Codex, Claude Code, OpenClaw, and Hermes can all write code and use tools, but they are not four versions of the same product. Codex and Claude Code start from software development: understanding repositories, editing files, running commands, testing changes, and helping developers ship code. OpenClaw and Hermes can also perform technical work, but their center of gravity is broader: persistent agents, messaging, automation, memory, model choice, and workflows that can remain useful after a coding session ends.
That makes the choice less about finding a universal “best AI agent” and more about deciding what you want the agent to become. If most of your work begins and ends inside a codebase, Codex or Claude Code is usually the cleaner starting point. If you want an agent that stays available on a home server, connects to other services, runs recurring jobs, or becomes part of a longer-lived personal AI environment, OpenClaw and Hermes deserve a different kind of evaluation.
Codex vs Claude Code vs OpenClaw vs Hermes at a Glance
The fastest way to separate these four tools is by their primary job. All four can overlap, and their feature sets continue to expand, but their default workflows still point users in different directions.
| Decision Axis | Codex | Claude Code | OpenClaw | Hermes |
| Core identity | Coding agent | Coding agent | Self-hosted agent gateway | Persistent general-purpose agent |
| Repository work | Core use case | Core use case | Supported, but not the only focus | Supported, but not the only focus |
| Model flexibility | OpenAI-centered official experience | Claude-centered | Multi-provider | Provider-agnostic |
| Long-running personal use | Possible | Possible | Core use case | Core use case |
| Memory / continuity | Project and session oriented | Project and session oriented | Agent workspaces and session stores | Persistent memory and learning |
| Extensions | Skills, tools and MCP | Skills, plugins, hooks, subagents and MCP | Skills, tools, providers and agents | Skills, plugins, MCP and providers |
| Recurring automation | Available in broader Codex workflows | Possible through tooling and integrations | Strong fit for always-on automation | Native scheduled agent tasks |
| Best starting point for | OpenAI-centered developers | Claude-centered developers | Personal automation and messaging | Custom persistent agent workflows |
The key distinction is not that Codex and Claude Code can code while OpenClaw and Hermes cannot. All four can participate in coding workflows. The difference is whether coding is the center of the product or one capability inside a broader agent environment.
What Are We Actually Comparing?
A useful comparison needs one shared problem. Otherwise Codex wins a repository benchmark while OpenClaw wins a messaging test and neither result helps you choose between them.
For this comparison, imagine one developer with an unfamiliar repository, recurring maintenance work, external tools, and an interest in keeping the same AI environment useful after the immediate coding task is complete. We compare all four agents across the same eight decision axes: coding, tool execution, model flexibility, extensibility, long-running automation, memory, security, and maintenance.
This also means we are comparing complete agent systems rather than only the language models underneath them. The model matters, but so do the agent loop, available tools, context construction, permissions, skills, memory, and the amount of infrastructure hidden or exposed to the user.
How Do All Four Handle the Same Coding Project?
Consider a simple prompt: “Open this unfamiliar repository, find why the test suite is failing, modify the relevant files, rerun the tests, and explain what changed.” All four agents can participate in a workflow like this, but Codex and Claude Code reach the task through a more coding-native path.
Codex is built around an agent loop that lets the model inspect a working environment, invoke tools, interpret results, modify files, and continue until the software task reaches a usable state. OpenAI's technical explanation of the Codex agent loop makes this distinction explicit: the harness coordinates the model, tools, prompts, and execution logic needed for software work.
Claude Code follows a similarly direct path. It can understand a codebase, edit files, run commands, work with Git-oriented development tasks, and connect to additional systems through MCP. Anthropic's Claude Code workflow is designed around moving from a developer request to actions inside the actual project environment rather than returning a code snippet for the developer to apply manually.
If repository work is your primary requirement, the difference between these two will often come down to the model ecosystem you prefer, how each agent behaves on your particular codebase, and which surrounding development workflow fits your team. ZimaSpace has separate guides to Codex skills for coding workflows and Claude Code agent skills if extensibility becomes part of that decision.
