levels is useful because it separates RAID 0, RAID 1, RAID 5, RAID 6, and RAID 10 by minimum drive count and behavior. That is the level of understanding most beginner NAS buyers need before choosing a layout. If you choose ZimaOS, verify the supported array configuration and recovery procedure before treating the RAID layout as settled.
Compare Plans
ZimaOS
FREE
  • Core features
  • Zima Client for Mobile & PC
  • Thunderbolt Support
  • Developer Mode
  • 4 Disks
  • 3 Members
Download Now
ZimaOS+
$29Lifetime License
Effortless expansion
  • Everything in Free
  • Unlimited Disks
  • Unlimited Users
Buy Now
This table is only a starting point. Your actual usable capacity, expansion path, rebuild behavior, and snapshot support depend on the NAS operating system and filesystem. Always confirm the details inside the NAS software before storing important data.
RAID Level Minimum Drives Main Goal What You Give Up
RAID 0 2 Speed and full raw capacity No drive-failure protection
RAID 1 2 Simple mirroring About half usable capacity
RAID 5 3 Capacity efficiency + one-drive fault tolerance Slower rebuild, parity overhead
RAID 6 4 Two-drive fault tolerance More capacity and write overhead
RAID 10 4 Speed + mirror resilience About half usable capacity
Raw Capacity Is Not the Capacity You Should Plan Around
Capacity confusion is one of the first problems new NAS users run into. Four 12TB drives sound like a 48TB NAS. Two 8TB drives sound like 16TB. But those numbers are raw capacity, not necessarily safe usable capacity.
Usable capacity depends on the RAID level, filesystem overhead, snapshots, reserved space, and how much free headroom you want to keep. RAID 1 mirrors data, so usable capacity is close to one drive. RAID 5 reserves roughly one drive’s worth for parity. RAID 6 reserves more. RAID 10 usually gives about half of raw capacity.
Plan a NAS from usable capacity backward. Decide how much working storage you need for the next few years, then choose drive size and RAID level. Do not start from the drive label and assume all of it will be available for safe storage.
What Happens When a Drive Fails?
When a drive fails in a redundant RAID array, the NAS may keep running in a degraded state. Files may still be accessible, but the system has lost part of its safety margin. This is the moment when RAID feels useful, but it is also when the array is more vulnerable.
The normal recovery path is to replace the failed drive and let the array rebuild. DigitalOcean’s mdadm tutorial walks through Linux RAID administration, including RAID rebuild after a drive failure. During rebuild, the system uses the remaining mirror or parity information to restore data onto the new drive.
Degraded does not mean safe. During a rebuild, the remaining drives may be under sustained read pressure, and the array has less tolerance for another problem. Larger drives, fuller arrays, older disks, and slower systems can make rebuild time more stressful. This is why RAID should be paired with monitoring and backup, not blind trust.
Hardware RAID, Software RAID, and NAS RAID Are Different Paths
Users often see terms like hardware RAID card, motherboard RAID, software RAID, mdadm, ZFS, Btrfs, RAIDZ, SHR, and vendor RAID. These are not just marketing names. They describe different layers where the array is managed.
Hardware RAID uses a dedicated controller to manage the array. Software RAID is handled by the operating system or storage software. NAS platforms often wrap the same underlying ideas in a friendlier interface, adding snapshots, alerts, shared folders, app storage, and rebuild workflows.
For most home NAS users, the priority is not buying a hardware RAID card. The priority is understanding how the NAS manages drives, how it expands, what happens during rebuild, how alerts are sent, and how backups are handled. If the system offers multiple choices, use the documentation to choose the right RAID mode before committing data.
Drive Choice Matters More Than Beginners Think
It is tempting to build RAID with whatever drives are cheapest or already available. A desktop drive here, an old external drive there, and maybe one new large disk can look like a budget-friendly NAS. That approach may work for testing, but it is not a good foundation for important data.
NAS and RAID workloads are different from occasional desktop storage. Drives may stay powered on for long periods, handle sustained writes, participate in rebuilds, and serve multiple devices. Seagate’s CMR and SMR list is a useful reference when checking CMR drives for NAS workloads, because SMR drives can behave poorly in some sustained-write and rebuild-heavy scenarios.
RAID does not require a mysterious special disk, but the drive choice should match the job. For a home NAS, NAS-rated CMR drives, consistent drive sizes, clear health monitoring, and planned replacement matter more than chasing the lowest price per drive.
