Running MiniMax H3 Locally: Hardware, ComfyUI, and a Self-Hosted AI Video Setup
Yes, MiniMax H3 can run locally. The open H3-Base weights can generate video and native stereo audio on your own hardware, and community runtimes have already pushed the model onto 24GB GPUs, 12โ€“16GB cards, and even experimental 8GB configurations.
The important catch is that โ€œrunning H3 locallyโ€ does not currently mean reproducing every feature of MiniMaxโ€™s hosted pipeline offline. H3-Base is open for local inference, while the official H3-Context-IR orchestration layer and H3-Regenerate-2K stage remain hosted. For most home AI users, that makes H3 less of a simple model download and more of an infrastructure problem involving GPU memory, system RAM, model storage, workflow software, and increasingly a NAS or home server.
Can MiniMax H3 Really Run Locally?
Yes. MiniMax released H3 as an open-weight multimodal video model in August 2026 and provides H3-Base checkpoints that can be deployed on local hardware.
The official MiniMax H3 release describes the model as a general-purpose multimodal system that can understand combinations of text, images, video, and audio while generating video together with native stereo audio.
The local H3-Base model supports:
  • 4โ€“15 second video generation
  • 24 FPS output
  • 32 kHz stereo audio
  • text-to-video with audio
  • first-frame and last-frame conditioning
  • multimodal image, video, and audio references
  • multiple aspect ratios including 16:9, 9:16, 1:1, 4:3, and 21:9
The default H3-Base output uses a 768-pixel short edge. That distinction matters because the often-advertised โ€œup to 2Kโ€ capability belongs to the complete H3 system rather than to the basic fully local workflow alone.
Is MiniMax H3 Fully Local, or Does It Still Need the Cloud?
This is the most important distinction for anyone building a private H3 setup.
The complete official H3 workflow contains three major parts:
Component What It Does Can It Run Locally Today?
H3-Context-IR Interprets complex text, image, audio, and video references and turns them into structured generation instructions No, official implementation is hosted
H3-Base Generates the video and stereo audio Yes
H3-Regenerate-2K Regenerates the base result at 2K using the original multimodal context No, official implementation is currently hosted
MiniMax explicitly states in its official H3 repository that H3-Context-IR depends on multiple hosted models and services and is not part of the current open release. H3-Regenerate-2K is also not yet open-sourced.
That gives us two very different deployment models.
Fully local H3
Prompt or local reference media โ†’ H3-Base โ†’ local 768p-class video + stereo audio.
Your source files, generation process, and output can remain on your own machine. This is the same broader principle behind local AI processing: the more stages that stay inside your own network, the more control you retain over private data and service dependencies.
Hybrid H3
Hosted Context-IR โ†’ locally deployed H3-Base โ†’ hosted Regenerate-2K.
This can reproduce more of MiniMaxโ€™s full workflow, but it is no longer a completely offline or private pipeline.
If local-first AI is the goal, H3-Base is therefore the component that matters most.
What Hardware Do You Need to Run MiniMax H3 Locally?
There is no single MiniMax H3 VRAM requirement because the answer changes dramatically depending on precision, quantization, model pruning, offloading, resolution, workflow, and runtime.
The native model is large. H3 uses a 33-billion-parameter dense H3-Omni-Transformer, while its encoder uses the pretrained Qwen3-VL-32B weights. MiniMax notes that roughly 13B of the transformer parameters belong to AdaLN-related branches whose outputs can be precomputed and cached for inference, but this is still far beyond the memory footprint of a typical unquantized consumer model.
The local ecosystem has therefore focused heavily on pruning and quantization.
GPU Class Practical H3 Path What to Expect
8GB VRAM NF4 + aggressive CPU/RAM offloading Technically possible, but heavily memory constrained and slow
12โ€“16GB VRAM Pruned GGUF or NVFP4 model + quantized encoder + lightweight VAEs Useful for experimentation if you accept substantial offloading
24GB VRAM Pruned INT8 H3 + quantized text encoder Much more realistic consumer local-H3 target
48GB+ VRAM Higher-precision or less aggressively quantized workflow Less swapping and fewer compromises
Datacenter / multi-GPU BF16, distributed inference, SGLang or vLLM-Omni Best throughput and closest to native deployment
The MiniMax-maintained H3 integration index currently lists local paths ranging from an 8GB DiffSynth NF4 configuration to 12โ€“16GB quantized builds and 24GB ComfyUI setups.
