What Factors Determine RAG Citation Accuracy in a Home Knowledge Base?
RAG citation accuracy depends on retrieving the right source span and attaching it to the exact claim it supports, not merely listing relevant documents.
A home knowledge base can answer from an insurance policy, appliance manual, or scanned invoice and still cite the wrong page. The correct document may be present while the supporting sentence was split, ranked below another chunk, or linked to the wrong generated claim. Citation quality therefore reflects ingestion, retrieval, generation, alignment, and version control together.
Source and Chunk Quality Set the Evidence Ceiling
OCR errors, missing tables, stale copies, and lost headings corrupt the evidence before retrieval begins. Chunk boundaries must preserve the statement, qualifier, and identifying context needed to support a claim; a fragment containing only a number may match without proving what it measures.
Research comparing advanced chunking strategies finds that document segmentation choices change retrieval performance because fixed chunks can split concepts or mix unrelated material. Citation accuracy cannot exceed the quality of the span available to cite.
Metadata should retain document version, page, section, and coordinates so the citation resolves to inspectable evidence. Deduplication must prevent stale and current copies from competing without erasing the historical version used by an earlier answer.
Retrieval and Generation Must Preserve Claim-Level Alignment
A retriever can return a topically relevant page that does not entail the final sentence. Reranking should prioritize direct support, while generation should keep claim boundaries and source identifiers visible so each factual span maps to the evidence actually present in context.
Research on citation faithfulness distinguishes citation correctness from citation faithfulness and reports that apparently supporting citations may be attached after the model relied on other information. This is why surface agreement alone can overstate trust.
Citation coverage and correctness are separate. An answer may cite two claims accurately while leaving three unsupported, or cite every sentence to one broad document that supports none precisely. Both dimensions need independent measurement. This distinction remains visible during later household testing.
Post-Processing Can Fix Links but Not Missing Evidence
A verifier can compare each generated claim with candidate passages, move a citation to a better source, or remove an unsupported claim. This catches alignment mistakes after generation, but it cannot recover evidence that ingestion or retrieval never supplied.
The citation correction system cross-checks generated citations against retrieved articles and reports improved citation accuracy with limited extra cost. Its results demonstrate the value of a dedicated alignment stage after answer drafting. The intermediate result must remain inspectable before automation follows.
The failure boundary is a confident claim with no entailing source in the retrieved set. The verifier should abstain, retrieve again, or delete the claim rather than assigning the closest-looking citation and making the answer appear grounded.
Score Citation Support and Coverage Separately
Build fifty questions with verified answer spans across clean PDFs, OCR scans, tables, duplicate versions, and no-answer cases. Split every generated response into atomic claims, then judge whether each citation entails its claim and whether every factual claim has a citation.
Use the recall, precision, and coverage framework in RAG evaluation framework, but add citation entailment, version correctness, and resolvable page or region. Compare results by document type instead of reporting only one aggregate score. That boundary should be measured separately under realistic operating conditions.
Pass only when citations resolve to current, inspectable spans and unsupported claims trigger abstention or another retrieval attempt. When a source is relevant but does not entail the sentence, count it as an inaccurate citation rather than partial success.
