Updated for 2026. This industry insight report combines public market forecasts, official platform documentation, open-source ecosystem signals, and a small public-signal pilot sample to forecast how AI Agent Skills may grow from 2027 to 2029.
Core thesis: AI Agent Skills are becoming the execution layer of agentic AI. Between 2027 and 2029, the strongest growth is likely to move from read-only skills, such as search and file retrieval, toward write-action skills and multi-step workflow skills that can modify files, trigger tools, update systems, and coordinate private workflows.
Quick Answer
AI Agent Skills are likely to become one of the fastest-growing layers in the agentic AI stack between 2027 and 2029. In this report, “AI Agent Skills” does not only mean Claude Skills or a specific SKILL.md package. It refers to the broader capability layer that lets AI agents call tools, use APIs, access files, execute workflows, and reuse task-specific procedural knowledge.
Our model-based forecast estimates that active AI Agent Skills users could grow from roughly 35–55 million in 2026 to 240–360 million by 2029. As a share of active generative AI users, Skills usage may rise from around 4%–6% in 2026 to 18%–24% by 2029.
The most important shift will not be simple search or file-reading. It will be the movement from read-only skills to write-action skills and multi-step workflow skills. In practical terms, users will move from asking an AI assistant to summarize a document to asking an AI agent to update a file, modify code, create a calendar event, generate a report, trigger a workflow, or coordinate multiple tools across a private workspace.
For ZimaSpace, this trend matters because AI Agent Skills will increasingly need access to local files, private knowledge bases, home labs, team documents, code repositories, and self-hosted workflows. That makes local AI infrastructure, private storage, and personal cloud systems a strategic part of the future agent stack.
What Counts as an AI Agent Skill?
An AI Agent Skill is a reusable capability package that helps an AI agent complete a task beyond ordinary conversation. It can include instructions, metadata, scripts, templates, examples, APIs, or tool definitions. The key difference between a prompt and a skill is persistence. A prompt is usually a one-time instruction. A skill is reusable, discoverable, and designed to be loaded when the agent needs that capability.
In the current ecosystem, AI Agent Skills appear in several forms:
Claude Agent Skills and SKILL.md folders.
MCP tools connected to files, databases, APIs, search engines, and workflows.
OpenAI tool calling, built-in web search, file search, and computer use.
Coding-agent skills for Claude Code, Codex, Gemini CLI, Cursor, VS Code, and similar tools.
Automation workflows in tools such as Zapier, Make, n8n, or custom internal scripts.
This broader definition is important. If the report only counts one platform’s Skills feature, it will underestimate the market. Skills are better understood as an execution layer inside the larger AI agent trend.
| Skill Type | What It Does | Example |
| Read-only Skills | Retrieve, search, summarize, or classify information. | Search local documents, read PDFs, retrieve customer notes. |
| Write-action Skills | Modify an external system or create a real output. | Send email, update a spreadsheet, modify code, create a ticket. |
| Multi-step Workflow Skills | Coordinate multiple tools and decisions across a workflow. | Research a market, generate a report, update a CRM, notify a team. |
In 2026, read-only skills are still the easiest to adopt because they carry lower risk. But from 2027 to 2029, the strongest growth is expected in write-action and multi-step skills because those are the skills that turn AI from an assistant into an operator.
2026 Baseline: Agent Adoption Is Real, but Not Fully Scaled
The 2026 baseline is mixed. AI adoption is already broad, but agentic AI is still uneven. Many organizations use AI, but far fewer have redesigned workflows deeply enough for agents to produce measurable business impact.
This distinction matters for forecasting AI Agent Skills. A company may use generative AI for writing, summarization, or brainstorming without using any real agent skills. Skill adoption begins when the AI system connects to tools, data, workflows, or executable actions.
| Early Adopter Group | Why They Adopt First |
| Developers | Coding agents naturally need repository context, terminal access, testing tools, and code modification. |
| AI Power Users | They build repeatable workflows for research, content, data, and productivity. |
| Automation Teams | They already understand APIs, workflow triggers, RPA, and SaaS integrations. |
| Self-hosted and Local AI Users | They care about private files, local knowledge bases, controllable infrastructure, and local workflow ownership. |
The strongest early signal comes from software development. Coding agents need skills because code work is structured, repetitive, testable, and tool-heavy. A coding skill can inspect files, apply project conventions, run tests, update documentation, or generate a pull request. This makes coding one of the first major adoption channels for Skills.
