Top 3D Printed NAS Cases Accessories for Your Homelab
3D printingย is revolutionizing how homelab enthusiasts build and optimize their server setups. Whether you're looking to house a powerfulย ZimaCube Proย or create a compactย ZimaBoardย cluster, custom 3D printed components offer unparalleled flexibility for cooling, storage expansion, and space management. In this guide, we dive into the best hardware-testedย NAS chassis designs, essential 3D printed accessories, and the technical filament requirementsโ€”like usingย ABSย orย PETGโ€”to ensure your DIY server remains structurally sound and perfectly cooled in a 24/7 environment.
What Are the Best 3D Printed NAS Cases for a Homelab Setup?
The best 3D printed NAS cases for a homelab include modular open racks, stackable single-board computer clusters, and dual-drive protective shells that prioritizeย airflow and cable management. These designs maximize space efficiency while keeping hardware accessible.
  • Modular Open Racks: Systems like the OpenRack 1U allow you to fit devices like the ZimaBoard and 2.5-inch hard drives into fully modular 10-inch or 19-inch server rack spaces.
  • Stackable Cluster Shells: Universal stacking projects designed for ZimaBoard support both HDD and SSD shell options, featuring built-in channels for a tidy workspace.
  • Elevated Protective Cases: Enclosures like the ZimaBoard SE Dual SSD Protective Case v2 feature raised bottom support protrusions to increase airflow and allow space for CAT5 and power cords.
Looking forย print-ready designs? Stop calculating tolerances from scratch. You canย download optimized, hardware-verified STL filesย directly from our official repository to ensure a perfect fit.
An empty white custom 3D printed chassis and mounting frame designed for a DIY home server or mini PC build, resting on a wooden surface.
Which 3D Printing Filament is Best for NAS Cases and Server Racks?
PETG and ABS/ASA are the best 3D printing filaments for NAS cases and server racks due to their high heat deflection temperatures (70ยฐC to 90ยฐC) and structural rigidity.
  • ABS or ASA (Required for High Heat): You absolutely need to print components close to the processorโ€”like the ZimaCube Pro CPU Fan Coverโ€”using high-temperature resistant materials such as ABS or ASA to prevent warping.
  • PETG (Best All-Rounder): Offers a perfect balance of printability and thermal resistance (around 75ยฐC), making it ideal for drive sleds and outer chassis shells.
  • PLA (Not Recommended): Avoid PLA for structural NAS parts because its low glass transition temperature (55ยฐC) causes it to warp under constant heat from HBAs and CPUs.
How Can 3D Printed Accessories Improve Homelab Server Cooling?
3D printed accessories improve homelab cooling by explicitly directing airflow over hot components usingย 3D-printable fan shrouds, elevated mounts, and integrated fan brackets.
  • Custom CPU Fan Covers: A well-designed fan shroud (such as for the ZimaCube Pro) can drop CPU temperatures by about 6ยฐC at 85% load and can be secured using 5x3mm magnets.
  • Integrated Large Fan Mounts: Stacking projects often include integrated 140mm fan mounts for superior, low-noise thermal management across multiple clustered boards.
  • Honeycomb and Elevated Structures: Adding honeycomb-shaped bumps and raising external supports significantly improves passive ambient cooling for dense storage arrays.
A fully wired DIY home server setup featuring a Zimaboard and hard drives housed in a black 3D printed enclosure with ethernet and power cables connected.
How to 3D Print Custom Mounts and Cases for ZimaBoard or ZimaCube?
To 3D print custom mounts for ZimaBoard or ZimaCube, download dimensionally accurate STL files, apply specific slicing settings, and reuse original hardware screws for secure mounting. By visiting the Zima Official 3D Models Library, you can access designs that have been pre-tested for tolerance and fit.
  • Hardware Preparation: Prep involves removing the top acrylic panel or bottom plastic plate; reuse the original screws to lock the board into the new shell.
  • Optimal Print Settings: For precision parts like the ZimaBoard SE SSD Adapter Bottom Mount, use a 0.2mm layer height, 2 wall lines, and 15% infill.
  • Accommodating Hardware: Ensure your chosen model leaves clearance for internal USB drives like the Samsung Fit Plus or accommodates specific 120mm PCIe extension cables.
What Are the Most Reliable 3D Printed Hard Drive Brackets for a DIY NAS?
The most reliable 3D printed hard drive brackets feature space-efficient designs, seamless chassis integration, and dedicated slots forย PCIe expansion adapters.
  • Dual 3.5-inch Brackets: Space-efficient designs allow you to mount two 3.5-inch drives underneath a single-board server by replacing the original bottom plate.
  • Precision NVMe Adapter Mounts: Compact bottom mounts are essential for securing PCIe to NVMe adapters to the base of your NAS rack, preventing disconnects.
  • GPU Compatibility: Advanced fan covers and brackets are designed to remain compatible with low-profile GPUs like the Nvidia RTX A2000 or Intel ARC A380 LP.
Is It Cheaper to 3D Print a NAS Case Instead of Buying a Pre-built Chassis?
Yes, 3D printing a NAS case is significantly cheaper, typically costing between $15 to $30 in filament, compared to $100 to $250 for a commercial chassis. It allows for unmatched customization, such as routing paths for external CAT5 cables, and offers modular upgradability for pennies on the dollar.
Inside a small form factor PC case showing a mini-ITX motherboard with Corsair Vengeance RAM, a low-profile CPU cooler, and custom 3D printed black air ducts for optimized cooling.
FAQs
Q1: Can I use PLA filament for a homelab NAS case?
It is highly recommended to avoid PLA for a NAS case. Homelab servers run 24/7, generating constant heat. PLA begins to soften and warp at temperatures as low as 55ยฐC. Always use PETG, ABS, or ASA for components like CPU fan covers and drive brackets to ensure thermal stability.
Q2: Where can I find free STL files for homelab servers and NAS?
You can find high-quality, free STL files for homelab setups on standard 3D printing repositories. However, for hardware-specific designsโ€”such as exact ZimaBoard SE SSD adapters, ZimaCube fan shrouds, and 1U open racksโ€”visit the Zima Official 3D Models Library for optimized and physically tested files.
Q3:ย Do 3D printed hard drive cages cause vibration damage?
If designed poorly, rigid 3D printed cages can transfer vibrations. However, utilizing slightly flexible materials like PETG, printing with dense infill patterns, and securing the drives tightly using standard mounting screws will effectively mitigate harmful vibration risks in your DIY NAS.
Q4:ย What infill percentage is needed for a 3D printed server rack mount?
For load-bearing structural parts like a 19-inch server rack mount, an infill percentage of 30% to 50% is recommended. For smaller, precision-engineered components like an SSD adapter bottom mount, a 15% infill combined with 2 wall lines at a 0.2mm layer height provides ample stability.
Q5:ย How long does it take to 3D print a complete DIY NAS case?
Depending on the size of the NAS case and the speed of your 3D printer, printing a complete multi-bay chassis typically takes between 25 to 50 hours. Smaller accessories, like a dual hard drive bracket or a custom CPU fan cover, can usually be completed in 3 to 6 hours.
Zima Campaign Hub
