Docker lets you use a homelab as a repeatable application platform by defining each service, port, network, and persistent data path before deployment.
On a NAS or home server, that means you can run DNS filtering, monitoring, media, file sync, dashboards, and other self-hosted apps without installing every dependency directly on the host. The practical goal is not simply to start a container once. It is to build a stack that survives reboots, keeps its data through updates, stays reachable only where intended, and can be restored when something goes wrong.
What Docker Does in a Homelab
Docker packages an application and its runtime dependencies into an image, then starts that image as a container. The host still provides the CPU, memory, storage, and network, but each service gets a defined environment that is easier to reproduce than a long list of manual installation steps.
Five concepts explain most of the Docker configuration you will use in a homelab:
| Docker concept | What it means | Why it matters at home |
| Image | The packaged template used to create a service | You can download the same application version again after a rebuild |
| Container | A running instance of an image | You can stop, replace, or recreate the app without reinstalling the host |
| Port | The host and container endpoints used to reach a service | You decide whether an app is available locally, across the LAN, or remotely |
| Volume or bind mount | Storage kept outside the disposable container layer | Configs, databases, and account data survive updates |
| Network | A communication boundary for related containers | Apps can reach one another by service name without publishing every port |
A container should be treated as replaceable. Your Compose file, environment settings, and persistent data are the parts that make the service recoverable.
What You Need Before Installing Docker
Start by deciding where Docker will run. A NAS operating system may provide a visual app manager, while a standard Linux home server usually uses Docker Engine and the Compose plugin from the command line. A virtual machine can also work when you want Docker separated from the base hypervisor.
| Host type | Recommended workflow | Main thing to verify |
| NAS with a Docker app manager | Use the GUI, but document ports, mounts, and environment values | You can locate and back up the app data outside the container |
| Linux home server | Docker Engine plus Docker Compose | The Docker service starts automatically after a reboot |
| Virtual machine | Install Docker inside a dedicated Linux VM | The VM has stable storage, networking, and enough reserved memory |
- Confirm whether the host uses amd64 or arm64 so you choose compatible images.
- Reserve a stable LAN address through DHCP reservation or a static IP.
- Create one persistent location for container configs and databases, separate from large media shares.
- Choose either Compose projects or a visual manager as the primary workflow instead of mixing undocumented methods.
- Decide which services will remain LAN-only and which may eventually need remote access.
- Choose a second storage destination for backups of Compose files and persistent data.
When the host itself is still being planned, the guide on how to build a home server can help establish the storage, network, and operating-system foundation before Docker is added.
Install Docker and Verify the Host
The installation method depends on the operating system, but the validation sequence should remain consistent. Some NAS platforms bundle Docker behind an app interface. A Linux host normally requires Docker Engine and the Compose plugin, while Windows and macOS are better suited to learning or testing than to a permanently running NAS service.
A beginner-friendly Docker homelab setup shows the useful sequence of installing Docker, running a first container, organizing project folders, and moving repeatable services into Compose. Use that sequence as a framework, then follow the installation method required by your own NAS or Linux distribution.
Check Docker and Compose
After installation, open a terminal on the host and confirm that both Docker and Compose respond:
docker --version
docker compose version
If either command is missing, stop here and fix the installation before creating application folders. On Linux, also confirm that the Docker service starts automatically and that the account used for management is protected. Access to the Docker daemon is effectively administrative access to the host.
Run a Disposable Validation Container
Use a temporary container to confirm that the daemon can download an image and start it:
docker run --rm hello-world
A successful result confirms the basic path from the command-line client to the Docker daemon and image registry. The --rm option removes this test container after it exits, so it does not become part of your permanent stack.
Confirm the Basic Admin Commands
docker ps
docker ps -a
docker images
docker ps shows running containers, docker ps -a includes stopped containers, and docker images shows images stored on the host. These three views are often enough to tell whether a problem is caused by a container that stopped, an image that was never downloaded, or a service that was never created.
Deploy Your First Docker Compose Stack
One-off docker run commands are useful for tests, but Compose is easier to repeat, review, back up, and migrate. Each project gets its own directory and a compose.yaml file that records the image, ports, storage, restart behavior, and network.
