GitHub AI Scan Explained: Security Checks for PHP, Shell, and Docker Projects
GitHub AI Scan adds security findings to eligible pull requests, including changes in PHP, Shell, and Dockerfiles. It can help review code and configuration around self-hosted apps. Its findings are advisory: they do not fail the code-scanning check or become a merge-blocking ruleset requirement.
Use the feature as another review signal for repositories you maintain. It does not inspect every live service on your NAS, patch an installed PHP runtime, or prove that a third-party container is safe. Keep source review connected to supported updates and verification of the running application.
What does GitHub AI Scan check?
AI Scan complements CodeQL with selected language and framework coverage. GitHub documents PR-based analysis rather than a full repository backlog scan. Findings appear in the pull request with an AI label, making them distinguishable from CodeQL results.
For a home-server project, this can be relevant to a deployment script or Dockerfile you actually change. It is not a replacement for checking the vendor status of the base image and packaged application.
Which workflow gaps should I understand?
Expectation Actual boundary to plan around
Check every contribution Fork and Dependabot pull requests are excluded
Block unsafe merges automatically AI Scan findings are advisory
Scan the whole live NAS The feature analyzes qualifying pull requests
Patch all dependencies Vendor and package updates remain separate
Prove a clean result is secure Findings can be incomplete or inaccurate
Treat an absence of findings as limited evidence. A reviewer still needs to consider the actual code path and deployment settings.
Why is this useful after the PHP security event?
The PHP response highlights both application-code risk and runtime maintenance. A pull-request scanner can help with risky code you write; a runtime vulnerability needs the appropriate upstream or downstream update. These are related responsibilities with different evidence.
The software-stack guide and Patch the Planet explanation help locate that boundary. A cleaner repository does not automatically replace an affected binary in production.
How should a maintainer act on a finding?
Read the affected code path, check whether the reported conditions apply, and inspect any suggested change. Keep the correction focused. Test the relevant expected behavior and confirm that a security fix does not remove a required control or break a legitimate use case.
Our advisory and patch verification guide covers the later deployment step. Store recovery files separately from application-writable directories.
What should I configure first?
Verify repository eligibility, code scanning, the effective AI Scan setting, and the responsible billing budget. Organization and enterprise policies can constrain repository settings. Start with one eligible repository before enabling a wider set.
Follow the AI Scan enablement guide. If you already use CodeQL, read the AI Scan versus CodeQL comparison to understand why complementary coverage does not imply identical merge controls.
Does AI Scan block a pull request from merging?
No. Its findings are advisory and cannot enforce merge requirements through rulesets.
Does AI Scan inspect the applications already running on my NAS?
No. It analyzes qualifying pull-request changes in GitHub repositories.
Does it run on fork or Dependabot pull requests?
GitHub documents that those pull requests are excluded.
Can AI Scan replace PHP runtime updates?
No. Update affected packages or application images through the relevant vendor-supported process.
Related reading
Sources
Cover: GitHub AI Scan official announcement image. Image source.
