Best 5 Mini PCs for Home Server & Media Labs (2026)
Choosing the best mini PC for a home server in 2026 is different from choosing a small desktop PC. A good home server is not only about CPU benchmark scores. It needs to run quietly, stay online 24/7, support reliable storage, handle Docker apps, and give you enough networking headroom for NAS, Jellyfin, Plex, Home Assistant, Pi-hole, backups, and remote access.
This updated guide focuses on mini PCs and compact single-board servers that make sense for home server, homelab, and private cloud use. Some options are better for NAS storage, some are better for Windows desktop workloads, and some are better if you want a budget self-hosting box that can run Docker containers without taking over your desk.
Best Mini PC for Home Server in 2026: Quick Verdict
If you want the simplest answer, the best mini PC for a home server depends on what you plan to run. A NAS-focused user should care about SATA, PCIe, network ports, and idle power. A homelab user should care about RAM, virtualization support, Linux compatibility, and expansion. A media-server user should care about storage, hardware decoding, noise, and network stability.
Use Case Best Fit Why It Works
Best overall home server mini PC ZimaBoard 2 Built around home server use with dual 2.5GbE, SATA, PCIe expansion, passive cooling, and ZimaOS support.
Best budget mini PC for home server ZimaBoard SE Good entry point for Docker apps, lightweight NAS, media server testing, and personal cloud projects.
Best traditional mini PC ASUS ExpertCenter PN Series Better when you need a compact Windows or Linux desktop that can also run server workloads.
Best maker board option Raspberry Pi 4B / Raspberry Pi 5 Strong for learning, GPIO projects, lightweight services, and community tutorials.
Best cheap experiment box Beelink GK Mini / N-series mini PCs Useful for basic services, low-cost testing, and simple 24/7 tasks if storage and thermals are checked carefully.
What Makes a Mini PC Good for a Home Server?
A home server mini PC should be judged differently from a normal office mini PC. For an always-on server, the most important question is not “Can it open many browser tabs?” but “Can it run quietly and reliably for months while serving files, containers, media, and network services?”
CPU and idle power matter more than peak benchmark scores
For Docker, file sharing, Jellyfin, Plex, Home Assistant, Pi-hole, and backup tasks, modern low-power processors are often enough. The more important factor is whether the device can stay efficient at idle, because a home server spends most of its time waiting for requests.
This is why newer low-power chips such as the Intel N150 low-power processor specs matter for home server buyers. Intel lists the N150 as a 4-core, 4-thread processor with up to 3.6GHz turbo frequency and a 6W processor base power, which makes it a strong fit for small always-on systems.
2.5GbE, SATA, and PCIe matter for NAS use
If you want your mini PC to work as a NAS, storage and networking matter as much as the CPU. A single microSD card or one internal M.2 slot may be fine for learning, but it becomes limiting when you want larger media libraries, local backups, or multi-device file sharing.
For NAS and private cloud use, look for native SATA, reliable external storage options, 2.5GbE networking, and preferably PCIe expansion. These features give the server a longer useful life than a compact desktop with only USB storage.
RAM and storage expansion decide Docker and VM headroom
Docker containers are lightweight, but several apps together can still consume memory quickly. A small home server running Jellyfin, Immich, Home Assistant, Pi-hole, Syncthing, and a dashboard can feel very different from a single-purpose media box.
For a basic home server, 8GB RAM is a practical starting point. For a homelab with virtual machines, databases, or heavier self-hosted services, 16GB or more gives you more room to experiment.
OS support matters for Proxmox, Linux, CasaOS, TrueNAS, and pfSense
A mini PC for home server use should support the operating system you actually want to run. Windows can work for some users, but many home server setups depend on Linux, Docker, CasaOS, ZimaOS, Proxmox, TrueNAS, OpenWrt, or pfSense.
Compare Plans
ZimaOS
FREE
  • Core features
  • Zima Client for Mobile & PC
  • Thunderbolt Support
  • Developer Mode
  • 4 Disks
  • 3 Members
Download Now
ZimaOS+
$29Lifetime License
Effortless expansion
  • Everything in Free
  • Unlimited Disks
  • Unlimited Users
Buy Now
Before buying, check whether the hardware has stable network drivers, storage support, and BIOS options. This is especially important if you plan to use the device as a router, firewall, NAS, or virtualization node.