Create a Project Directory
The following example creates a small Nginx start page. It is intentionally simple, but it tests the same workflow you will use for a dashboard, media server, monitoring tool, or personal cloud:
mkdir -p ~/docker/start-page/site
cd ~/docker/start-page
printf '<h1>Docker homelab is running</h1>\n' > site/index.html
Keeping every service in a separate folder makes it easier to identify its Compose file, environment values, and persistent data. A larger NAS can use a path such as /docker/start-page or a dedicated shared folder instead of the home directory.
Create the Compose File
Create a file named compose.yaml in the project directory:
services:
start-page:
image: nginx:alpine
container_name: homelab-start-page
ports:
- "8080:80"
volumes:
- ./site:/usr/share/nginx/html:ro
restart: unless-stopped
networks:
- homelab
networks:
homelab:
driver: bridge
The port mapping sends requests from port 8080 on the NAS to port 80 inside the container. The bind mount makes the local site directory available inside Nginx as read-only content. The restart policy brings the service back after a normal reboot unless you intentionally stopped it.
This example publishes port 8080 on the host. Keep router port forwarding disabled during testing. When the service should only be reachable from the Docker host itself, bind it to loopback with 127.0.0.1:8080:80 instead.
Start and Verify the Service
docker compose up -d
docker compose ps
docker compose logs --tail=100
Open http://NAS-IP:8080 from a device on the same network. The page should display “Docker homelab is running.” Then reboot the host once and confirm that the container returns automatically.
The commands you will use most often are:
| Task | Command |
| Create or apply changes | docker compose up -d |
| Check service state | docker compose ps |
| Follow logs | docker compose logs -f |
| Restart the stack | docker compose restart |
| Stop and remove containers | docker compose down |
| Download newer images | docker compose pull |
Avoid adding -v to docker compose down unless you intentionally want to remove Compose-managed volumes. Removing the container is routine; removing persistent data is not.
If your NAS operating system provides a visual Docker app manager, the same fields still matter. The interface should make the image, host ports, container ports, mounted paths, environment variables, and restart behavior visible. This NAS operating system workflow is useful when you prefer a GUI but still want predictable app paths.
Store Docker Data Safely on a NAS
Containers are disposable, but service data is not. Most homelab failures after an update come from a database, account file, or application configuration that was saved only inside the container layer. Recreating that container then produces a clean installation instead of restoring the original service.
A bind mount maps a known host file or directory into a container. A volume is managed by Docker under its storage area. Both can preserve data, but they differ in visibility and backup workflow.
| Storage method | Best fit on a NAS | Why it works | Common failure |
| Bind mount | Configs, uploads, and app data you want visible in NAS folders | Easy to inspect and include in normal NAS backups | A wrong path or host permission prevents the app from starting |
| Named volume | Databases and internal service state | Fewer hard-coded host paths and cleaner Compose portability | The volume may be missed by a file-level backup |
Separate Application Data from Bulk Media
Keep configs, databases, thumbnails, indexes, and other small-file workloads on a dedicated docker-data location that is backed up frequently. Large movies, photos, recordings, and downloads can stay on normal media shares. This separation makes the backup scope clearer and can prevent application metadata from competing with large sequential storage workloads.
Before deploying a real application, write down every host path used in its Compose file. A simple layout could look like this:
/docker
/app-name
compose.yaml
.env
/config
/data
Back Up What Recreates the Service
Back up the Compose file, any .env file, certificates, custom configuration, and the persistent container data. Images normally do not need to be backed up because they can be downloaded again. Protect environment files carefully because they may contain passwords, tokens, or database credentials.
The 3-2-1 backup rule provides a useful planning model, but a Docker backup is only complete when you can recreate the stack and restore its data. Test one non-critical restore before your homelab becomes dependent on the service.
When using a visual NAS interface, confirm where its persistent container data is stored instead of assuming the interface automatically protects it.
How Docker Networking Works in a Homelab
Docker networking controls two different paths: communication between containers and access from devices outside Docker. Keeping those paths separate reduces unnecessary port publishing and makes multi-service stacks easier to understand.
