ZimaBoard 2 Review: Unboxing, PCIe Expansion and Teardown
Thank you to Platima Tinkers for giving ZimaBoard 2 an unusually hands-on review. His April 18, 2026 video starts with the packaging and first boot, then moves through ZimaOS, an update, PCIe storage, old graphics cards, a 10GbE adapter, and a complete teardown. It shows the appeal of an expandable x86 board while keeping the experiments that did not work on camera.
The sample is the higher-memory configuration: Intel N150, 16GB of RAM, and 64GB of eMMC. Platima's findings below belong to that hardware and the software he tests, including a move from ZimaOS 1.5.0 to 1.6.0. The video discloses sponsorship from PCBWay. This article follows the review rather than claiming new measurements, and distinguishes a detected device from a completed performance test.
Watch the original review: Platima Tinkers's ZimaBoard 2 Review: Unboxing, PCIe Expansion and Teardown.
Unboxing: a small board with space for experiments
The aluminum enclosure is compact enough to hold in one hand and forms the passive cooling surface around the board. The unboxing spends time on the connectors and accessories because those determine how the system grows. Dual 2.5GbE ports, SATA connections, and an exposed PCIe interface give the owner several directions beyond installing a single app on the built-in storage.
Platima holding the fanless ZimaBoard 2 during unboxing
The fanless aluminum board is small; the completed storage and expansion assembly needs additional space and support. Video frame at 5:00, courtesy of Platima Tinkers.
The packaging can be reused as a simple holder for the board and two 2.5-inch drives. It is a useful starting arrangement while deciding on a permanent enclosure or shelf. The supplied dual SATA cable brings both drive connections together, avoiding the need to improvise that part of a small SSD build.
Dual SATA cable supplied with ZimaBoard 2
The dual SATA cable is part of the expansion plan. The later attempts with two used SATA SSDs remain unresolved in this review. Video frame at 10:00, courtesy of Platima Tinkers.
The exposed interface does not make the finished system as small as the bare board. An adapter, riser, network card, and external drives occupy additional space and need support. Consider the full assembly before choosing a mounting position. For a more structured example, our Kabuto modular rack project explores how the board can fit into a larger homelab layout.
Check the current ZimaBoard 2 configuration and accessory options when ordering. This review's 16GB/64GB sample is distinct from the earlier 8GB/32GB configuration, and the required expansion hardware depends on the intended project.
First boot and ZimaOS setup
Platima initially connects a display and finds a console-style boot screen rather than treating the board as a conventional desktop. After attaching Ethernet, he uses the displayed network address to open the setup interface from another computer. Account creation, the dashboard, client integration, and the app catalog are the important parts of the first-use experience.
He finds the interface approachable and the app selection broad. The catalog includes services for media, photos, home automation, databases, file access, and monitoring. The advantage is a straightforward starting point for hosting services without assembling every management component individually. Browsing the catalog, however, is not a test of every listed application.
ZimaOS application catalog in Platima Tinkers review
The app catalog offers a quick starting point for services. Browsing the available tiles does not validate every application. Video frame at 17:00, courtesy of Platima Tinkers.
The update experience is less immediate. The sample begins on ZimaOS 1.5.0, and Platima wants to move to the newly available 1.6.0 release. He does not immediately find the expected update prompt, consults the project information and documentation, and completes a manual update before proceeding. The video's later tests therefore need their software version attached.
Use the current ZimaOS documentation for today's installation and update process. The review's CasaOS comparisons describe familiar interface ideas; they should not be read as proof that every CasaOS command or operating-system assumption applies unchanged to ZimaOS.
Read the published Geekbench results with their versions attached
Platima links two public CPU benchmark records for the N150 review system. Both list ZimaOS 1.6.0 and approximately 15.37GB of reported memory, consistent with the 16GB configuration. They are useful reference points for this particular machine and run, rather than a promise of identical results under every cooling arrangement or background workload.
Published benchmark Single-core Multi-core Recorded software
Geekbench 5.5.1 for Linux 1,090 3,020 ZimaOS 1.6.0
Geekbench 6.7.0 for Linux AVX2 1,275 3,293 ZimaOS 1.6.0
Compare Geekbench 5 scores with other Geekbench 5 results and Geekbench 6 with version 6. The two scoring systems are not a before-and-after performance percentage. Neither record measures NAS transfer speed, GPU performance, or how a collection of always-on services responds under simultaneous load.
PCIe experiments: NVMe works, the old GPUs do not
The expansion segment starts with a graphics card and immediately exposes a physical constraint: the card does not fit comfortably straight against the enclosure, so Platima uses an extension. This is a reminder to check clearance as well as connector dimensions. A slot that accepts an electrical adapter still needs a workable mechanical arrangement.
His old NVIDIA card is detected, but its required legacy driver is not available in the tested setup. The read-only system arrangement makes that experiment less straightforward than a typical mutable desktop Linux installation. A second, old AMD card also fails to produce a working result. The video does not establish a universal GPU incompatibility, but it certainly does not show these two cards working successfully.
The NVMe adapter fares better. A drive is detected and made available through the storage interface. Platima creates usable storage and explores the available pool options. With only one drive selected, multi-drive RAID choices are naturally unavailable. This is a successful storage-recognition and setup demonstration, not a measured NVMe throughput benchmark.