Best Overall: ZimaBoard 2 for NAS, Docker, and Always-On Home Server Use
The ZimaBoard family has always been different from a typical office mini PC. Instead of focusing only on desktop performance, it is designed around server-like use cases: storage expansion, networking, Docker apps, NAS projects, and private cloud workloads.
ZimaBoard home server mini PC
Why it fits home server workloads
For users searching for the best mini PC for home server in 2026, ZimaBoard 2 home server hardware is a strong fit because it is built for always-on services rather than occasional desktop use. Its focus on dual 2.5GbE networking, SATA storage, PCIe expansion, and a compact fanless design makes it especially relevant for NAS, Docker, and lightweight homelab projects.
That hardware layout matters. A normal mini PC may have a faster CPU on paper, but if it only gives you one Ethernet port and limited storage expansion, it can become awkward as a NAS. ZimaBoard 2 is more purpose-built for people who want to run local services at home without building a full tower server.
Where it is better than a normal office mini PC
ZimaBoard 2 is better when your goal is to build a personal server instead of a second desktop. It is a good match for file sharing, Docker containers, local backup, media libraries, private cloud apps, network services, and small self-hosted tools.
A third-party ZimaBoard 2 mini NAS review also positions it around homelab, DIY NAS, Docker, single-VM, and low-power server use. That is the same search intent behind many “ZimaBoard alternative” and “best mini PC for home server” queries.
Where a larger mini PC may still be better
ZimaBoard 2 is not the right choice for every user. If you need a Windows desktop replacement, heavy video editing, high-end gaming, or multiple large virtual machines, a larger mini PC with a stronger CPU, more RAM capacity, and active cooling may be a better option.
But for a quiet 24/7 home server, the balance is different. Storage access, networking, power use, and service reliability often matter more than peak desktop performance.
Best Budget Home Server: ZimaBoard SE for Entry-Level Self-Hosting
ZimaBoard SE is a better fit for users who want to start self-hosting without spending too much. It is not meant to replace a full NAS or a high-end mini PC, but it works well as a budget home server for lightweight services.
ZimaBoard SE budget home server mini PC
Good fit for Docker apps and lightweight NAS
ZimaBoard SE is a good choice if your first home server projects include Docker apps, a small media library, file sync, Pi-hole, Home Assistant, a personal dashboard, or a lightweight web server. It gives beginners a more server-oriented path than a generic mini PC while staying more affordable than a larger NAS.
For users searching for the best budget mini PC for home server in 2026, the key advantage is not just price. It is the combination of compact size, server-friendly design, and enough flexibility to experiment with real self-hosted apps.
Limits to know before using it as a main server
The main limitation is scale. If you expect to run many containers, transcode multiple media streams, host large databases, or build a serious virtualization lab, ZimaBoard SE may become a stepping stone rather than your final server.
That does not make it a bad pick. It simply means ZimaBoard SE works best as an entry-level self-hosting box, a learning server, or a compact device for a focused set of services.
Best General-Purpose Mini PC: ASUS ExpertCenter PN Series
A traditional mini PC such as the ASUS ExpertCenter PN Series is useful when you need one machine to cover both desktop and server tasks. It is not as storage-focused as ZimaBoard 2, but it can be a strong choice for users who want a compact Windows or Linux computer with more conventional PC hardware.
The original list included the Asus ExpertCenter PN52, and that category still makes sense for users who want a polished mini PC from a major brand.
ASUS ExpertCenter PN52 mini PC
When a traditional mini PC is better than a single-board server
Choose a traditional mini PC if you need stronger desktop performance, Windows compatibility, office workloads, browser-heavy tasks, or occasional creative work. A standard mini PC can also run Docker, media servers, and network services, especially if you install Linux or a virtualization platform.
This category is also useful for users who want a home server that can double as a small workstation. For example, you may want to run a few containers in the background while still using the machine for browsing, office work, or media playback.