Read Port Mappings from Left to Right
In 8080:80, port 8080 belongs to the Docker host and port 80 belongs to the container. Devices on the LAN connect to the NAS address and host port. Docker then forwards the request to the application’s internal port.
Only publish a host port when a browser, phone, TV, or another non-Docker device needs direct access. A database used only by another container usually does not need a published port.
Use Custom Networks for Related Services
Compose can create a user-defined bridge network for each stack. Containers on that network can reach one another by service name, which means a web application can connect to a service named database without relying on a changing container IP address.
A hands-on example of custom Docker networks and container isolation demonstrates how name resolution and connectivity change when containers are placed on separate bridge networks or connected to more than one network.
Group services that genuinely need to communicate. Keep unrelated stacks on separate networks, and do not publish an internal database, cache, or message queue merely to make the containers see one another.
Keep LAN Access Separate from Internet Access
A service reachable at NAS-IP:8080 on your home network is not automatically available from the internet. Public exposure normally requires a router forwarding rule, a tunnel, a VPN, or another remote-access path. Treat that extra step as a separate security decision rather than part of every deployment.
Expose Docker Services Safely
Remote access is where a convenient homelab can become a real security liability. The safer default is to keep application interfaces private on the LAN and expose only a controlled access layer when remote use is necessary.
Use a VPN for Private Remote Access
A private VPN or overlay network lets approved devices reach home services without publishing each application directly. This is often the simplest route for personal dashboards, admin panels, file access, and services used by only a few trusted people. The guide to secure remote access covers the broader home-server decision between VPN-based access and public web exposure.
Use a Reverse Proxy as the Public Entry Point
When a web service must be public, a reverse proxy provides one place for hostnames, certificates, routing rules, and access controls. Expose the proxy rather than forwarding a separate router port to every application. Keep databases, admin interfaces, and internal service ports on private Docker networks whenever possible.
Use HTTPS and Deliberate Port Rules
Any login or session reachable outside the home network should use HTTPS. Review router forwarding rules periodically and remove entries that are no longer required. Certificate automation helps, but it does not replace strong authentication, timely updates, or careful control over which services are public.
Update, Monitor, and Restore the Stack
A Docker homelab stays manageable when maintenance follows a repeatable sequence. Do not update every service blindly at the same time. Start with a backup, update one stack, and verify the paths that matter before moving to the next application.
Use a Controlled Update Sequence
docker compose pull
docker compose ps
For an important service, note the working image tag before an update so you have a rollback reference. After redeployment, test the login, mounted storage, database connection, LAN access, and any reverse-proxy route. An “Up” container state only proves that the process is running; it does not prove that the application is healthy.
Watch the Signals That Drift Quietly
- System-drive usage from old images, writable layers, logs, and abandoned data.
- Container restart counts and repeated errors in application logs.
- Unexpected router forwards or host ports that are no longer required.
- Backup age, backup size, and whether the latest archive can be opened.
- Memory pressure when additional services are added to a small NAS.
Use cleanup commands only after reviewing what they will remove. Unused images consume space, but aggressive pruning can also delete cached layers or unused volumes that still matter to a recovery plan.
Rehearse One Restore
Choose a non-critical service, stop it, move its persistent data aside, and rebuild it from the Compose file. Then restore the data and confirm that accounts, settings, and application state return. A successful restore is stronger evidence than a green backup job.
