For a multi-VLAN home lab with self-hosted services, OPNsense is usually the stronger choice when the gateway is a dedicated x86 firewall whose main job is routing, policy, VPN, logging, and security inspection. OpenWrt is usually the better fit when you want to reuse supported router hardware, keep Wi-Fi and routing in one compact device, or build flexible AP and edge-router roles around Linux networking.
Neither platform wins because one “supports VLANs” and the other does not—both do. The decision is about operational shape. OPNsense gives a firewall-first workflow with interfaces, aliases, groups, stateful policies, VPNs, and IPS organized around a dedicated security appliance. OpenWrt gives a router-first Linux platform with DSA switching, VLAN-aware bridges, firewall zones, packages, and broad embedded-hardware flexibility.
Compare the Gateway Role Before Comparing Features
A multi-VLAN home lab typically has at least four jobs at the gateway: route between subnets, enforce which zones may initiate connections, provide internet access, and expose or tunnel selected self-hosted services. Once that gateway also handles DNS policy, remote access, traffic logs, intrusion prevention, or several exceptions between IoT, trusted clients, servers, and guests, maintainability becomes as important as raw throughput.
The existing ZimaSpace comparison of a consumer router versus a dedicated firewall establishes that architectural boundary. This comparison goes one layer deeper: if you already need a VLAN-capable open-source gateway, which software model fits the job better?
| Decision axis | OPNsense | OpenWrt |
| Primary design center | Dedicated firewall/router appliance | Flexible router, AP, switch, or embedded Linux gateway |
| Typical hardware | x86-64 appliance or PC | Many supported routers, SBCs, and x86 targets |
| Multi-VLAN policy workflow | Interface rules, groups, aliases, stateful firewall | Interfaces/bridges plus firewall zones and forwarding |
| Integrated Wi-Fi role | Usually separated to external APs | Often a core strength on supported router hardware |
| IDS/IPS workflow | Built-in documented Suricata integration | Possible through packages, but more device-dependent |
| Best fit | Central security gateway | Flexible router/AP/edge node |
Both Can Build VLANs, but They Express the Network Differently
OpenWrt's current DSA model exposes switch ports through Linux networking and supports multiple networks using VLAN-aware bridges and tagged trunks. The project's DSA tutorial shows separate bridge VLANs, tagged and untagged ports, and firewall-zone assignment for routed VLAN interfaces. That is enough to build trusted, IoT, guest, server, and management networks on suitable hardware.
OPNsense approaches the same problem from a firewall appliance perspective. It supports 802.1Q VLAN interfaces, while its stateful firewall rules are grouped by interface and can be combined with aliases and interface groups. Its aliases let multiple hosts, networks, or ports be represented as reusable policy objects.
For a lab with three VLANs and a dozen rules, either model is manageable. As the ruleset grows, the question becomes which mental model you prefer to recover at 2 a.m.: a Linux router configuration built from devices, interfaces, bridge VLANs, zones, packages, and UCI—or a dedicated firewall configuration built around interfaces, groups, aliases, policies, and security services.
OPNsense Is Stronger When Policy Becomes the Main Product
Suppose the lab has a trusted LAN, IoT VLAN, camera VLAN, server VLAN, guest network, management network, and VPN users. The difficult work is no longer creating VLAN tags. It is maintaining exceptions such as:
- Home Assistant may initiate selected connections to IoT devices.
- IoT devices may use DNS and NTP but cannot initiate sessions to the server VLAN.
- Cameras may reach the NVR but not the internet.
- Remote VPN users may reach management services but not guest clients.
- Public reverse-proxy traffic may reach only the intended application ports.
OPNsense is especially comfortable here because the firewall is its primary interface. It has documented rule ordering, state tracking, groups, categories, logging, aliases, NAT, and policy-based routing. Its interface groups can apply common policy to multiple network interfaces without duplicating the same rule everywhere.
This does not mean OpenWrt cannot express the same policies. It can. The difference is operational emphasis: OPNsense assumes the device exists to be a firewall, whereas OpenWrt is a general router distribution that can be shaped into many network roles.
OpenWrt Is Stronger When Hardware Flexibility and Wi-Fi Matter
OpenWrt's advantage appears when the gateway is also an access point, travel router, low-power edge device, or repurposed consumer router. Its VLAN and switch model reflects the variety of integrated switch hardware and DSA migration states across devices.
This broad hardware model is useful but introduces a requirement that OPNsense users encounter less often: verify the exact device target, switch architecture, Wi-Fi chipset support, flash/RAM capacity, and upgrade path before designing the network around it. Two routers running OpenWrt can have very different port, radio, and acceleration capabilities.
If you already own a well-supported OpenWrt router that can route your internet connection at the required speed, run the needed VLANs, and host the necessary VPN packages, replacing it solely because OPNsense has a more firewall-oriented UI may add hardware without solving a real problem.
OPNsense Assumes More Dedicated Hardware
OPNsense currently targets x86-64 systems. Its official hardware guide lists 8 GB RAM and a 1.5 GHz multi-core CPU as its recommended specification for running the standard feature set across typical use cases, while lower specifications can run reduced or lighter configurations.