Why storage and networking may need extra planning
The trade-off is that many office-oriented mini PCs are not designed around NAS expansion. They may have one Ethernet port, limited internal drive bays, and fewer options for direct SATA storage.
If you choose this route, check whether the model supports enough RAM, whether it can boot your preferred OS, and whether you can add reliable storage without depending only on USB drives.
Best Maker Board Option: Raspberry Pi 4B and Raspberry Pi 5
Raspberry Pi remains one of the strongest choices for learning, GPIO projects, lightweight Linux services, and community-driven tutorials. It is easy to find guides, accessories, cases, hats, and project examples, which makes it friendly for beginners and makers.
The original article included the Raspberry Pi 4B, and it is still useful for many lightweight projects. However, buyers comparing options in 2026 should also consider the newer Raspberry Pi 5 performance baseline, which Raspberry Pi describes as using a 2.4GHz quad-core Arm Cortex-A76 processor and offering up to three times the performance of the previous generation.
Raspberry Pi 4B mini PC board
Good for learning, lightweight services, and GPIO projects
Raspberry Pi is still excellent for learning Linux, running small services, building sensors, experimenting with GPIO, and following community tutorials. It is also a good fit for Pi-hole, simple dashboards, lightweight web apps, and basic automation projects.
If your goal is education, maker projects, or a small always-on service, Raspberry Pi is one of the easiest platforms to start with because the ecosystem is so large.
Why it is not always the best NAS or Plex server choice
For NAS and media-server use, Raspberry Pi has trade-offs. Storage expansion often depends on USB or add-on boards, and network/storage layout can be less convenient than a device designed for server storage from the start.
That does not mean Raspberry Pi is bad for home server use. It means it is best for lightweight services and maker workloads, while ZimaBoard 2 or a purpose-built mini server is usually a cleaner fit for NAS, Docker stacks, and long-term storage-heavy use.
Best Cheap Windows Mini PC: Beelink GK Mini and N-Series Mini PCs
Cheap mini PCs remain popular because they are easy to buy, small, and often powerful enough for simple server tasks. Devices like the Beelink GK Mini category can work well for users who want a low-cost experiment box, a basic Windows mini PC, or a simple Linux server.
Beelink GK Mini PC
Good for basic services and low-cost experiments
A low-cost mini PC can run basic services such as Pi-hole, lightweight Docker containers, file sync, Home Assistant, a test web server, or a small media server. For users who are still learning, this can be an affordable way to test whether self-hosting fits their daily routine.
Cheap mini PCs are also useful as secondary nodes in a homelab. You can use one for testing Linux distributions, learning Docker Compose, or running a small monitoring stack.
What to check before using one as a 24/7 home server
Before using a budget mini PC as a 24/7 server, check cooling, BIOS stability, idle power, network chip support, and storage options. Some very cheap mini PCs look attractive on paper but are less ideal for long-term always-on use.
If the device has only one network port and limited internal storage, it may still be useful, but it will not be as clean for NAS or router-style workloads as a server-focused board.
ZimaBoard Alternative: When Should You Choose a Regular Mini PC Instead?
Many users search for a ZimaBoard alternative because they are comparing two different categories: compact office mini PCs and single-board servers. Both can run Linux and Docker, but they are optimized for different priorities.
Choose a regular mini PC for Windows desktop workloads
Choose a regular mini PC if you want Windows, office work, browser-heavy use, video conferencing, light editing, or a machine that can act like a normal desktop most of the time. A traditional mini PC can still run server apps, but its design often starts from desktop use.
Choose ZimaBoard 2 for native storage, networking, and silent server use
Choose ZimaBoard 2 if your priority is a quiet always-on personal server with native server-style features. Dual LAN, SATA, PCIe, compact design, and ZimaOS make it easier to think in terms of NAS, Docker, home cloud, and network services.
In other words, the best ZimaBoard alternative is not always the fastest mini PC. It is the device that gives you the storage, network, OS, and expansion path your home server actually needs.
Choose a bigger NAS if you need multiple hot-swap drive bays
If your main goal is a large storage array with multiple hot-swap drives, RAID management, and a more appliance-like NAS experience, then a larger NAS may be better than either ZimaBoard 2 or a generic mini PC.
