Thank you to u/Intelligent-Air-9143, who also writes as Dima Anfimov, for sharing the first month with a ZimaBoard 2. What began with DNS filtering and a home media library became something more specific: a remote build machine for a small VPS that sometimes stopped responding during Docker builds.
The original Reddit account and the creator’s illustrated write-up describe the same progression. Tailscale supplied connectivity between home and the VPS, while a resource-allocated ZVM guest provided a place for Dokploy builds. The story is useful because the eventual purpose emerged from an existing problem rather than a finished shopping list.
A First Server Acquired Jobs One at a Time
Dima wanted to experiment with small hardware but found the initial barrier to a Raspberry Pi project uninviting. The chosen starting point was a ZimaBoard 2. Assembly itself became part of the introduction: opening the new machine and connecting its small fan made the server a physical project before any applications were installed.
Within the first month, the board had gained an HDD intended for backups, an SSD for frequently used storage, and a smart home base station nearby. Dima describes the SSD as holding media and VM storage, with another HDD still awaited. The account does not identify the board’s memory variant, every disk capacity, or a completed multi-disk backup arrangement.
| Part of the setup | Role reported by the creator |
| ZimaBoard 2 with ZimaOS | Home applications and a ZVM guest for build work |
| Attached HDD | Backup storage; another HDD was still expected |
| Attached SSD | Frequently accessed media and VM storage |
| Hetzner VPS | Side projects on 2 vCPUs and 4 GB RAM |
| Tailscale and Dokploy | Private connectivity and remote application builds |
The equipment list describes a developing installation. It is not a minimum specification for Docker builds or a promise that every software project will fit within the same resources. Build size, dependencies, cache growth and concurrency all belong to the workload that a reader would need to test.
DNS Filtering Introduced a Real Troubleshooting Lesson
Pi-hole and AdGuard Home were among the first experiments. Dima preferred AdGuard Home’s interface and kept it running. The appeal was household-wide filtering for devices whose users did not necessarily install browser extensions.
The difficulty appeared when blocklists affected wanted services. Google services and a work Grafana instance became inaccessible during the experiments, and the creator spent hours investigating before checking the DNS blocker. The useful lesson is the order of investigation: when several otherwise unrelated destinations fail after a filtering change, name resolution belongs near the beginning of the diagnosis.
A DNS blocker works at the hostname level. As the Pi-hole documentation explains, its role is a DNS sinkhole. It cannot selectively remove every advertisement delivered from the same hostname as wanted content. This distinction keeps the household benefit understandable without turning one person’s good experience into an all-advertising guarantee.
The related Pi-hole-to-family-server story follows another service collection that grew beyond an initial networking task. Here, the memorable detail is the time lost looking elsewhere when a shared DNS dependency was responsible.
A Media Library Made Storage Paths Matter
Plex and Transmission supplied another early use. Dima configured the download location to match the media location watched by Plex, reducing the need to move files through a work computer before they appeared in the library. The practical improvement was a consistent destination for files and a media service that knew where to look.
The source also describes a conflict between downloading and the DNS-filtering setup. It does not provide enough reproducible configuration to establish a general repair, so the account is best read as an unresolved interaction rather than a networking recipe. A reader investigating a similar symptom would need to distinguish DNS resolution, container networking and application settings.
Plex did not become the creator’s default for every viewing session. It was most useful when planning a longer collection in advance. That detail matters: a successful installation can still have a limited, well-defined role. The useful server is the one whose workflow fits its household, rather than the one with the largest application count.
A Small VPS Supplied the Strongest Reason for the Board
Dima already used a Hetzner VPS for side projects, including syncing Obsidian notes. Its 2 vCPUs and 4 GB RAM became a constraint during Docker image builds. The creator reports builds sometimes exhausting resources until the VPS stopped responding to requests.
The proposed change was to use the ZimaBoard’s resources for that temporary work. This separates a burst of compilation and image construction from the machine serving existing applications. It does not require claiming that the home board is faster than every VPS configuration; the relevant problem was contention on this particular small server.
According to Dokploy’s build-server documentation, a build server prepares an application image separately and makes it available through a registry for deployment. The current documentation distinguishes this feature from Docker Compose deployments. It supplies the product’s configuration reference; Dima’s post supplies the personal reason for adopting it.
Tailscale and ZVM Addressed Different Boundaries
Moving builds home introduced two questions: how the VPS would reach the machine, and how much of the home server a build could occupy. Dima used Tailscale for the first and a ZVM guest with assigned resources for the second.
The Tailscale tailnet overview explains the private network joining participating devices. In this build, it gave the VPS and home machine a way to communicate without making the build service an ordinary public endpoint. Authentication and access policy still matter; simply connecting two devices is not a complete access review.
ZVM supplied a guest environment with a defined resource allocation. That creates an operational boundary for the build tools, while the guest and household applications still share the physical board, its storage and network connection. The creator reports reaching a working Dokploy build-server result; no controlled build-time comparison or concurrent-load benchmark accompanies it.
For another hardware arrangement, the small homelab from u/jc-21 shows how clearly assigned machine roles can make a service collection easier to explain. Readers evaluating this story’s actual platform can find the ZimaBoard 2 hardware details without assuming the creator used a particular memory SKU.
What made this more than a first media-server experiment?
The home board became a Dokploy build server for a resource-constrained VPS. DNS filtering and media applications came first, but the existing VPS problem gave the hardware a distinct development role.
Were public services already moved onto the home board?
No. Using the VPS as a public-facing proxy for services at home was described as a future experiment. The completed result reported here is the remote build-server arrangement.
Does a ZVM guest remove every shared-resource concern?
No. Assigned guest resources help define the workload’s allocation, but the underlying board, storage and network remain shared. The source gives no guarantee about every combination of household services and builds.
Which original images are included?
The early assembly photograph, expanded hardware photograph and ZimaOS dashboard come from the creator’s contribution. The unrelated cat photographs and entertainment screenshots were not needed to explain the server’s role.
Conclusion
Dima’s first month progressed from trying familiar self-hosted applications to solving an existing infrastructure problem. DNS filtering exposed a dependency worth checking, media applications made file locations concrete, and Docker builds gave the ZimaBoard 2 a job alongside the VPS.
The strongest part of the account is that progression. A small home machine became useful because its owner could connect a real bottleneck to a separate place for work, while leaving the next public-hosting experiment clearly in the future.
Zima Campaign Hub
A ZimaBlade TrueNAS Storage Host in a Shelf-Sized Apartment Homelab
An apartment homelab puts ZimaBlade TrueNAS storage beside a Raspberry Pi, Mac mini and automated fans, with two 14 TB disks and a separate...
From Rack Servers to a Living-Room ZimaCube 2 Homelab
A ZimaCube 2 Pioneer participant consolidates containers, GitHub Actions runners and mixed storage beside the TV, with an owner-reported UPS test.
A ZimaBoard SE NAS with an RTX 3060 and USB Database Storage
A ZimaBoard SE owner combines an RTX 3060, hard drives and USB database storage for Immich and Plex after a replacement-unit experience.
