Thank you to u/Smokeey1 for sharing the first stage of a ZimaBlade 7700 home server with two 8 TB IronWolf NAS drives. The hardware is assembled, CasaOS is being explored, and the creator is already asking the questions that turn a collection of parts into a useful server: how to assess drive temperatures, how to shut down cleanly and which workload to establish first.
The original Reddit story is a beginner’s request for guidance, rather than a report of every planned service being completed. Its photographs and questions make that early operating stage worth examining on its own terms.
The First Build Starts with Storage Hardware
The owner identifies a ZimaBlade 7700 and two 8 TB Seagate IronWolf NAS drives, described as roughly 7,000 RPM. The photographs show the board above the disks in an open stand, with networking equipment nearby. This is a compact assembly being put to use before a larger application stack is established.
The source does not identify the board’s exact processor revision, installed memory or boot-device arrangement. Historical ZimaBlade 7700 units should not be assigned a newer product configuration simply because they share the family name.
The matching hardware reference is ZimaBlade. The original kit and this creator’s selected drives provide the physical starting point; the intended backup, media and learning roles still need to be developed.
The Questions Separate the Current Setup from Its Goals
| Area | State described in the post |
| Board | ZimaBlade 7700, already assembled with storage |
| Drives | Two 8 TB IronWolf NAS disks |
| Software | Exploring CasaOS and having reset the setup during experimentation |
| Temperature observation | Owner reports around 40–50°C during writes |
| Data goal | Backup of client files and a possible RAID arrangement |
| Other interests | Media libraries, browser isolation, transcoding questions and a Linux-learning VM |
That final group is a wish list, not an installed-service inventory. The post does not establish a completed RAID volume, successful transcoding, a deployed isolated browser or a running virtual machine.
Our ZimaBlade apartment homelab story provides a companion view of a more developed storage-and-application collection. This owner is at the earlier point of deciding how the first machine should be operated.
The Drive Temperatures Are a Measurement Question
The owner notices temperatures around 40–50°C while writing and asks whether a Noctua fan should be added. The post does not provide the exact drive model numbers, ambient temperature, sensor method or duration of the writes.
Those missing details matter before declaring a fault or choosing a cooling change. The official IronWolf product and support resources are the starting point for locating the documentation that matches the actual disk label. A specification from another capacity or product revision should not be substituted without checking.
The photographs make physical spacing visible, but they do not measure airflow. A useful comparison for another builder would record the same workload and room conditions before and after a change. That is a way to investigate the question, not a cooling result attributed to this creator.
Shutdown Is an Operating Task, Not Just a Button
The owner also asks whether a server must remain on continuously and how to handle shutdown when the board does not have the familiar desktop-style button they expect. This question connects the computer’s small form with the habits needed to operate attached storage.
The official ZimaBlade hardware guide is a useful reference for the board and its setup. The exact shutdown path also depends on the operating environment installed beneath the interface. This account does not invent a button sequence or an automatic power schedule for the creator’s machine.
A clean software shutdown and simply removing power are different events. The practical objective is to let active work finish and the system stop before power is removed. Whether the household wants scheduled downtime or continuous availability is a separate decision about when its services are needed.
The source does not report that a particular shutdown policy was tested. It captures the moment when a beginner recognizes that using the server includes starting, stopping and recovering it as well as installing applications.
CasaOS Gives Experimentation a Visible Starting Point
The creator wants to learn through CasaOS despite having encountered criticism of it elsewhere. The official CasaOS project documents its personal-cloud interface and application-management approach. This historical story should retain that software choice rather than silently replace it with ZimaOS.
The owner says they have reset the setup during experimentation. That makes the separation between disposable configuration and valuable data especially relevant. Learning how an application is recreated is a different task from learning where its persistent files are kept.
Our small homelab story from u/jc-21 offers a related perspective on giving devices defined responsibilities. For this first board, choosing one useful job would make each subsequent software experiment easier to evaluate.
Client-File Backups Need a Clear Recovery Goal
The most concrete proposed data role is backing up client files. The owner also wants to put the disks into RAID, but does not say that layout has been created. The two concepts deserve separate records: drive redundancy can help with a disk failure, while recovery also depends on copies, retention and the ability to retrieve the intended files.
Before a similar server becomes responsible for important work, a useful first exercise would use a sample file: identify its original, make a separate copy and retrieve that copy without relying on the original location. That is an editorial suggestion for establishing a recovery workflow, not an action the owner reports completing.
The wider interests—media, browser isolation and a Linux VM—can then be considered against that first job. The source supplies no resource allocation, transcoding result or virtual-machine compatibility test. A list of goals is a starting point for learning rather than evidence that the board already meets every requirement.
This is what makes the early-stage account useful: the operating questions are visible before the system’s application list becomes difficult to untangle.
Is this a completed mirrored NAS?
The owner has two drives and asks about RAID. A completed mirrored configuration is not documented.
Was a cooling fan added successfully?
The post asks about adding a fan but supplies no verified modification or measured improvement.
Are the planned media and virtual-machine services installed?
The source presents them as interests and questions, without a completed deployment or benchmark.
Does this creator use ZimaOS?
The software discussion identifies CasaOS. The story preserves that historical choice.
Conclusion
This first ZimaBlade 7700 build shows the gap between assembling storage and knowing how to operate it. The creator already has a compact board-and-drive arrangement; the next work is to understand temperatures, clean shutdown, persistent data and the first recoverable file workflow. Keeping the goals separate from completed results makes the story a useful record of learning to run a server.
Zima Campaign Hub
A Lenovo M80q ZimaOS Server for a Child’s Minecraft World
A reused Lenovo M80q runs ZimaOS and a child’s Minecraft server beside a 16 TB disk. Original photos show the hardware, dashboard and storage...
A P360 Ultra Homelab with ZimaOS Storage and Cockpit-Managed VMs
A P360 Ultra combines Ubuntu, Cockpit-managed VMs, ZimaOS storage and remote access, with a mirrored enclosure and a clear inventory of separate roles.
ZimaCube 2 Review: Creator Pack, ZimaOS Apps and Virtual Machines
IT-Connect explores the ZimaCube 2 Creator Pack, from hardware access to ZimaOS apps, virtual machines, backups, and custom containers.
