Thank you to u/federicokalik for sharing a printed homelab that gives a ZimaBlade a dedicated TrueNAS SCALE storage role beside a Raspberry Pi 5 and a Ryzen mini PC. Two 4 TB drives form a ZFS mirror, while front displays, accessible drive bays and custom printed parts make the collection easier to inspect as one physical system.
The original Reddit build explains the creator’s preference for several machines with different responsibilities instead of one larger server. This story focuses on that existing ZimaBlade storage arrangement and its supporting rack hardware.
A Printed Rack Brings Three Different Computers Together
The creator’s stated goal is a compact, relatively quiet and energy-conscious setup. Those are design aims, not measured results: the post does not provide a noise test or a wattage figure that another builder could reproduce.
The photographs show a white printed structure containing networking, compact computers, drive bays and cooling openings. Equipment has a defined position rather than occupying a loose pile around the room. The result is still a homelab assembled from different parts, with the physical frame giving those parts a shared home.
The source title refers to a 5U rack while its body describes an 8U LabRax. Because those descriptions differ, this account does not treat either height as a verified construction dimension. A reader reproducing the layout would need to check the actual frame files and component measurements.
ZimaBlade Handles a Named Storage Configuration
The clearest software-and-disk pairing is the ZimaBlade running TrueNAS SCALE with two 4 TB hard drives in a ZFS mirror. That is an explicitly reported layout, rather than a redundancy assumption made from the presence of two bays.
| Part | Owner-reported configuration |
| NAS host | ZimaBlade running TrueNAS SCALE |
| NAS disks | Two 4 TB hard drives in a ZFS mirror |
| ARM computer | Raspberry Pi 5 running Ubuntu 26.04 |
| x86 mini PC | Acemagic K1 with AMD Ryzen 5, running Ubuntu 26.04 |
| Network and smart-home hardware | Gigabit switch and SLZB-06 Zigbee coordinator |
| Supporting equipment | Noctua fans, two status displays and an 800 VA UPS |
The corresponding product is ZimaBlade. The creator does not identify its exact model or installed memory. The other two computers’ operating systems should also remain separate from the TrueNAS installation on the storage board.
Our ZimaBlade TrueNAS apartment story offers another example of separating a small NAS host from surrounding application machines. The printed frame here gives that division a more deliberate physical arrangement.
The Mirror Defines Redundancy, While Recovery Needs Another Record
The TrueNAS pool documentation describes mirror layouts within the broader process of creating storage. A mirror stores redundant copies across its member disks; it does not make the two drive labels an eight-terabyte protected volume.
That distinction matters when reading this build. Two 4 TB drives are the installed inventory, while usable space depends on the layout and overhead. The source establishes the mirror, but it does not describe datasets, share permissions, snapshots or an external recovery copy.
For someone adapting the arrangement, a useful next record would connect each important service to its data location. Which files are served from the mirror? Which configuration lives on another computer? Where would the owner recover the information if the whole storage host became unavailable? Those are planning questions prompted by the architecture, not results claimed by the creator.
The Proxbox backup-server story is a useful companion because it gives recovery a defined machine and purpose within a different homelab.
Front Displays Make the Rack Easier to Read
The owner identifies a small OLED and an additional monitoring display. Their placement makes status information available without opening every machine’s web interface. The photographs also show drive access integrated into the front of the assembly.
These details help explain the printed parts’ purpose. A custom panel can align a screen with the rest of the equipment, while a drive opening can preserve access to storage. The value comes from how those pieces fit the owner’s actual devices and maintenance habits.
The source does not supply a display configuration, sensor calibration or a complete monitoring architecture. A number on a screen describes the displayed reading at that moment. It should not be turned into a sustained-load thermal result or a benchmark for every board in the rack.
Cooling and Power Support Belong to the Same Layout
Noctua fans and an 800 VA UPS are named in the inventory. They support different operating needs: airflow around the equipment and continued power during a mains interruption. Neither item alone establishes how the entire system behaves under a long workload or during an outage.
The UPS rating is not a measured runtime. The post does not provide battery condition, connected load or a tested shutdown sequence. Likewise, visible fans do not establish a particular temperature reduction without a before-and-after test.
The Network UPS Tools manual is a reference for readers investigating UPS monitoring and automatic shutdown across computers. The creator does not say this rack uses NUT, so that documentation explains a related operational task rather than a feature attributed to the build.
Separate Machines Still Need an Understandable Service Map
The decision to divide responsibilities is the central architectural idea. The ZimaBlade’s storage role is explicit, and the two Ubuntu machines provide separate computing environments. Sharing a frame does not combine those machines into one operating system or automatically create a cluster.
The source inventory is not a complete application deployment map. It does not establish every share mount, dependency or recovery order. Keeping those limits visible helps another builder borrow the organization idea without treating a photograph as a complete installation guide.
A practical service map could stay short: name the host, its job, the persistent files it owns and what stops when it restarts. That would complement the clarity already created by the custom panels and front connections. It is a way to document a similar setup, rather than an extra task the original owner claims to have finished.
Which operating system runs on the ZimaBlade?
The creator identifies TrueNAS SCALE. The Raspberry Pi and Ryzen mini PC are described separately as Ubuntu machines.
Are the two hard drives mirrored?
Yes. The source explicitly states that the two 4 TB disks form a ZFS mirror.
Is the rack height established consistently?
No. The title and body give different unit counts, so this article does not use either as a verified build dimension.
Does the UPS rating establish battery runtime?
No runtime test is supplied. The 800 VA figure is the owner’s equipment rating.
Conclusion
This printed homelab makes a dedicated ZimaBlade storage host part of a compact, understandable physical system. The mirror, separate computers, front displays and accessible bays give the design concrete functions. Its most useful lesson is to connect physical organization with explicit operating roles, while keeping measurements and configuration details within what the creator actually documents.
Zima Campaign Hub
A First ZimaBlade 7700 NAS: Two 8 TB Drives and Learning CasaOS
A first ZimaBlade 7700 build pairs two 8 TB drives with CasaOS, raising practical questions about temperatures, shutdown and a recoverable backup workflow.
A Lenovo M80q ZimaOS Server for a Child’s Minecraft World
A reused Lenovo M80q runs ZimaOS and a child’s Minecraft server beside a 16 TB disk. Original photos show the hardware, dashboard and storage...
A P360 Ultra Homelab with ZimaOS Storage and Cockpit-Managed VMs
A P360 Ultra combines Ubuntu, Cockpit-managed VMs, ZimaOS storage and remote access, with a mirrored enclosure and a clear inventory of separate roles.
