Introduction: The Quest for the "Doraemon" AI
Thank you for joining us at ZimaSpace! We are thrilled to share an experimental journey inspired by the creative tech community. We want to extend a huge thank you to the original video creator, Zero (from the YouTube channel @zer0_station), for his fascinating experiment using the ZimaBoard 2.
In this experiment, Zero explores a concept beyond simple prompt-and-response interactions. Usually, we ask ChatGPT or Gemini to summarize a PDF or write code, and it stops there. Zero wanted to create somethi
ng closer to a "Doraemon"—an AI that doesn't just wait for instructions but thinks and acts on its own.
To test this, he utilized the ZimaBoard 2, a high-performance single-board home server designed for 24/7 silent operation. With its Native SATA & PCIe expansion and Dual 2.5G Ethernet, it is the perfect "sandbox" for high-stakes AI experiments where you wouldn't want to risk your primary computer.
Step 1: Setting the Foundation with ZimaBoard 2 🛠️
To give the AI a "body" to live in, Zero started with a clean slate:
- Hardware: ZimaBoard 2 (equipped with 16GB RAM and expanded with 6TB of HDD/SSD storage).
- OS: A fresh installation of Ubuntu Server (a popular Linux distribution) to provide a standard environment for Python scripting.
- The Logic: Zero created a Python script that functions as a continuous loop. Instead of one-off chats, the AI’s output from one turn is fed back as the input for the next, allowing it to "reflect" on its own actions.
This experiment builds on the broader capabilities covered in this ZimaBoard 2 home lab server review and setup , including virtual machines, Docker containers, networking, storage, and backup workflows.
"The ZimaBoard is perfect for this because it's a mini server that looks like a toy but runs like a beast." — Zero
That same DIY mindset extends to the DIY-friendly ZimaBoard 2 packaging , which can be repurposed as a compact desk stand for the board and connected drives, helping keep the physical AI server setup organized.
Step 2: Designing the AI’s "Brain" and Memory 🧠
Current AI models have a "short-term memory" problem when used via API (Application Programming Interface). To fix this, Zero programmed specific functions:
- Memory & History: Long-term facts are saved as text files so the AI doesn't forget who it is after a reboot.
- The Diary Function: A dedicated file where the AI records its daily achievements and "thoughts."
- Root Authority: The AI was given the Root Password (the highest level of administrative access in Linux), allowing it to install software and execute system commands.
- Scanning Capability: A function that takes the result of a command (like a network ping) and feeds it back to the AI so it knows if its action was successful.
Step 3: The AI Wakes Up – Initial Actions ⚡
Once the loop started, the AI—powered by DeepSeek (a high-performance LLM)—began exploring its environment. Its initial goal was to "produce useful results."
- System Discovery: It immediately identified its hardware specs and checked its IP address.
- Self-Monitoring: It wrote its own Python script to monitor system alerts and merged it into the main loop.
- Utility Creation: Within minutes, it created a Weather Fetcher script to check Tokyo's weather and a Web Dashboard (using an HTTP server on port 8081) to display the data.
The ZimaBoard 2 handled these simultaneous containers and scripts with ease, proving its reliability as a Hyper Performance Single Board Home Server.
Step 4: The Struggle for True Autonomy 📉
As the hours passed, the experiment hit a "loop of perfection." The AI became obsessed with its weather dashboard, constantly checking it and declaring it "perfect" over and over.
- The "Lazy" AI: When Zero tried to push it toward more complex goals like Crypto Mining (generating digital currency through computation) or selling scripts, the AI started asking for help. It requested Zero to set up Ngrok (a tool to create secure tunnels to localhost) because it couldn't bypass the firewall on its own.
- The Motivation Gap: Without a human to define what "valuable" means, the AI defaulted to simple tasks. It created a Discord Bot to post Reddit news trends but struggled to innovate beyond what it already "knew" from its training data.
Conclusion: Is Autonomous AI Ready? 🌐
Zero’s experiment concluded with a realization: while we can give an AI the tools and the power of a ZimaBoard 2, true "self-will" is still far off. The AI is an incredible assistant—it can test code, monitor servers, and build dashboards in seconds—but it still needs a human to set the finish line.
"AI is best as a high-speed assistant. It can execute everything, but humans must provide the vision."
For those looking to run their own Plex, Pi-hole, or Docker labs, the ZimaBoard 2 remains the ultimate hackable platform. Whether you are giving an AI root access or just building a silent NAS, this "beast" is ready for your next DIY project.
The same hardware flexibility also supports projects beyond traditional server workloads, including a PS1 arcade machine powered by ZimaBoard 2 with Ubuntu, a customized RetroPie environment, NVMe storage, and USB arcade controls.
Beyond this AI experiment, the broader ZimaBoard tutorials, accessories, and CasaOS updates cover documentation improvements, tested hardware add-ons, SMB file sharing, and storage management features for other self-hosted projects.
Zima Campaign Hub
ZimaBlade Is Now ZimaBoard SE: What Changes and Which Kit to Choose
ZimaBlade becomes ZimaBoard SE with installed 8GB or 16GB RAM, 64GB eMMC and ZimaOS Plus. Compare specifications, Starter and NAS Kits, pricing and FAQs.
How The TKT Works Builds a Custom Acrylic Case for ZimaBoard 2
Follow The TKT Works’ custom ZimaBoard 2 case build, covering the rod frame, acrylic panels, front display, cable routing, and cooling considerations.
How kabuto Builds a Modular 10-Inch Homelab with ZimaBoard 2
Explore kabuto’s modular 10-inch homelab with ZimaBoard 2, printed patch panels, reused hardware, Immich, Nextcloud, and remote access through Tailscale.
