What Features Enable Reliable JSON Output From a Local LLM?
Reliable JSON from a local LLM requires schema-aware constrained decoding plus semantic validation; prompting alone cannot guarantee parseable or correct fields.
A home agent may need a tool call with an exact device ID, enum, number, and nested argument object. One missing quote breaks parsing, while perfectly valid JSON can still select the wrong device. Reliability therefore has two layers: the decoder must enforce permitted syntax, and the application must validate whether the completed values satisfy the real operation.
A Schema Defines More Than Curly Braces
JSON mode can restrict output to valid JSON, but a JSON Schema also describes required keys, types, enums, nesting, ranges, and whether extra properties are allowed. Clear field names and descriptions help the model choose content before structural constraints are applied.
A large JSON Schema benchmark benchmark evaluates constrained decoders across ten thousand real-world schemas and separates compliance, coverage, efficiency, and output quality. That separation shows why one โ€œvalid JSONโ€ percentage cannot describe practical reliability. This distinction remains visible during later household testing.
The modelโ€™s chat template and tool-call format must match the runtime. An unsupported schema keyword or tokenizer mismatch can weaken enforcement, while deeply recursive or ambiguous schemas can increase latency and content errors even when syntax remains valid.
Grammar-Constrained Decoding Blocks Invalid Next Tokens
At each generation step, a grammar engine tracks the valid parser state and masks tokens that would violate the schema. The model chooses only among allowed continuations, preventing missing delimiters, impossible keys, or free text outside the requested structure.
grammar-constrained decoding accelerates context-free-grammar execution with prechecked tokens, persistent parser state, and inference-engine integration. The work demonstrates that strong structural constraints can be applied with low overhead in local serving. The intermediate result must remain inspectable before automation follows.
Constraints guarantee membership in the language described by the grammar, not that the selected value is true. If both โ€œunlockโ€ and โ€œlockโ€ are valid enum values, the grammar cannot determine which one reflects the userโ€™s intent.
Validation and Repair Protect Meaning After Parsing
After parsing, deterministic validators should check identifiers, units, ranges, cross-field rules, permissions, and references to current state. A bounded repair pass can receive the validation errors and regenerate only the invalid object rather than letting malformed data flow downstream.
The structured output repair approach uses a lightweight post-processing model and evaluates both schema accuracy and content fidelity. It illustrates an alternative or complement when the main local model lacks complete native constraint support. That boundary should be measured separately under realistic operating conditions.
The failure boundary is semantically dangerous but syntactically valid output. High-risk tool calls need target resolution and approval outside the model, and repeated repair should stop after a small budget instead of silently changing intent until validation passes.
Build a Schema Reliability Test Matrix
Create schemas covering required fields, enums, nested arrays, nullable values, numeric bounds, Unicode, escaped text, and forbidden extra keys. Run representative and adversarial prompts at the intended temperature, context length, model quantization, and concurrency. The practical consequence appears when several sources compete for limited context.
Relate the results to the structured-tool-call shift in structured tool calls. Count parse success, schema compliance, semantic validity, repair attempts, latency, and unsafe target selections separately; do not merge them into one pass rate. This dependency should remain explicit in the final interface.
Deploy only schema features the runtime actually supports and reject objects that fail deterministic checks. If syntax reaches one hundred percent while semantic errors remain, improve field definitions and external validation rather than claiming the JSON pipeline is reliable.