That is a different deployment philosophy from flashing OpenWrt onto a compact router. A small x86 firewall with multiple quality NICs costs more and consumes another power outlet, but it also separates routing and security from Wi-Fi. Access points can then be upgraded, rebooted, or repositioned without replacing the core gateway.
For a home server environment that is already becoming infrastructure-heavy, this separation is often an advantage. For a small apartment with one AP and three VLANs, it can be unnecessary complexity.
VPN Support Is Strong on Both Platforms
WireGuard does not force the decision either. OpenWrt has current WireGuard configuration guidance, and OPNsense documents both road-warrior and site-to-site WireGuard workflows in its VPN documentation.
The real difference is what happens around the tunnel. If VPN users need their own policy objects, multiple destination groups, selective routing, extensive logging, or several internal zones, the firewall-centric OPNsense workflow becomes attractive. If the VPN is simply a way for a few personal devices to reach the LAN through a compact router, OpenWrt can remain the simpler system.
IDS/IPS Pushes the Decision Toward OPNsense
When the gateway must inspect traffic rather than merely route and filter it, hardware sizing becomes more important. OPNsense has a documented Suricata intrusion prevention workflow, including interface selection and IPS-specific hardware-offload considerations.
OpenWrt can run additional security packages on sufficiently capable hardware, but the usable result depends much more on the particular router's CPU, RAM, storage, and acceleration support. If always-on IDS/IPS is a real requirement, choosing the firewall software and the x86 hardware together is usually easier to reason about than treating inspection as another package on a resource-constrained Wi-Fi router.
Do Not Assume OPNsense Is Automatically Faster
Throughput depends on CPU architecture, NIC quality, packet size, NAT, VPN cryptography, IDS/IPS, traffic shaping, PPPoE, hardware offload, and the actual OpenWrt device. A powerful OpenWrt x86 box can outperform a weak OPNsense appliance, while a well-sized OPNsense machine can outperform an inexpensive embedded router once multi-gig routing and inspection are enabled.
Therefore compare the hardware required to sustain your real feature set. Test internet routing, inter-VLAN routing, VPN throughput, and CPU utilization with the exact services you intend to keep enabled. A headline routing number without the firewall rules and VPN/inspection features is not the number your home lab will see.
The Best Architecture Is Often OPNsense at the Core and OpenWrt at the Edge
These platforms do not have to replace one another. A particularly clean multi-VLAN design is:
Internet
OPNsense x86 gateway
802.1Q trunk
Managed switch
|---------------- Home servers / NAS
|---------------- Wired clients
OpenWrt access point(s)
|---------------- Trusted Wi-Fi
|---------------- IoT Wi-Fi
|---------------- Guest Wi-Fi
In this topology OPNsense owns inter-VLAN routing, policy, VPN, logs, and optional IPS. OpenWrt provides Wi-Fi radios and maps SSIDs to VLANs without having to be the central security appliance. This also aligns with the ZimaSpace guidance on guest networks versus VLANs: the VLAN tag is only the segmentation mechanism; the routed firewall policy determines what the zones can actually reach.
Decision Matrix for a Self-Hosted Home Lab
| Your priority | Better starting point | Why |
| Dedicated central firewall with many VLAN policies | OPNsense | Firewall-first rule, alias, logging, and interface workflow |
| Reuse a supported Wi-Fi router | OpenWrt | Integrated router/AP role and broad device ecosystem |
| IDS/IPS at the gateway | OPNsense | Documented Suricata workflow and easier x86 sizing |
| One compact box for routing and Wi-Fi | OpenWrt | Designed for embedded router hardware |
| Several APs plus a managed switch | OPNsense core + OpenWrt APs | Separates security policy from radio hardware |
| Learning Linux networking deeply | OpenWrt | DSA, bridges, UCI, packages, and Linux network plumbing are visible |
Final Verdict
Choose OPNsense when the multi-VLAN gateway has become security infrastructure; choose OpenWrt when the gateway is still primarily a flexible router or access point. For a self-hosted home lab with several VLANs, public services, VPN users, and policy exceptions, a dedicated OPNsense box usually produces the clearer long-term operating model.
OpenWrt remains an excellent choice for smaller networks and is often the better companion rather than competitor: use it on access points or edge routers while the dedicated firewall owns inter-VLAN policy.
FAQs
Can OpenWrt route multiple VLANs?
Yes. Current OpenWrt supports DSA VLAN-aware bridge configurations, tagged trunks, separate interfaces, and firewall zones on supported hardware.
Does OPNsense require a managed switch?
Not for every setup, but a managed VLAN-capable switch is normally required when one physical trunk must carry several wired VLANs beyond the firewall appliance.
Which is easier for Wi-Fi VLANs?
OpenWrt is often easier when the same supported device provides the radios. OPNsense is commonly paired with separate VLAN-aware access points.
Should I replace working OpenWrt with OPNsense?
Only if the dedicated-firewall model solves a real limit such as rule complexity, inspection, independent gateway recovery, or hardware throughput. A functioning OpenWrt gateway does not need replacement merely for architectural purity.
Product Comparisons