A compact home server is best when you want flexibility. A full NAS is better when storage capacity, drive management, and long-term file protection are the primary goals.
Mini PC Home Server Comparison Table
Device Category Best For Main Strength Main Limitation
ZimaBoard 2 NAS, Docker, home cloud, low-power homelab Server-focused storage, networking, and expansion Not a high-end desktop replacement
ZimaBoard SE Budget self-hosting and lightweight Docker apps Affordable entry into personal server projects Limited headroom for heavier workloads
ASUS ExpertCenter PN Series Desktop plus server mixed use Stronger general-purpose PC experience Storage and networking may need planning
Raspberry Pi 4B / Raspberry Pi 5 Learning, GPIO, lightweight services, maker projects Huge ecosystem and community support Less ideal for storage-heavy NAS use
Beelink GK Mini / N-series mini PCs Cheap experiments and basic services Low price and easy availability Thermals, storage, and network support vary by model
Which Mini PC Should You Buy for NAS, Docker, Plex, or Homelab?
Choose a device with real storage expansion, stable networking, and an OS path that supports file sharing and backup tools. ZimaBoard 2 is the cleanest fit in this list because it is designed around storage and server use rather than general desktop use.
For Docker and self-hosted apps
For Docker apps, prioritize RAM, stable Linux support, and enough storage for app data. ZimaBoard 2 is better for a longer-term Docker server, while ZimaBoard SE is a better first step for lightweight self-hosting.
For Plex or Jellyfin media server
For Plex or Jellyfin, check storage capacity, network speed, and whether the system can handle your media format. If you only stream inside the home, networking and storage may matter more than raw CPU speed. If you need transcoding, check hardware decoding support carefully before buying.
For homelab and virtualization
For Proxmox, VMs, and heavier lab work, RAM and CPU headroom become more important. A larger mini PC may be better if you plan to run several virtual machines, but ZimaBoard 2 still works well for lightweight homelab tasks, Docker stacks, and single-VM experiments.
Final Verdict: Best Mini PC for Home Server in 2026
The best mini PC for home server use in 2026 is the one that matches your workload. For most users building a NAS, Docker host, personal cloud, or quiet always-on server, ZimaBoard 2 is the strongest overall fit because its hardware layout is designed around home server needs.
ZimaBoard SE is the better budget choice if you want to start small. ASUS ExpertCenter PN Series is better if you need a normal mini PC that can also run server workloads. Raspberry Pi is still excellent for learning and maker projects. Beelink-style mini PCs are useful for cheap experiments, but you should check storage, thermals, and network support before relying on one as your main server.
If your goal is a true 24/7 home server, do not buy only by CPU score. Look at networking, storage, power, OS support, and expansion. Those are the details that decide whether a mini PC feels reliable after the first week of setup.
What is the best mini PC for home server in 2026?
For NAS, Docker, media server, and home cloud use, ZimaBoard 2 is the best overall choice in this list because it is designed around server-style storage, networking, and expansion. A traditional mini PC may be better if you also need a Windows desktop.
What is the best budget mini PC for home server?
ZimaBoard SE is a strong budget option for users who want to run lightweight Docker apps, file sharing, Home Assistant, Pi-hole, or a small personal cloud. It is best for entry-level self-hosting rather than heavy virtualization.
Is a mini PC good for NAS?
Yes, a mini PC can be good for NAS if it has reliable storage expansion, stable networking, and low-power operation. A server-focused board with SATA, PCIe, and dual LAN is usually better for NAS than a generic mini PC with only USB storage.
Is ZimaBoard 2 a mini PC or a single-board server?
ZimaBoard 2 is closer to a single-board server than a normal mini PC. It can perform many mini PC tasks, but its hardware design is more focused on NAS, Docker, networking, and always-on home server use.
What is a good ZimaBoard alternative?
A good ZimaBoard alternative depends on why you want an alternative. Choose a traditional mini PC if you need Windows desktop performance. Choose Raspberry Pi if you want GPIO and maker projects. Choose a larger NAS if your main goal is multi-drive storage. Choose ZimaBoard 2 if you want a compact, quiet, server-first device.
Zima Campaign Hub