This also explains why tools such as the AI Agent Skill Finder are useful. Users do not only need to know that “AI agents are growing.” They need to identify which skills fit specific workflows: coding, local knowledge bases, document search, RAG, DevOps, content creation, or private automation.
Forecast: AI Agent Skills Users and Usage Share, 2027–2029
This report uses a three-variable forecast model:
Estimated AI Agent Skills Users = Active GenAI Users × Agent Adoption Rate × Skill Activation Rate
Estimated Skill Usage = Active Agents × Actions per Agent × Skill/Tool Share
The forecast does not assume that every AI user becomes a Skills user. Most casual users will continue using AI as a chat interface. Skills adoption grows when the user or organization needs repeatable execution.
Forecast Matrix
| Year | Estimated Active AI Agent Skills Users | Share of Active GenAI Users | Main Growth Driver |
| 2026 | 35M–55M | 4%–6% | Developers, AI power users, early workflow automation. |
| 2027 | 75M–120M | 7%–10% | Enterprise pilots mature; low-quality agent projects are filtered out. |
| 2028 | 140M–230M | 12%–16% | Task-specific agents become common inside enterprise applications. |
| 2029 | 240M–360M | 18%–24% | Multi-step workflow skills, agent-to-agent orchestration, and private/local AI workflows. |
Skill-Type Forecast
| Year | Read-only Skills | Write-action Skills | Multi-step Workflow Skills |
| 2026 | 45%–55% | 35%–45% | 5%–10% |
| 2027 | 38%–48% | 38%–46% | 10%–17% |
| 2028 | 30%–40% | 40%–48% | 15%–25% |
| 2029 | 25%–35% | 42%–50% | 22%–30% |
The most important forecast is not the exact user count. It is the mix shift. Read-only skills will remain useful, but their share should decline as agents become more trusted to take action. By 2029, the highest-value skills will not simply read information. They will execute repeatable workflows with guardrails, permissions, and local context.
Forecast Visualization: Active AI Agent Skills Users, 2026–2029
The chart below visualizes the midpoint of our active AI Agent Skills user forecast. The line does not represent an official market-size estimate from a single institution. It is a model-based midpoint derived from the forecast range used in this report.
Source note: midpoint forecast based on the report model. 2026 = 45M, 2027 = 97.5M, 2028 = 185M, 2029 = 300M active AI Agent Skills users.
Why Write-action and Multi-step Skills Will Grow Faster
There are three reasons write-action and multi-step skills should grow faster than read-only skills.
First, the major AI platforms are building toward tool execution. OpenAI’s agent tooling, Anthropic’s Agent Skills, MCP, and coding-agent ecosystems all point in the same direction: agents need structured ways to discover capabilities, call tools, and act on external environments.
Second, the user value is higher. A read-only skill saves time by finding or summarizing information. A write-action skill saves time by completing the task. For example, summarizing a bug report is useful. Creating a patch, running a test, updating the changelog, and preparing a pull request is much more valuable.
Third, multi-step skills create workflow lock-in. Once a team builds a repeatable agent workflow for weekly reporting, customer support triage, code review, documentation, or research, the skill becomes part of the operating process. That makes it more durable than a one-off prompt.
However, growth will not be frictionless. Write-action skills introduce real risks: wrong edits, incorrect emails, broken workflows, permission errors, data leakage, and hidden tool misuse. That is why the next phase of the market will reward skills that are auditable, scoped, reversible, and easy to review.
Why Local and Private Agent Skills Matter
Most early AI assistants were cloud-first. But agent skills are different because they often need access to private context: documents, media libraries, code repositories, spreadsheets, customer notes, local databases, and internal knowledge bases.
That creates a new infrastructure question: where should the agent’s working context live?
