RAID 0 and RAID 1 are often described as a simple trade-off: speed versus safety. That is mostly true, but it is not enough for a NAS decision. RAID 0 gives you more usable capacity and higher large-file throughput, while RAID 1 gives you protection against a single drive failure.
The real question is not which RAID level is “better.” The better question is what the NAS is storing. If it holds family photos, documents, business files, or backup data, RAID 1 is usually the safer default. If it is only a temporary workspace with another copy elsewhere, RAID 0 can make sense.
RAID 0 and RAID 1 Solve Different Problems
RAID 0 and RAID 1 are not two versions of the same safety feature. They are opposite design choices. RAID 0 is built around striping: spreading data across multiple disks for capacity and speed. RAID 1 is built around mirroring: keeping the same data on two disks so the NAS can survive one disk failure.
That is why a NAS buyer should not start with “which one is faster?” Start with the data. A scratch volume for temporary video files has a very different risk profile from a family photo archive or a small business document folder.
TechTarget’s comparison of RAID 0 vs RAID 1 data protection makes the basic split clear: RAID 0 prioritizes performance without fault tolerance, while RAID 1 focuses on data availability through mirroring.
| RAID Level | Main Goal | What Happens |
| RAID 0 | Speed and capacity | Data is striped across disks |
| RAID 1 | Drive-failure resilience | Data is mirrored to both disks |
Misconception: RAID 0 and RAID 1 are not “fast safe” and “slow safe.” RAID 0 is not a redundancy feature at all.
What RAID 0 Actually Does
RAID 0 uses striping. Instead of writing a whole file to one disk, the array splits data into chunks and writes those chunks across multiple drives. This can improve large-file throughput because more than one disk works at the same time.
The trade-off is severe: RAID 0 has no redundancy. If one disk fails, the array fails. You are not losing only the files on that disk, because parts of many files may be spread across all disks. The whole volume becomes unsafe or unusable.
That is why RAID 0 striping should be treated as a performance and capacity layout, not a protection layout.
| RAID 0 Benefit | RAID 0 Risk |
| More usable capacity | No redundancy |
| Higher large-file throughput | Any disk failure can kill the array |
| Good for temporary workspace | Not safe for important files |
| Simple performance boost | Restore requires a separate backup |
RAID 0 should be treated like fast workspace, not safe storage.
What RAID 1 Actually Does
RAID 1 uses mirroring. With two disks, each disk stores a complete copy of the data. If one disk fails, the NAS can usually keep running from the other disk while you replace the failed drive and rebuild the mirror.
The trade-off is capacity. Two 4TB drives in RAID 1 do not give you 8TB usable. They give you about 4TB usable, because the second drive is holding the mirror. That can feel expensive, but the point is resilience.
| RAID 1 Benefit | RAID 1 Trade-Off |
| Survives one disk failure | Usable capacity is cut in half |
| Easier recovery from drive failure | Write speed may not double |
| Good for important NAS data | Still needs backup |
| Keeps service online | Rebuild takes time |
RAID 1 protects uptime and drive-failure resilience, not every kind of data loss.
Capacity Math Is Simple but Easy to Misread
RAID 0 combines usable capacity across drives. RAID 1 mirrors data, so usable capacity equals the size of one drive in a two-drive mirror. This is one of the biggest reasons beginners feel tempted by RAID 0.
But capacity is not free. RAID 0 gives more usable space by removing redundancy. RAID 1 gives less usable space because it keeps a second live copy inside the NAS.
| Drive Setup | RAID 0 Usable Capacity | RAID 1 Usable Capacity |
| 2 × 2TB | About 4TB | About 2TB |
| 2 × 4TB | About 8TB | About 4TB |
| 2 × 8TB | About 16TB | About 8TB |
| 2 × 12TB | About 24TB | About 12TB |
Misconception: RAID 1 does not “waste” a disk. It spends one disk’s worth of capacity on drive-failure resilience.
Speed Depends on Workload, Not Just RAID Level
RAID 0 is faster on paper, especially for large sequential reads and writes. A two-disk stripe can read and write across both drives at once, so big video files, disk images, and temporary project data may move faster.
RAID 1 can also improve read behavior in some systems because data exists on both disks, but writes usually need to go to both drives. In practice, RAID 1 write speed is often closer to a single disk than a striped array.