That does not mean an 8GB GPU is a good H3 machine.
At the low end, the missing VRAM has to be compensated for by moving model components between GPU memory and system memory. That changes the problem from โ€œCan the model load?โ€ to โ€œHow long are you willing to wait for every generation?โ€
Minimum VRAM and usable VRAM are two different questions. This is why it helps to separate compute, memory, and storage bottlenecks before assuming that a faster SSD or NAS can compensate for insufficient GPU memory.
Can MiniMax H3 Run on 24GB GPUs Like the RTX 4090?
Yes, and 24GB is currently one of the more interesting targets for a serious home H3 setup.
Community and ComfyUI-oriented builds have reduced the diffusion model enough that a pruned INT8 H3 transformer can sit around the 20GB range, with the text encoder separately quantized and model components offloaded when necessary.
The important detail is that H3 is not one weight file.
A complete generation workflow may need:
  • the H3 diffusion transformer
  • Qwen3-VL-based text/vision encoder
  • video VAE
  • audio VAE
  • optional LoRAs or acceleration models
  • reference media
  • temporary latent and decode memory
So a โ€œ19GB modelโ€ does not automatically mean it fits cleanly inside a 24GB GPU with 5GB left over.
Runtime memory management matters almost as much as checkpoint size.
Can MiniMax H3 Run on 16GB or 12GB VRAM?
Yes, but this moves further into community-quantized territory.
The current ecosystem includes pruned GGUF and NVFP4 diffusion models paired with heavily quantized Qwen3-VL encoders. This can move H3 into the 12โ€“16GB class, but system memory and data transfer become increasingly important.
This is better viewed as a way to make H3 accessible than as the ideal configuration for frequent production work.
If you generate only occasional short clips, that trade-off may be perfectly acceptable. If H3 is part of an automated content workflow generating dozens of clips, throughput will matter much more than simply fitting the model into VRAM.
Can MiniMax H3 Really Run With Only 8GB VRAM?
There is now an 8GB path, but the number needs context.
DiffSynth-Studio provides an NF4 inference configuration whose stated VRAM floor is 8GB. At that level, however, extensive offloading means a large part of the workload is no longer staying resident on the GPU.
For an 8GB setup, the relevant question is therefore not:
โ€œDoes H3 launch?โ€
It is:
โ€œIs the resulting generation time acceptable for what I want to do?โ€
For testing H3, learning workflows, or generating an occasional clip, an 8GB experiment can be valuable. For repeated local video generation, more VRAM remains a major quality-of-life upgrade.
FL2VA vs Ref2VA: Which MiniMax H3 Model Should You Use?
H3-Base is released in two task-oriented variants. Choosing the right one can save both storage and workflow complexity.
H3-Base-FL2VA
FL2VA focuses on text and keyframe-driven generation.
Input Result
Text only Text-to-video + audio
First image First-frame-to-video
Last image Generate a sequence that ends on the supplied image
First + last images Generate a transition between two keyframes
If your goal is conventional text-to-video or image-to-video generation, FL2VA is usually the simpler place to start.
H3-Base-Ref2VA
Ref2VA is designed for richer multimodal reference conditioning.
According to the official H3 model card, Ref2VA can accept up to:
  • 9 images
  • 3 video clips
  • 3 audio clips
  • 12 reference files in total
This opens much more interesting local workflows: character reference, motion transfer, style reference, voice reference, source-video editing, or combinations of several media types.
But if you do not need those references, downloading and managing a second large checkpoint adds storage without necessarily improving a simple text-to-video workflow.
What Is the Easiest Way to Run MiniMax H3 Locally?
For most individual users, ComfyUI is currently the easiest entry point.
MiniMax lists ComfyUI alongside Diffusers, SGLang, and vLLM as supported deployment paths. ComfyUI also released day-one H3 support and has packaged lower-memory versions aimed at consumer GPUs.