For individuals and small teams, a private local AI workflow may become more attractive than pushing every file into a cloud assistant. For developers, creators, researchers, and home lab users, the ideal agent stack may include local storage, local indexing, private retrieval, and controlled tool execution.
This is where ZimaSpace has a natural content angle. A device like ZimaCube 2 AI NAS can be positioned not just as storage, but as part of the private AI workflow layer: a place to organize files, host local services, build private knowledge bases, run self-hosted tools, and connect future agent skills to personal or team data.
Strategic framing: AI Agent Skills will move from cloud-based assistants to private, local, and workflow-aware execution layers.
For ZimaSpace, this gives the report a differentiated point of view. Instead of writing another generic AI agent market article, the article can explain why agent skills will need private infrastructure as they move from conversation to execution.
Community Signal Validation: What Public Users and Developers Are Already Discussing
To reduce the risk of relying only on top-down market forecasts, we added a public-signal pilot sample. This is not a statistically representative survey. Instead, it is a web-verified sample designed to test whether real users and developers are already discussing AI Agent Skills, MCP tools, SKILL.md packages, coding-agent plugins, installation friction, and action-oriented workflows.
In this pilot pass, we reviewed 46 relevant public signals across Reddit, GitHub, and indexed X/Grok-style public posts. X/Grok signals were counted only as index-level trend signals when the full post content required login. For a production-grade report, this pilot should be expanded to a 300-post sample using Reddit API, GitHub API, Firecrawl, and a reproducible labeling sheet.
Public-Signal Sample Design
The chart below summarizes the public-signal pilot sample used in this report. We reviewed 46 relevant signals across Reddit, GitHub, and indexed X/Grok-style public posts.
Source note: web-verified public-signal pilot sample across Reddit, GitHub, and indexed X/Grok-style public posts.
This sample is not a statistically representative survey. It is a directional validation layer used to test whether real users and developers are already discussing AI Agent Skills, MCP tools, SKILL.md packages, coding-agent plugins, installation friction, and action-oriented workflows.
| Source Surface | Verified / Reviewed Signals | What We Counted | Use in Forecast |
| Reddit: r/ClaudeAI | 8 | Claude Skills explainers, SKILL.md discussions, skill directory mentions, token/cost concerns. | Validates early user curiosity and skill-discovery demand. |
| Reddit: r/mcp | 6 | MCP tools vs resources/prompts, client compatibility, tool-calling preference. | Supports the forecast that tools and action skills will grow faster than passive resources. |
| Reddit: r/LocalLLaMA | 5 | MCP-powered local agents, tool setup, fragmented discovery, local workflow use cases. | Supports local/private AI workflow relevance for ZimaSpace. |
| GitHub: Official and platform docs | 5 | Anthropic Skills, GitHub Copilot agent skills, SKILL.md structure, skill installation paths. | Confirms that Skills are becoming a cross-platform agent capability pattern. |
| GitHub: Community repositories | 12 | Claude Skills libraries, awesome lists, coding-agent plugins, MCP-related agent tools. | Validates ecosystem formation outside official vendor docs. |
| X / Grok-indexed public posts | 10 | Indexed posts about Claude Skills, MCP tools, workflow skills, coding-agent skill lists. | Used only as weak trend signal because many full posts require login. |
| Total | 46 | Publicly visible, manually reviewed pilot signals. | Used to validate direction, not to claim statistical representation. |
Intent Analysis Matrix
Each signal was manually labeled by dominant intent. The goal was to test whether public discussion is mostly about general AI curiosity, or whether users are already discussing repeatable skills, tool calling, workflow execution, and setup friction.
