Home AI Result Verification: Why Tool Output Needs Independent Checks
Tool output needs independent checks because a successful call proves only that the tool returned, not that its result is correct, current, or complete.
A home agent can receive HTTP 200 from a storage tool while the wrong folder was measured, or accept “locked” from a device API before the physical state changes. Repeating the same call may reproduce the same fault. Verification adds a separate observation or rule between the returned value and any decision that depends on it.
Transport Success and Semantic Success Are Different
A tool response has several layers: transport status, parseable structure, schema validity, domain meaning, and observed side effect. Each can pass while the next fails. A numeric free-space field may be valid JSON yet use stale data or the wrong volume.
A practical result verification layer pattern places validation between raw agent output and downstream consumption. It distinguishes format checks, assertions, and evidence-based gates rather than treating fluent output as completion. This distinction remains visible during later household testing.
The orchestrator should represent these layers separately. A tool can be reachable but unverified, a proposed action can be valid but unexecuted, and an execution can report success before the target system confirms the changed state.
Independent Checks Need a Different Failure Path
Useful verification avoids asking the same component to endorse itself. File creation can be checked by reading metadata or a hash, a database write by a read on the authoritative store, and a smart-home command by a state sensor rather than the command acknowledgement.
verifiable agent state models an agent system as a nondeterministic component inside a verifiable state machine with explicit safety properties. The approach illustrates why constraints and runtime monitors belong in the orchestration layer, outside free-form model reasoning.
The strongest check depends on consequence. Low-risk search can validate schema and source presence, while a deletion needs exact target resolution, policy approval, and post-action observation. More checks are not automatically better if they share one corrupted source.
Verification Can Still Agree With the Same Wrong Assumption
Two LLM passes using the same prompt, context, and model are correlated, not independent. A second API endpoint may share the same database. Tests can also validate the implementation while missing the user’s actual intent. Agreement therefore raises confidence only when failure modes differ.
The independent verification loop workflow separates implementation, adversarial verification, and repair roles. Its core value is not the number of agents but the deliberate difference between producing an output and testing it against an external criterion.
The failure boundary is a consequential result with no independent observable truth. The system should surface uncertainty and request human confirmation rather than manufacturing confidence from repeated reasoning or majority votes among similar models. The intermediate result must remain inspectable before automation follows.
Design a Check for One Consequential Tool
Choose one tool that can change data or device state. Write its preconditions, expected response schema, domain invariants, authoritative postcondition, timeout, rollback boundary, and the exact condition that requires human approval before running any test.
Use the self-verification limits described in agent verification limits to separate claims the agent can inspect from physical outcomes it cannot directly observe. Inject wrong targets, stale responses, partial success, and false acknowledgements in a safe test environment.
Pass only if the verifier catches every injected semantic failure and prevents the dependent action. If the check depends on the same source or cannot observe the postcondition, label the result unverified and lower the agent’s authority.