RAID Is Not Backup
This is the most important RAID lesson for a home NAS. RAID can help a system survive a drive failure, but it does not protect you from many common data-loss events. If a file is deleted, encrypted, overwritten, or corrupted, RAID may simply preserve that bad state across the array.
RAID does not stop accidental deletion, ransomware, bad sync rules, software bugs, file corruption, theft, fire, water damage, or full NAS failure. It is local resilience, not a recovery strategy. A real backup plan stores another copy somewhere separate from the main array.
For important files, RAID does not replace backup. The safer pattern is redundancy for drive failure, snapshots or versioning for short-term mistakes, and a separate backup copy for real recovery.
Risk RAID Helps? What You Still Need
One drive fails Yes, in redundant RAID Replace drive and rebuild
Accidental deletion No Snapshot or backup
Ransomware encryption No Versioned backup or offline copy
File corruption Not reliably Backup and integrity checks
NAS stolen or damaged No Offsite backup
Fire or flood No Offsite copy
Which RAID Level Makes Sense for a Home NAS?
Most home users do not need every RAID level. They need a choice that matches bay count, data value, and backup maturity. A 2-bay NAS, a 4-bay NAS, and a write-heavy home lab should not automatically use the same layout.
For a 2-bay NAS with important files, RAID 1 plus backup is usually the clearest choice. For temporary speed or scratch storage, RAID 0 can be used only when the data is disposable. For a 4-bay NAS used for media and backups, RAID 5 or a similar single-parity layout may be reasonable. For more important archives or larger drives, RAID 6 or a dual-parity layout provides more fault tolerance. For VM-heavy or write-heavy home lab use, RAID 10 can make sense if you accept the capacity cost.
If you are unsure, avoid RAID 0 for important data. Start from the data’s value, then choose redundancy and backup around it. Speed is nice, but recoverability matters more when the NAS holds family files, work data, or long-term archives.
Final Takeaway
RAID combines multiple drives into one logical storage system, but each RAID level makes a different trade-off. RAID 0 gives speed and capacity with no redundancy. RAID 1 mirrors data for simple drive-failure resilience. RAID 5 and RAID 6 use parity to balance usable capacity and fault tolerance. RAID 10 combines mirroring and striping for stronger performance at higher disk cost.
For a home NAS, RAID is useful because drives fail. But RAID is not backup. It protects against some drive failures, not accidental deletion, ransomware, corruption, theft, fire, or full NAS failure. Choose RAID for local resilience, then build backup for real recovery.
ZimaSpace offers Raid Calculator,Welcome to Try!
What does RAID stand for?
RAID stands for Redundant Array of Independent Disks. It is a storage method that combines multiple physical drives into one logical storage system.
Is RAID the same as backup?
No. RAID helps with drive failure in redundant layouts, but it does not protect against deletion, ransomware, corruption, theft, fire, or a failed NAS. Important data still needs a separate backup.
Which RAID is best for a 2-bay NAS?
For important data, RAID 1 is usually the simplest choice because it mirrors data across both drives. RAID 0 should only be used for temporary or disposable data.
Which RAID is best for a 4-bay NAS?
For many home users, RAID 5 or a similar single-parity layout offers a balance of usable capacity and one-drive fault tolerance. RAID 6 gives more fault tolerance but uses more capacity. RAID 10 can work well for performance-focused home lab storage.
What happens if one drive fails in RAID 5?
The array usually enters a degraded state and keeps running. You replace the failed drive, then the system rebuilds missing data using parity and the remaining drives. During rebuild, the array is more vulnerable.
Is RAID 0 safe for important data?
No. RAID 0 has no redundancy. If one drive fails, the whole array may become unusable. Use it only for temporary data, cache, scratch work, or files that can be recreated.
Does RAID make a NAS faster?
Some RAID levels can improve performance, especially striping-based layouts such as RAID 0 and RAID 10. But speed depends on drives, network, NAS CPU, filesystem, workload, and caching. RAID should not be chosen for speed alone if the data is important.
Do I need NAS-rated drives for RAID?
They are strongly recommended for important NAS use. NAS-rated CMR drives are designed for always-on storage and sustained workloads. Mixing old desktop drives or SMR drives may create performance and rebuild problems.
Zima Campaign Hub