| Intent Category | Signal Count | Share of Pilot Sample | Interpretation |
| Build, install, or use agent skills | 18 | 39.1% | Strongest signal. Users and developers are not only reading about Skills; they are trying to create, install, and reuse them. |
| Tool/action preference over passive resources | 9 | 19.6% | Supports the forecast that action-oriented tools and skills will become the practical adoption layer. |
| Discovery, directories, and marketplaces | 8 | 17.4% | Shows a growing need for skill finders, curated directories, and compatibility filters. |
| Setup friction, compatibility, security, or governance concerns | 7 | 15.2% | Supports the conservative risk case: adoption will grow, but poor setup and unclear governance will slow weak projects. |
| Local, private, or self-hosted agent workflows | 4 | 8.7% | Smaller but strategically important signal for ZimaSpace because private context and local files are natural skill inputs. |
| Total | 46 | 100% | Pilot sample for directional validation. |
What the Pilot Sample Adds to the Forecast
The pilot sample strengthens three parts of the forecast. First, it supports the idea that Skills are becoming an ecosystem, not just a single vendor feature. Official repositories, GitHub Copilot documentation, and community skill libraries all use the same core pattern: a skill is a reusable directory that contains a SKILL.md file and optional scripts, examples, or resources.
Second, it supports the shift from read-only skills to action-oriented skills. Reddit MCP discussions show that tools are currently the most visible and practical part of MCP adoption, while resources and prompts are less widely understood. This matches the forecast that write-action skills will grow faster than passive information-access skills.
Third, it identifies the adoption bottleneck. Users are interested in Skills, but they also discuss installation paths, client compatibility, permission boundaries, tool fragmentation, and security. This means the winning AI Agent Skills ecosystem will not be the one with the most packages. It will be the one with better discovery, safer execution, clearer installation, and reliable workflow outcomes.
For ZimaSpace, the local/private signal is especially important. As more Skills need access to files, repositories, media libraries, personal archives, and team knowledge bases, users will need a controlled place for that data to live. This creates a natural bridge between AI Agent Skills and private AI infrastructure such as ZimaCube 2 AI NAS.
Risks That Could Slow AI Agent Skills Adoption
The biggest risk is not lack of interest. It is trust.
Many agent projects will fail because they are not real agents, do not connect to valuable workflows, or cannot prove ROI. “Agent washing” will also create confusion, where ordinary chatbots or RPA scripts are marketed as agentic AI.
The second risk is tool safety. When an agent can modify files, call APIs, send messages, or trigger financial workflows, the skill layer becomes a security boundary. A poorly written skill can cause real damage. A malicious skill can manipulate the agent’s discovery or selection process.
The third risk is verification. Enterprises may experiment with agents that perform impressive demos but cannot be safely integrated into production because the output is hard to verify. In high-stakes workflows, human-in-the-loop approval will remain necessary.
The fourth risk is tool sprawl. As users install more MCP servers, skills, scripts, and workflow connectors, they may struggle to manage permissions, dependencies, duplication, and relevance. This creates an opportunity for skill finders, registries, permission managers, and local control panels.
Conclusion
AI Agent Skills are not a small feature category. They are an early form of the execution layer for agentic AI.
From 2027 to 2029, the market should shift from simple read-only skills toward write-action and multi-step workflow skills. The number of active AI Agent Skills users could grow from tens of millions in 2026 to hundreds of millions by 2029, but the real story is the change in behavior: users will expect AI systems to act, not just answer.
For ZimaSpace, the most valuable angle is local and private execution. As agent skills touch more private files, home labs, code repositories, media libraries, and team knowledge bases, users will need infrastructure they can control. That makes private AI storage, local knowledge bases, and self-hosted workflows a credible part of the agentic AI future.
The winning skills will be reusable, scoped, auditable, and connected to real workflows. The winning infrastructure will be private, reliable, and ready for agent execution.