The ComfyUI H3 release explains that pruning H3's modulation weights, INT8 quantization, custom kernels, and dynamic VRAM offloading significantly reduce the memory footprint compared with full-precision deployment.
A practical local setup looks like this:
  1. Install or update ComfyUI.
  2. Choose a MiniMax H3 text-to-video, image-to-video, or reference-to-video workflow.
  3. Download the matching diffusion model.
  4. Download the compatible H3 text encoder.
  5. Add the video and audio VAEs.
  6. Start with a short 768p-class generation.
  7. Watch both GPU memory and system RAM usage.
  8. Only then increase duration, resolution, or workflow complexity.
This order matters. Debugging H3 while simultaneously using a long clip, maximum references, large resolution, and aggressive extensions makes it difficult to tell whether a failure comes from the model, memory, nodes, or the workflow itself.
ComfyUI vs Diffusers vs SGLang vs vLLM-Omni for H3
The best runtime depends less on benchmark scores than on how H3 will be used.
Runtime Best For Why
ComfyUI Creators and home users Visual workflows, consumer-GPU quantization, reusable generation graphs
Diffusers Python developers Easy integration into custom scripts and applications
SGLang Dedicated H3 server Serving, multi-GPU deployment, API-style inference
vLLM-Omni AI infrastructure and multimodal serving OpenAI-compatible video serving and distributed deployment options
This distinction becomes important once H3 moves beyond an experiment.
A creator manually producing one video at a time needs a very different architecture from a household or studio where several devices submit generation jobs to one central GPU machine. The same separation already appears in practical guides to separate compute and storage: the NAS does not have to perform the heaviest inference simply because it owns the data.
Can MiniMax H3 Run as a Local Video Generation API?
Yes.
This is one reason H3 is interesting beyond desktop experimentation. SGLang and vLLM-Omni can turn H3 into a service instead of requiring users to interact directly with the model process.
For example, the vLLM-Omni H3 recipe exposes generation through an OpenAI-style /v1/videos interface.
That enables a different home AI architecture:
Laptop / phone / automation โ†“ Local H3 API โ†“ GPU server โ†“ Generated video + audio โ†“ Local storage
Once H3 is exposed this way, the GPU workstation no longer has to be the machine where the user edits prompts, manages projects, or stores finished media.
Compute and storage can become separate services.
How Much Storage Does MiniMax H3 Need?
Storage is one of the easiest H3 requirements to underestimate.
The official MiniMax H3 repository contains both task families, transformer weights, the Qwen-based encoder, VAEs, Diffusers layouts, and supporting files. The complete repository can occupy hundreds of gigabytes if everything is downloaded.
The MiniMax H3 integration index currently puts the complete original repository at roughly 464 GiB. Individual original FL2VA and Ref2VA transformer weights are each roughly 62 GiB before moving to smaller precision or pruned variants.
You do not need to download all of that to run H3.
A sensible home setup should instead separate:
  • active checkpoint
  • alternate quantizations
  • FL2VA and Ref2VA variants
  • text encoders
  • VAEs
  • LoRAs
  • reference images and video
  • generated output
  • archived projects
This is where local AI video starts to look much more like a storage workload than a traditional desktop AI application. A broader local AI and file storage architecture becomes useful once models, source media, outputs, and backups all need a permanent home.
Should MiniMax H3 Models Be Stored on a NAS?
Yes for some files, but not necessarily for every part of active inference.
A useful architecture is to split hot storage from capacity storage.
Keep on the GPU machine's local SSD
  • currently active H3 checkpoint
  • active text encoder
  • temporary generation files
  • cache
  • files repeatedly loaded during inference
Keep on the NAS or home server
  • alternate H3 quantizations
  • older model versions
  • FL2VA and Ref2VA archives
  • reference media library
  • completed videos
  • ComfyUI workflow backups
  • project assets
  • training data or LoRA datasets
This split avoids turning network storage into an unnecessary bottleneck during every model load while still preventing hundreds of gigabytes of AI assets from filling the workstation.
For a ZimaSpace-style home lab, this is the more useful way to think about H3: the GPU node generates, while the home server organizes and retains the AI workspace.