But NAS speed is not decided by RAID alone. Network speed, HDD or SSD performance, SMB/NFS overhead, NAS CPU, client disk speed, and file size all matter. If your NAS is limited by 1GbE, small files, or a slow client drive, RAID 0’s theoretical speed advantage may not be visible.
| Workload | RAID 0 Advantage | RAID 1 Behavior |
| Large video files | Stronger | Good read, slower write |
| Backup target | Less important | Safer |
| Small files | Limited | Similar bottlenecks |
| Photos | Not always obvious | Safer for storage |
| VM/image files | Can help | More resilient |
| 1GbE transfer | Often hidden | Often enough |
| 10GbE transfer | More visible | Depends on drive pool |
RAID 0 is faster on paper, but your NAS may be limited by network, drives, SMB, or small files before RAID becomes the bottleneck.
RAID 0 Is Dangerous for Important NAS Data
RAID 0 is not automatically bad. It is bad when people use it for the wrong data. If the NAS is storing the only copy of family photos, tax records, work files, personal archives, client documents, or backups, RAID 0 is the wrong fit.
The reason is simple: RAID 0 expands the failure domain. With two drives, either drive can bring down the whole array. With more drives, there are more failure points. That is acceptable only when the data is temporary, reproducible, or already protected somewhere else.
| Data Type | RAID 0 Fit? |
| Temporary video cache | Yes, if backed up elsewhere |
| Download staging folder | Maybe |
| Game/media copy | Maybe |
| Family photos | No |
| Business documents | No |
| Backup destination | No |
| Tax records | No |
| Private archive | No |
Misconception: RAID 0 is not a cheap way to make safe storage bigger. It is a fast way to make one larger failure domain.
RAID 1 Is Safer, but It Is Not Backup
RAID 1 is safer than RAID 0 for important NAS data because it can survive one drive failure. But this is the most important line in the whole article: RAID 1 is not backup.
RAID 1 mirrors changes. If you accidentally delete a folder, the deletion is mirrored. If ransomware encrypts files, the encrypted files are mirrored. If the NAS is stolen, damaged by fire, hit by a power event, or corrupted by software failure, the mirror does not save you.
Acronis makes the same point in its discussion of why RAID is not a backup: RAID can improve availability, but it does not replace a separate recovery copy.
| Risk | RAID 1 Helps? |
| One drive fails | Yes |
| Accidental deletion | No |
| Ransomware encryption | No |
| File corruption | Usually no |
| NAS stolen | No |
| Fire or flood | No |
| Wrong folder overwritten | No |
| Malware changes files | No |
RAID 1 is redundancy, not backup.
For a 2-Bay NAS, RAID 1 Is Usually the Safer Default
Most 2-bay NAS users are not building disposable scratch storage. They are storing family photos, personal documents, scanned files, work folders, media libraries, backups, and home server configs. For that kind of use, RAID 1 is usually the safer default.
Backblaze’s overview of NAS RAID levels also frames RAID choice around data protection and the role of the NAS, which is the right way to think about a home or small-office setup.
| User Scenario | Better Choice |
| Family photo storage | RAID 1 |
| Personal documents | RAID 1 |
| Small business files | RAID 1 |
| Time Machine / PC backup target | RAID 1 + external backup |
| Temporary editing cache | RAID 0 |
| Non-critical download volume | RAID 0 or single disk |
| Media copy with master elsewhere | RAID 0 can work |
If you are unsure which one to choose, RAID 1 is usually the safer NAS answer.
When RAID 0 Actually Makes Sense
RAID 0 can make sense when the data is disposable or already protected somewhere else. A temporary video editing workspace, render cache, AI dataset cache, game library copy, download staging area, or non-critical media copy can benefit from capacity and sequential speed.
The rule is simple: if the array failed tonight, could you rebuild the data without panic? If the answer is yes, RAID 0 may be acceptable. If the answer is no, RAID 0 is the wrong design.
| RAID 0 Makes Sense If... | RAID 0 Is a Bad Idea If... |
| Data is temporary | Data is irreplaceable |
| Another copy exists | This NAS is the only copy |
| Speed matters more than uptime | Safety matters more |
| Restore is easy | Restore would be painful |
| Failure is acceptable | Downtime is unacceptable |
RAID 0 is a workspace choice, not an archive choice.
When RAID 1 Is the Better NAS Choice
RAID 1 is the better choice when the NAS server is expected to keep important files available. That includes family archives, scanned documents, home office files, small business folders, personal cloud storage, server configs, and backup targets.