Common Docker Homelab Problems and Fixes
| Symptom | Check first | Likely direction |
| The browser cannot reach the app |
docker compose ps, port mapping, host firewall, and NAS IP |
Confirm the container is running and the host port is not blocked or already used |
| The container keeps restarting | docker compose logs --tail=100 |
Look for missing environment values, bad paths, database failures, or permission errors |
| Permission denied on a mounted folder | Host ownership, UID/GID, and read-only flags | Match the application user to the directory permissions instead of granting broad access |
| Port is already allocated | Other containers and host processes using that port | Choose a different host port or stop the conflicting service |
| The image will not start | CPU architecture and image platform support | Use an image that publishes the correct amd64 or arm64 build |
| Data disappeared after an update | Volume and bind-mount definitions | Restore the persistent data and move future state outside the container layer |
| Two containers cannot communicate | The networks attached to both services | Place related services on the same user-defined network and connect by service name |
| The NAS system drive is filling up | Images, logs, caches, and unused volumes | Identify the source before pruning and move persistent workloads to the planned data path |
Choose the Next Container for Your Homelab
After the first Compose stack survives a reboot and a small update, add one service that solves a real household need. Each category introduces a different operational lesson:
| Goal | Service category | What it teaches |
| See whether services are available | Uptime monitoring | Health checks, notifications, and persistent configuration |
| Reduce unwanted domains across the network | DNS-based filtering | Stable IP planning, DNS reliability, and LAN-only administration |
| Stream a local media library | Media server | Large bind mounts, permissions, metadata storage, and hardware limits |
| Synchronize files across devices | Personal cloud or peer-to-peer sync | Database persistence, remote access, and restore planning |
A DNS-level filter is useful when the entire household benefits from one network service. For storage workflows, private file synchronization demonstrates why configs and databases must remain outside the disposable container layer. A Plex media server adds media permissions, metadata placement, and possible transcoding requirements.
Do not add several critical services at once. A small stack with documented paths, narrow exposure, and a tested backup is more useful than a crowded dashboard that nobody can reliably rebuild.
FAQs
Can I use Docker on an ARM-based NAS?
Often, yes. The image must publish a build for the NAS architecture. Check the platform offered by the image before deployment, especially for smaller projects that may support amd64 but not arm64. An architecture mismatch can prevent the container from starting even when the Compose file is otherwise correct.
How much RAM does a Docker homelab need?
There is no universal number because a DNS filter, media server, database, and AI service have very different memory profiles. List the services you plan to run, start with a small stack, measure peak usage over several days, and keep headroom for the operating system, filesystem cache, updates, and temporary spikes.
Do I need Docker Compose if my NAS has a GUI?
No. A well-designed GUI can manage a simple homelab, especially when it exposes every path, port, variable, and restart setting. Compose becomes more valuable when you want versioned configuration, easier migration, repeatable recovery, or several related services in one stack.
Should every container have its own network?
Not necessarily. Create networks around application boundaries rather than assigning one network to every individual container. A web app and its database may share one private network, while an unrelated media server uses another. Publish only the ports that non-Docker devices need.
What is the safest way to access Docker services remotely?
For personal access, a personal VPN you run at home can reduce the need to expose several application ports publicly. Public services usually need a reverse proxy, HTTPS, strong authentication, timely updates, and a deliberate decision about what remains private.
How do I know whether a Docker backup is complete?
You should be able to recreate the containers from the Compose file and restore the application state from the saved persistent data. A backup that contains only images or a Compose file without the database and config directories is not enough for most stateful services.
Build a Homelab You Can Recreate
Learning how to use Docker in a homelab is less about collecting containers and more about making each service repeatable. Verify Docker first, keep one Compose project per application, store state outside the container, publish only necessary ports, and test a restore before the service becomes important.
Once the first stack survives a reboot, an update, and a recovery drill, add the next application with the same discipline. That sequence turns a NAS from a place where containers happen to run into a home server you can understand, maintain, and rebuild.
Zima Campaign Hub
How Rez Tech Builds His Own Personal Cloud With ZimaBoard 2
Rez Tech builds a personal cloud with ZimaBoard 2, two local drives, RAID 1, and ZimaOS, then tests file access, 4K HDR media, and...
Silicon Steak Shrinks His Homelab With ZimaBoard 2
Silicon Steak explores whether ZimaBoard 2 can replace a much larger homelab machine, testing storage, media playback, Minecraft, Pi-hole, self-hosted apps, and ZimaOS management.
How Smart Life Builds a Private Cloud with ZimaBoard 2
Smart Life turns ZimaBoard 2 into a home destination for phone photos and videos, showing the hardware build, ZimaOS storage setup, phone connection, and...
