Private knowledge graphs expand home document search by linking repeated entities and relationships, giving retrieval paths beyond shared words or embedding similarity.
A household archive may mention “Maple Street,” “the old apartment,” a landlord’s surname, and a repair invoice without repeating one searchable phrase. Entity extraction can identify people, places, devices, dates, and projects, while resolution connects equivalent mentions. A graph then lets search traverse from one known node to related files that would otherwise remain semantically distant.
Entity Resolution Turns Mentions Into Reusable Nodes
Extraction finds candidate names, identifiers, locations, dates, and organizations in each document. Resolution decides whether two mentions refer to the same entity, then attaches source spans and relationship edges such as owned-by, located-at, or mentioned-in.
The entity knowledge graph approach builds an entity knowledge graph from source documents before generating group-level summaries. Its design shows how entity and relationship structure can support questions that require information distributed across many files.
A stable node allows one query to collect aliases and connected evidence. Searching a device nickname can reach its serial number, purchase receipt, maintenance notes, and room without requiring every document to share the nickname itself.
Graph Traversal Adds Relationship-Based Candidate Paths
Vector retrieval finds semantically close passages, while graph retrieval follows explicit edges from query entities. A search can start with a person, traverse to an address, then retrieve documents attached to a related account or event.
A broad survey of GraphRAG pipeline describes entity recognition, linking, graph construction, retrieval, and generation as distinct stages. That decomposition helps diagnose whether a miss came from an absent node, wrong edge, or retrieval policy.
Hybrid candidate generation often works better than graph-only search because narrative evidence may be similar without having extracted edges. The graph adds relational recall, while lexical and vector methods preserve paths that the entity model failed to represent.
A Wrong Entity Merge Spreads Errors Across Many Files
Households reuse first names, abbreviations, addresses, and device models. Merging two people or projects creates false paths; splitting one entity into several nodes hides connections. An incorrect edge can therefore contaminate more results than one bad embedding.
A document GraphRAG implementation evaluates knowledge-graph-enhanced document retrieval and describes the extra extraction and graph stages needed for robust search. Those stages add capability but also create new quality dependencies. This distinction remains visible during later household testing.
The boundary is unresolved identity. Keep source spans, confidence, aliases, and competing candidates; do not automatically merge nodes when the distinguishing attributes are missing. Private storage protects the graph from external exposure but does not make its relationships correct.
Audit Ten Graph Paths Back to Source Spans
Choose ten questions that require one or two relationship hops and record the expected entity, edge, document, and supporting span. Compare lexical, vector, graph-only, and hybrid retrieval with the same final candidate budget. The intermediate result must remain inspectable before automation follows.
Apply the source-lineage discipline from family archive lineage so every node and edge retains the document version and extraction span that created it. Inspect wrong results by extraction, resolution, edge, traversal, and ranking stage. That boundary should be measured separately under realistic operating conditions.
Use graph expansion only when it adds verified evidence without excessive false paths. Split ambiguous entities, retire edges when their source is deleted, and cap traversal depth where broad household nodes such as an address connect unrelated records.
What Factors Determine RAG Citation Accuracy in a Home Knowledge Base?
Learn why a relevant source can still be a wrong citation, which pipeline stages control support and coverage, and how to audit household RAG...
What Features Enable Reliable JSON Output From a Local LLM?
See which features enforce JSON syntax, which protect semantic correctness, and how to test a local model across schemas, prompts, and failure cases.
Local AI Data Lineage: Why Every Answer Needs a Traceable Source Path
Learn how source paths make local AI answers auditable, why citations alone are incomplete, and how to test lineage through updates and deletions.