Does MiniMax H3 Need 10GbE Networking?
Not for the actual generation step. Once the active model and inputs are loaded on the GPU machine, H3 inference is overwhelmingly a local compute and memory workload.
Network speed becomes important when you repeatedly move very large checkpoints or high-bitrate media between a NAS and the GPU node.
For example, transferring a 20โ€“60GB model is very different from loading a 5MB document into a local LLM workflow.
That means AI video changes the value of faster home networking:
  • 1GbE is still adequate for storing completed projects and occasional model copies.
  • 2.5GbE meaningfully reduces friction when moving large model files.
  • 10GbE becomes more interesting when the NAS is a central model library for multiple AI workstations or when raw video assets move constantly.
The GPU does not become faster because your NAS has 10GbE. The surrounding workflow does. If the network itself becomes the bottleneck, the more useful comparison is 2.5GbE vs 10GbE NAS based on actual file sizes, storage throughput, clients, switches, and transfer frequency.
Can MiniMax H3 Run Completely Offline?
H3-Base can be used as part of an offline workflow once all required weights, dependencies, and reference files are already available locally.
That includes local text-to-video, keyframe-conditioned generation, and supported reference-driven H3-Base workflows.
However, the official Context-IR and Regenerate-2K services are currently hosted. A workflow that relies on those components is not completely offline.
This distinction is especially important for sensitive reference material. If the requirement is that images, videos, voices, or unreleased commercial assets never leave the local network, build the workflow around H3-Base and local preprocessing rather than assuming the entire official H3 stack is open.
The same rule applies to any fully offline local AI workflow: running the main model locally is not enough if authentication, preprocessing, storage, APIs, or other required stages still depend on the internet.
Can MiniMax H3 Generate 2K Video Locally?
Not through the complete official 2K pipeline today.
H3-Base produces the base result with a 768-pixel short edge. MiniMax's official 2K result uses H3-Regenerate-2K, which takes the base video together with the original context and regenerates the result rather than simply performing conventional super-resolution.
MiniMax says that Regenerate-2K is not yet included in the open release.
That does not prevent users from applying local upscaling or community workflows to an H3 output. It simply means those approaches should not be confused with MiniMax's official H3-Regenerate-2K pipeline.
For searches such as โ€œMiniMax H3 local 2K,โ€ this distinction is more useful than a simple yes-or-no answer:
local H3 generation is available; the official full 2K regeneration stage is not yet fully local.
Can MiniMax H3 Run on Apple Silicon?
The local ecosystem is expanding beyond NVIDIA GPUs.
One notable community project is h3.c, a Metal-native H3 inference implementation designed for Apple Silicon. The current ecosystem tracks support for text-to-video/audio, first-and-last-frame workflows, and ordered reference inputs.
This makes unified-memory Macs an interesting H3 platform because sufficiently large Apple Silicon systems can trade traditional discrete VRAM constraints for a larger shared memory pool.
However, Apple Silicon support should still be viewed separately from MiniMax's primary reference deployment path. Kernel maturity, performance, memory pressure, and feature parity can change quickly as community runtimes evolve.
Local MiniMax H3 vs Cloud H3: Which Setup Makes More Sense?
The answer depends on whether you value infrastructure ownership or convenience.
Factor Local H3 Hosted H3
Hardware You provide GPU, RAM, and storage Provider manages compute
Setup More complex Immediate
Private source media Can remain local with H3-Base workflows Media is sent to the hosted service
Per-generation API fee No API fee for local inference Usually usage based
Electricity / hardware cost You pay it Included in service pricing
Workflow customization High Depends on platform
Offline use Possible for H3-Base No
Official full 2K workflow Not completely local today Available through hosted components
For occasional AI video generation, cloud inference can make far more economic sense than buying a large GPU.
Local deployment becomes more interesting when the machine already exists, generation volume is high, source media is sensitive, workflows need extensive customization, or H3 is only one of several local AI services sharing the same hardware.
That is also why local versus cloud AI costs should be evaluated around workload frequency and hardware already owned rather than simply comparing an API price with the purchase price of a GPU.
Why Local AI Video Is Becoming a Home Server Problem
Running local language models trained users to think primarily about RAM and VRAM.