RAID 1 does not make the NAS invincible. It simply means a single drive failure is less likely to become an immediate data crisis. You still need snapshots, external backup, offsite backup, restore testing, and drive health monitoring.
| RAID 1 Fits When... | Why |
| Files are important | Survives one disk failure |
| NAS is always on | Keeps service available |
| Family uses shared folders | Less downtime risk |
| Backup target matters | Safer than RAID 0 |
| Rebuild should be simple | Replace failed disk and rebuild |
| You value peace of mind | Capacity trade-off is acceptable |
For important data, the capacity trade-off of RAID 1 is usually easier to accept than the recovery risk of RAID 0.
RAID 0 vs RAID 1 Is Not the Same as Backup Strategy
RAID chooses how the NAS survives disk failure. Backup chooses how your data survives everything else. Those are different jobs.
A good NAS plan can use RAID 1 for local drive-failure resilience, snapshots for accidental changes, local backup for device-level recovery, and offsite backup for theft, fire, flood, or major failure. RAID is one layer, not the whole strategy.
| Layer | Purpose |
| RAID | Keeps storage available after disk failure |
| Snapshot | Helps recover from accidental changes |
| Local backup | Restores from device failure or deletion |
| Offsite backup | Protects against fire, theft, or disaster |
| Restore test | Confirms backup actually works |
Quick Decision Checklist
| Question | Choose RAID 0 If... | Choose RAID 1 If... |
| Is the data important? | No | Yes |
| Do you have another copy? | Yes | Still yes |
| Do you need maximum usable capacity? | Yes | No |
| Do you need single-drive failure protection? | No | Yes |
| Is this temporary workspace? | Yes | Maybe |
| Is this a family or business archive? | No | Yes |
| Can you tolerate full restore after disk failure? | Yes | No |
| Are you unsure? | Usually no | Usually yes |
Final Takeaway
RAID 0 and RAID 1 are not “fast vs slow” only. They are different risk models. RAID 0 gives you more capacity and better large-file performance, but any disk failure can destroy the whole array. RAID 1 gives you less usable capacity, but it keeps the NAS running through a single drive failure.
For most NAS users storing important data, RAID 1 is the safer default. RAID 0 only makes sense when the volume is disposable, backed up elsewhere, or used as temporary high-speed workspace. And neither RAID 0 nor RAID 1 replaces a real backup plan.
Is RAID 0 faster than RAID 1?
Usually yes for large sequential reads and writes, because RAID 0 stripes data across multiple disks. But real NAS speed also depends on network speed, drives, SMB/NFS, CPU, client disk speed, and file size.
Is RAID 1 safer than RAID 0?
Yes. RAID 1 can survive one disk failure in a two-drive mirror. RAID 0 has no redundancy, so one failed disk can bring down the whole array.
Does RAID 1 give me backup?
No. RAID 1 is redundancy, not backup. It helps with one drive failure, but it does not protect against deletion, ransomware, theft, fire, corruption, or user error.
How much usable capacity do I get with two 4TB drives?
With RAID 0, you get about 8TB usable. With RAID 1, you get about 4TB usable because the second drive mirrors the first.
Should I use RAID 0 for family photos?
No. Family photos are usually irreplaceable, so RAID 0 is a poor fit. RAID 1 plus external or offsite backup is much safer.
When does RAID 0 make sense in a NAS?
RAID 0 makes sense for temporary workspace, video cache, render cache, non-critical media copies, or data that already has another complete backup elsewhere.
Is RAID 1 enough for a home NAS?
RAID 1 is a good local resilience layer for a 2-bay NAS, but it should still be paired with snapshots, external backup, offsite backup, and restore testing.
Which should I choose if I am not sure?
Choose RAID 1. If you are unsure, your data is probably important enough that drive-failure resilience matters more than RAID 0’s extra capacity and speed.
Product Comparisons
WireGuard Server vs Mesh VPN for Devices Behind CGNAT
Use mesh VPN for low-friction roaming devices; use a WireGuard relay when you want to own routing, keys, and the public endpoint.
10GbE NAS on Gigabit Clients: Upgrade the Server or Endpoints First?
Upgrade the endpoint path for one slow workstation; upgrade the NAS uplink first when several gigabit clients saturate it together.
1GbE vs 2.5GbE for a Home Server: Which Workloads Cross the Line?
Keep 1GbE for light services and single streams; move to 2.5GbE when recurring transfers or combined clients sustain more than about 100 MB/s.