Sources
Industry Reports
McKinsey — The State of AI: Global Survey 2025
https://www.mckinsey.com/capabilities/quantumblack/our-insights/the-state-of-ai
Stanford HAI — 2026 AI Index Report
https://hai.stanford.edu/ai-index/2026-ai-index-report
IDC — Agent Adoption: The IT Industry’s Next Great Inflection Point
https://www.idc.com/resource-center/blog/agent-adoption-the-it-industrys-next-great-inflection-point/
Gartner — Over 40% of Agentic AI Projects Will Be Canceled by End of 2027
https://www.gartner.com/en/newsroom/press-releases/2025-06-25-gartner-predicts-over-40-percent-of-agentic-ai-projects-will-be-canceled-by-end-of-2027
Gartner — 40% of Enterprise Apps Will Feature Task-Specific AI Agents by 2026
https://www.gartner.com/en/newsroom/press-releases/2025-08-26-gartner-predicts-40-percent-of-enterprise-apps-will-feature-task-specific-ai-agents-by-2026-up-from-less-than-5-percent-in-2025
Grand View Research — AI Agents Market Size, Share & Trends Report 2026–2033
https://www.grandviewresearch.com/industry-analysis/ai-agents-market-report
Official Docs and Platform Sources
OpenAI — New Tools for Building Agents
https://openai.com/index/new-tools-for-building-agents/
OpenAI — Agents SDK
https://developers.openai.com/api/docs/guides/agents
Model Context Protocol — Introduction
https://modelcontextprotocol.io/docs/getting-started/intro
Anthropic — Agent Skills Overview
https://platform.claude.com/docs/en/agents-and-tools/agent-skills/overview
Anthropic — Equipping Agents for the Real World with Agent Skills
https://www.anthropic.com/engineering/equipping-agents-for-the-real-world-with-agent-skills
GitHub — anthropics/skills
https://github.com/anthropics/skills
Visual Studio Code — Use Agent Skills in VS Code
https://code.visualstudio.com/docs/agent-customization/agent-skills
GitHub Docs — Adding Agent Skills for GitHub Copilot CLI
https://docs.github.com/en/copilot/how-tos/copilot-cli/customize-copilot/add-skills
Academic and Technical Evidence
arXiv — How Are AI Agents Used? Evidence from 177,000 MCP Tools
https://arxiv.org/abs/2603.23802
arXiv — Agent Skills: A Data-Driven Analysis of Claude Skills
https://arxiv.org/abs/2602.08004
arXiv — Under the Hood of SKILL.md
https://arxiv.org/abs/2605.11418
arXiv — Agentic AI in Industry: Adoption Level and Deployment Barriers
https://arxiv.org/abs/2605.14675
Community and Open-Source Sources
GitHub — Claude Code Skills & Agent Plugins
https://github.com/alirezarezvani/claude-skills
GitHub — Awesome Claude Skills by ComposioHQ
https://github.com/ComposioHQ/awesome-claude-skills
GitHub — Awesome Claude Skills by travisvn
https://github.com/travisvn/awesome-claude-skills
GitHub — Awesome Agent Skills by VoltAgent
https://github.com/VoltAgent/awesome-agent-skills
GitHub — Agent Skills Documentation in wshobson/agents
https://github.com/wshobson/agents/blob/main/docs/agent-skills.md
Reddit — Why Do So Few Clients Support Resources and Prompts?
https://www.reddit.com/r/mcp/comments/1md6dkw/why_do_so_few_clients_support_resources_and/
Reddit — Which Clients Support Which Parts of the MCP Protocol?
https://www.reddit.com/r/mcp/comments/1lkbpbt/which_clients_support_which_parts_of_the_mcp/
Reddit — Tiny Agents, an MCP-Powered Agent in 50 Lines of Code
https://www.reddit.com/r/LocalLLaMA/comments/1k7rgyv/tiny_agents_a_mcppowered_agent_in_50_lines_of_code/
Reddit — Are AI Agent Tools Like MCP Servers Too Fragmented?
https://www.reddit.com/r/LocalLLaMA/comments/1sqif6v/are_ai_agent_tools_like_mcp_servers_too/
Reddit — The Busy Person’s Intro to Claude Skills
https://www.reddit.com/r/ClaudeAI/comments/1pq0ui4/the_busy_persons_intro_to_claude_skills_a_feature/
AI HUB
The Home AI Server Demand Forecast 2027: Why Private AI Workloads Are Moving Closer to Home
A 2027 forecast on why home AI server demand may grow as local LLMs, private RAG, media AI, automation, privacy needs, and cloud infrastructure...
What GPT-5.6 Means for Local AI, Home Servers, and Private Data
A practical guide to GPT-5.6, local AI, home servers, private data, hybrid workflows, RAG, tool calling, and safe cloud model use.
AI Agent at Home: What Can It Actually Automate?
A practical guide to home AI agents, covering smart-home control, local files, private RAG, server reports, approval gates, and safe automation.