NVMe adapter and SSD connected through the ZimaBoard 2 PCIe riser
The PCIe NVMe adapter and drive are recognized and made usable through the storage interface; this segment does not measure SSD throughput. Video frame at 30:00, courtesy of Platima Tinkers.
Check the adapter's controller, lane requirements, power needs, and operating-system support before choosing a card. Multiple M.2 sockets do not by themselves establish that every socket works with every host configuration. For a successful but very different graphics experiment, our RTX 3050 build review follows a complete assembly with its own power, cooling, and software requirements.
The SATA test remains unresolved in this video
Platima then connects two used SATA SSDs. The expected additional disks do not appear, and rebooting with the drives connected produces a long wait at the boot screen. He tries the drives separately and together and also removes the PCIe storage adapter during troubleshooting. The system eventually boots, but the SATA drives still are not recognized in the demonstrated attempts.
He considers several possible causes, including the drives' previous contents, firmware behavior, or an interface issue, and says he will ask his contact about the result. The video does not settle the cause. It would therefore be inaccurate either to call this a successful three-drive RAID build or to diagnose a proven defect affecting all ZimaBoard 2 units.
For a new setup, confirm the intended drives and cable with a small test before transferring important data. Check recognition after a full shutdown and boot, then test the resulting pool and a file copy. Keep a troubleshooting observation separate from a confirmed explanation. Michael Klements' early ZimaBoard 2 review shows a different sample successfully using two SATA SSDs, with different test conditions and software context.
10GbE recognition adds flexibility without a line-rate claim
The networking experiment uses a dual-port X520-class 10GbE card connected through the expansion arrangement. The board boots and ZimaOS shows four Ethernet interfaces: the two onboard 2.5GbE ports and the two ports from the add-in card. Platima is pleased that the adapter is recognized without the driver work encountered during the graphics experiment.
10GbE network adapter attached to ZimaBoard 2 for testing
The dual-port 10GbE card is recognized alongside the onboard ports. Platima does not run an iperf throughput test. Video frame at 36:20, courtesy of Platima Tinkers.
He explicitly does not run an iperf throughput test. Interface detection and a displayed 10GbE link therefore should not become a claim of sustained 10Gb/s file copies. The card, riser, negotiated PCIe connection, client, and storage path all affect attainable throughput. A second port is also not automatically twice the speed for one transfer.
Platima would like a more direct bridge-mode workflow in the interface, but does not complete a bridge or routing-performance test. His ideas for using the board in network projects are possibilities to investigate, rather than validated switch or firewall benchmarks. Decide which network function you need before choosing the operating system and add-in hardware around it.
Teardown and the optional fan
The final teardown reveals the mainboard, RTC battery, fan connection, and thermal contact between the components and aluminum shell. Platima appreciates the manufacturing and the way the assembly holds the board against the thermal mass. The exercise also shows that opening the enclosure is more involved than simply lifting away a lid: fasteners and thermal contact need attention during reassembly.
ZimaBoard 2 mainboard and aluminum case opened during teardown
Opening the enclosure reveals the board and thermal contact with the aluminum shell; the review then fits an optional fan. Video frame at 45:50, courtesy of Platima Tinkers.
He installs the small optional fan and finds it very quiet in his own recording setup, eventually choosing to leave it fitted. That is a subjective listening observation. The video does not supply a controlled decibel comparison or a completed before-and-after thermal chart, so the fan should not be assigned an invented temperature improvement.
For sustained CPU work, measure temperatures in the final enclosure with the actual drives and expansion card installed. The early Michael Klements test shows why duration and airflow matter, while this later teardown makes the cooling arrangement easier to understand. Neither replaces a check under your own ambient conditions.
Which ZimaBoard 2 configuration was reviewed?
The Intel N150 version with 16GB of RAM and 64GB of eMMC. The linked CPU records use ZimaOS 1.6.0.
Did the GPU experiment succeed?
No. The old NVIDIA card needed a legacy driver, and the old AMD card also did not produce a working result in the tested setup.
Did the NVMe drive work?
Yes. Platima demonstrates detection and storage setup through the PCIe adapter. He does not publish a storage-speed result for that experiment.
Were the SATA problems explained?
No definitive cause is established. Two used drives are not recognized during the demonstrated attempts, and the reviewer leaves the issue open.
Does the review prove 10GbE line-rate performance?
No. The dual-port card is recognized, but no iperf or equivalent throughput measurement is completed.
Is the optional fan silent in every installation?
Platima finds his example very quiet. Mounting, room noise, fan behavior, and the rest of the assembly affect what another owner hears.
Conclusion
Platima's review makes ZimaBoard 2 attractive as a compact platform for learning and building: setup is approachable, the NVMe adapter works, a 10GbE card is recognized, and the enclosure can be opened to examine the cooling and board design. Its most useful lesson is to validate expansion one device at a time. The failed old-GPU experiments and unresolved SATA behavior are part of the evidence, alongside the successes. Choose the configuration and adapters around a specific project, then prove the complete assembly before relying on it every day.
Zima Campaign Hub