Video models change the equation.
A serious local video setup accumulates:
  • tens or hundreds of gigabytes of model weights
  • several quantizations of the same model
  • reference image libraries
  • reference audio
  • source footage
  • LoRAs
  • workflow files
  • temporary renders
  • multiple versions of final video
As a result, the long-term question is no longer only:
Can my GPU run this model?
It is increasingly:
Can my local infrastructure store, serve, organize, back up, and repeatedly use this entire AI media pipeline?
That is the point where a local AI workstation and a home server start to complement each other.
Browser / Editing PC โ”‚ โ–ผ ComfyUI or Local API โ”‚ โ–ผ GPU Compute Node โ”‚ โ”œโ”€โ”€ Active H3 model on local NVMe โ”‚ โ–ผ NAS / Home Server โ”œโ”€โ”€ Model archive โ”œโ”€โ”€ Reference media โ”œโ”€โ”€ ComfyUI workflows โ”œโ”€โ”€ Generated videos โ””โ”€โ”€ Backups
The GPU remains the expensive compute engine. The server becomes the persistent AI workspace.
This is also a useful way to understand an AI NAS architecture: storage does not need to replace the GPU workstation. Its value is providing a stable data, model, media, indexing, and backup layer around compute-heavy AI workloads.
Is MiniMax H3 Open Source?
MiniMax describes H3 as an open-source release and publishes the H3-Base model weights and implementation publicly. However, the model is released under the MiniMax H3 Community License Agreement rather than a conventional permissive software license such as Apache-2.0 or MIT.
The distinction is worth checking before commercial deployment, redistribution, or integrating H3 into a product. The applicable terms are available with the official model release.
It is also important not to equate the open H3-Base checkpoint with the entire H3 service stack: H3-Context-IR and H3-Regenerate-2K remain outside the current open release.
Is Running MiniMax H3 Locally Worth It?
H3 is unusually interesting for local AI because it is not merely another text-to-video checkpoint. It combines multimodal references, video generation, and native stereo audio in one system, while its open H3-Base weights give the local community enough access to build new runtimes, quantizations, ComfyUI workflows, APIs, and hardware-specific optimizations around it.
But H3 also shows where local generative AI is heading.
The challenge is no longer simply downloading a model onto one PC. A useful H3 environment may involve a GPU server, fast local SSDs, hundreds of gigabytes of model storage, a media library, workflow orchestration, remote access, and persistent network storage.
For a one-off test, ComfyUI and a quantized H3 checkpoint may be enough.
For a long-term self-hosted AI video stack, the more useful architecture is to separate compute, active model storage, bulk media storage, and workflow access. That structure will remain useful even when the next open video model replaces H3 at the top of the leaderboard.
November 2026 update: HyperFlow H3 Flash for shorter local video jobs
Video Rebirth published HyperFlow H3 Flash, a derivative of MiniMax H3 that compresses the roughly 31B transformer to about 14B parameters and supports joint video and stereo audio. It offers 4, 6 or 8 sampling steps, with six as the default. The release includes code, setup guides and ComfyUI workflows.
Video Rebirthโ€™s official HyperFlow H3 Flash release artwork
Video Rebirthโ€™s official HyperFlow H3 Flash release artwork. Original source
For one 5.2-second text-to-video-and-audio example, the publisher reports 83 seconds on an RTX 5090 and 152 seconds on an RTX 4090 in its ComfyUI INT8 configuration. These are vendor-run measurements for the indicated workflow and settings, with export excluded from the quoted ComfyUI timings. A 15-second clip, a different reference mode or another backend can take much longer. Video length, resolution, audio, text encoder and export should all be part of a fair comparison.
Choice When to evaluate it What to measure
ComfyUI INT8 safetensors The publisher provides a supported path and measurements on 24 GB and 32 GB RTX GPUs. Peak GPU memory, temporary disk use, workflow duration and output quality.
Q4KM GGUF The model card lists a 9.1 GB quantized transformer file and documents GGUF configurations. Full pipeline memory, including encoder, VAE and intermediate tensors.
Longer clips or multiple reference inputs Use the documented task and workflow for the intended input. Generation time, peak memory, audio sync and frame consistency.
