Thank you to u/gotfilmm for sharing a media lab that includes a particularly hands-on ZimaBlade 7700 NAS. The small board runs TrueNAS with a PCIe-connected 1TB M.2 drive and two 6TB hard drives, while a printed fan shroud and an added power switch make the hardware its owner’s own.
The original Reddit gallery and the creator’s explanation connect the wider rack to the close-up of the board. They also preserve a useful unfinished detail: after the switch modification, the original cover no longer fitted, and a vented replacement was still being planned.
The Close-Up Gives the Rack a More Personal Story
A rack photograph shows where equipment belongs. A closer view can explain what its owner has changed to make a particular device fit that arrangement.
Here, the wider image supplies the context: a compact rack brings a display, network connections and small computers together. The board photograph then reveals the NAS work that the front panels largely conceal.
The thread does not provide a complete service inventory for every machine. The strongest documented part of the story is the ZimaBlade single-board server and the changes made around its storage, cooling and cover.
| Component or change | What is established |
| ZimaBlade 7700 | The board identified by the creator |
| TrueNAS | The reported NAS operating system |
| 1TB M.2 drive on PCIe | Additional storage connected through an adapter |
| Two 6TB HDDs | The listed mechanical drives |
| Printed fan shroud | A custom part for a 5V Noctua fan |
| Added power switch | A convenience modification that affects cover fit |
| Vented replacement cover | A planned next step |
TrueNAS Makes the Storage Layout Worth Understanding
The operating system gives the hardware a defined NAS role. It also means that the device list is only the beginning of understanding the storage.
Two 6TB drives provide 12TB of combined nominal device capacity. That does not establish how much space the owner can use. The actual pool layout determines how capacity and redundancy are arranged, and the source does not publish that configuration.
The TrueNAS pool-creation documentation explains the distinction between layouts such as stripes and mirrors. For readers planning their own NAS, choosing that layout is a separate decision from choosing the physical drive frame.
The same restraint applies to the M.2 drive. The owner reports its presence but does not specify whether it serves as boot storage, application storage or another role. A visible SSD should not automatically be described as a cache that accelerates the hard drives.
Our dedicated TrueNAS backup-node story offers a related comparison: the job assigned to storage is what makes a hardware arrangement meaningful.
The Printed Shroud Changes the Physical Design
The close-up is valuable because it makes the project’s constraints visible. The adapter extends beyond the small board. Cables need room to exit. Cooling parts occupy space that an unmodified enclosure may not have reserved.
A printed shroud lets a builder shape that space around a particular fan and mounting position. In this case, the creator identifies a 5V Noctua fan. The thread does not provide its exact model, electrical wiring or a published design file for the shroud.
For another maker, the useful starting point is a measurement task. Check the board outline, adapter height, connector clearance and the way the drive frame supports the assembly. Those dimensions determine whether a printed part will fit the actual build.
The Zima community 3D-model collection can provide examples of mounts and enclosures. It is a broader resource, rather than a claim that this creator’s exact part is available there.
A Small Convenience Change Creates a New Cover Problem
The added power switch is the detail that turns this from a parts list into an iterative build. It solves one practical concern for its owner, then changes the dimensions that the enclosure must accommodate.
In the reply, the creator says the original cover will no longer go back on. Their proposed replacement would be vented and sit on the two upper arches of the drive-bay enclosure. That is a specific plan tied to the existing physical structure.
It should remain a plan in the retelling. The gallery does not establish a completed replacement cover, its print material or its long-term fit. Those choices cannot be reconstructed reliably from the visible board alone.
For readers adapting the idea, a useful sequence is to test the new control’s position, check access to cables and adapters, then finalize the cover around those fixed points. Doing so can reduce the chance that finishing one part makes another difficult to reach.
Our guide to printed NAS cases and accessories explores the broader range of jobs that these small custom parts can perform.
Cooling Improvements Need Their Own Evidence
The presence of a fan is a design choice, rather than a temperature measurement. The post provides no before-and-after readings, fixed workload or noise test, so there is no supported numerical cooling claim to attach to the shroud.
The TrueNAS hardware guide discusses storage cooling and the importance of keeping devices within their manufacturers’ specifications. That is useful background for a compact assembly where the processor, SSD and hard drives may have different airflow needs.
Another owner evaluating a similar change could compare the same workload before and after fitting the part, with the cover in its intended position. Record the temperatures of the relevant devices and whether anything changes during an extended copy or other normal busy task.
That proposed comparison does not imply the creator had an overheating problem. It simply distinguishes an appealing mechanical modification from a result that another person could reproduce and assess.
The Wider Lab Is Still Growing
The creator also planned to add two more HP machines. The post does not establish that those additions happened or describe their eventual workloads.
As a reader, it is helpful to keep the NAS modification and the broader rack expansion separate. One changes the design of an existing storage host. The other would change the collection of hosts around it. Each can be assessed on its own purpose.
Is the operating system ZimaOS?
The creator identifies TrueNAS. The story follows that installation and does not substitute another operating system.
Are the two hard drives configured as a mirror?
The source does not state their pool layout. Their number and nominal capacities do not prove a particular redundancy configuration.
Is the replacement cover ready to download?
The creator describes a planned cover, without an established completed file in the discussion.
How much did the fan lower temperatures?
No measured temperature improvement is reported. The photographs document the modification, rather than a thermal benchmark.
Conclusion
This ZimaBlade 7700 NAS shows the small decisions that make a DIY server personal. Storage expansion, a printed shroud and an easier-to-reach switch all affect the enclosure around them.
The useful lesson is the sequence: understand the storage role, fit the working hardware, then design the surrounding parts around its real clearances and cooling needs. The unfinished cover is part of that process, and gives the project a clear next step.
Zima Campaign Hub
A ZimaBoard 2 Prototype with Two 22 TB Drives on the Test Bench
Explore sabitech2k’s early ZimaBoard 2 drive test, the reported power conditions, and the existing ZimaBoard used for Proxmox backups.
A Quiet ZimaCube and ZimaBoard Homelab with Debian and Docker
A ZimaCube and ZimaBoard split everyday applications from smart-home services, with Debian, Docker, Pi-hole and a Homepage dashboard.
A LEGO Rack for a First ZimaBoard 2 Home Server
See how a first-time builder organized a ZimaBoard 2 and two SSDs in a LEGO rack, with Home Assistant and home-office storage planned next.