A model file that fits on disk does not establish that a 16 GB GPU can run the full pipeline. Video Rebirth's release does not report tests on 16 GB GPUs. Start with the smallest documented clip, keep the full workflow fixed and change one setting at a time.
The developer labels HyperFlow as a derivative, and its model card points to the MiniMax H3 Community License Agreement. It lists territorial and use restrictions. Read the license and confirm authorization for your location and use before downloading or using the weights.
Frequently Asked Questions About Running MiniMax H3 Locally
Can I run MiniMax H3 locally for free?
You can run the open H3-Base weights on your own compatible hardware without paying a per-generation API charge. Local inference still has hardware, storage, electricity, and maintenance costs, and users should review the MiniMax H3 Community License for their intended use.
How much VRAM does MiniMax H3 need?
There is no single requirement. Community configurations currently range from an 8GB NF4/offloaded path to 12โ€“16GB quantized builds and more practical 24GB consumer-GPU workflows. Native or less aggressively quantized deployment requires substantially more memory.
Is 24GB VRAM enough for MiniMax H3?
Yes. Current pruned and quantized H3 configurations can run on 24GB GPUs, making this one of the most realistic local H3 hardware classes. The runtime still needs to manage the text encoder, VAEs, temporary tensors, and system-memory offloading.
Can an RTX 4090 run MiniMax H3?
Yes. The local H3 ecosystem includes single-RTX-4090 configurations using quantization and memory-saving techniques. A 4090 should be treated as a quantized H3 platform rather than a card capable of loading the complete original BF16 stack into VRAM at once.
Can MiniMax H3 run with 8GB VRAM?
DiffSynth-Studio provides an NF4 workflow with a stated 8GB VRAM floor. It relies heavily on offloading, so the result is better understood as a minimum-access configuration than a fast production setup.
Does MiniMax H3 work in ComfyUI?
Yes. ComfyUI supports H3 workflows for text-to-video, image/keyframe-to-video, and reference-driven generation, with local quantized model options designed to reduce memory requirements.
Does MiniMax H3 generate audio locally?
Yes. H3-Base jointly produces video and native stereo audio. The local workflow uses a separate H3 Audio VAE to decode the generated audio latent.
Can MiniMax H3 use reference videos and audio?
Yes. The Ref2VA model supports combinations of image, video, and audio references. The official model specification allows up to nine images, three video clips, three audio clips, and twelve reference files in total, subject to duration limits.
Can MiniMax H3 generate 2K video completely offline?
Not through MiniMax's complete official 2K pipeline today. H3-Base can run locally, but the official H3-Regenerate-2K stage is currently hosted. Local third-party upscaling should not be confused with H3-Regenerate-2K.
How much disk space should I reserve for MiniMax H3?
A single optimized workflow may require only a fraction of the complete repository, but users experimenting with both FL2VA and Ref2VA, multiple quantizations, encoders, VAEs, LoRAs, and reference media can quickly consume hundreds of gigabytes. Store active checkpoints on fast local storage and archive less frequently used assets on larger-capacity storage.
Can I store MiniMax H3 models on a NAS?
Yes. A NAS is useful for model archives, reference media, workflows, outputs, and backups. Frequently loaded checkpoints are usually better kept on a local NVMe drive attached to the GPU machine, then synchronized with or restored from the NAS when needed.
Does MiniMax H3 need an internet connection after installation?
H3-Base can operate locally after its model files and software dependencies have been downloaded. Workflows using MiniMax's hosted Context-IR or official Regenerate-2K service still require network access.
Which is better for H3, FL2VA or Ref2VA?
Use FL2VA for text-to-video and first/last-frame workflows. Use Ref2VA when the generation needs richer image, video, or audio references. There is little reason to maintain the larger multi-checkpoint setup if your workflow only needs basic text or keyframe conditioning.
Can I serve MiniMax H3 to multiple devices on my home network?
Yes. Serving frameworks such as SGLang and vLLM-Omni can expose H3 through a network API, allowing laptops, workstations, or automated applications to submit jobs to a central GPU server. Actual concurrency and throughput depend on GPU memory and the serving configuration.