OpenClaw and Hermes should not be treated as incapable alternatives. Both can execute technical tasks and interact with files, tools, or terminal-style environments. The difference becomes clearer after the bug is fixed: Codex and Claude Code have completed the job they were primarily designed around, while OpenClaw and Hermes are more naturally evaluated by what else you want the same agent to keep doing.
Coding Agent vs Personal Agent: Where the Four Start to Separate
The four-way comparison becomes much clearer when the coding task ends.
Codex and Claude Code begin from a developer relationship with the agent: there is a repository or engineering objective, and the agent helps move that work forward. Their ecosystems are expanding into broader automation and agent workflows, but software development remains the organizing center.
OpenClaw starts from a different architecture. A self-hosted Gateway connects an agent environment to communication channels and other services so the assistant can remain reachable outside a single terminal session. That makes a request such as “check this repository” only one potential task alongside notifications, messaging, scheduled operations, or other personal automation.
Hermes follows a similarly persistent direction but emphasizes accumulated capabilities. Its memory and skill systems are intended to preserve useful facts and reusable procedures across sessions, allowing the agent environment to become more adapted to recurring work over time.
The important distinction is therefore no longer “Can it code?” All four can. The better question is:
Is coding the destination, or is coding one capability inside a larger persistent agent?
If it is the destination, Codex and Claude Code deserve to be evaluated first. If coding is only one part of a system that should also communicate, remember, schedule, retrieve, monitor, or operate other services, OpenClaw and Hermes become much more relevant.
Which Agent Gives You More Freedom to Choose Models?
Model choice exposes one of the clearest architectural tradeoffs in this comparison: integration versus flexibility.
Codex's official experience is built around OpenAI's coding stack. There is more technical flexibility underneath the CLI than the product label alone suggests—the Codex harness can work with a configurable Responses API-compatible endpoint—but the most integrated user experience remains OpenAI-centered.
Claude Code takes a similarly integrated approach around Claude models. That simplifies the relationship among model behavior, agent prompts, coding tools, and Anthropic's surrounding platform, but it also means Claude is the model family around which the product is designed.
OpenClaw makes provider selection more explicit. Its configuration uses a provider/model model structure and supports a broad provider catalog plus custom providers. The official OpenClaw model provider directory reflects a design in which changing the model can be a normal configuration decision rather than changing the entire agent application.
Hermes is also designed around provider flexibility and can operate with different model backends. This is attractive when you want to test multiple APIs, move between hosted and local inference, or avoid tying every workflow to one model vendor.
That flexibility is not automatically better. Vendor-centered agents can tune their interface, prompting, tooling, and product features around a smaller set of assumptions. Multi-provider agents give you more architectural freedom, but you take on more responsibility for choosing models, endpoints, credentials, context limits, and compatibility.
Skills, MCP, Plugins, and Subagents: Which Agent Is Easier to Extend?
It would be outdated to divide these tools into “closed coding agents” and “extensible open agents.” All four now have meaningful extension mechanisms. What changes is which layer of the agent you are allowed to extend.
Codex supports reusable skills and external tools, making it possible to package recurring development procedures instead of repeatedly explaining the same process. Claude Code goes further into an explicit extension ecosystem where skills, hooks, subagents, MCP connections, and plugins can become part of a project's working environment.
OpenClaw treats skills, tools, agents, messaging channels, and model providers as pieces of a broader self-hosted gateway. Hermes combines skills with plugins, MCP servers, memory providers, scheduled jobs, and other configurable agent components.
This creates two different reasons to install an extension. A developer may add a Codex or Claude Code skill because a coding procedure should become repeatable. A persistent-agent user may add an OpenClaw or Hermes integration because the agent needs a new place to act, a new source of data, or a new long-term capability.
There is no advantage in maximizing extension count. Every additional tool increases the surface the model has to select from and every third-party integration introduces another permission and maintenance boundary. Our explanation of why you should limit an AI agent's tool scope applies to all four products, not only self-hosted agents.
Which One Is Better for Long-Running and Always-On Work?
This is where a simple coding benchmark stops being sufficient.
If the task is “fix this pull request today,” Codex and Claude Code are operating directly in their strongest territory. But an always-on workflow introduces a different set of requirements: scheduling, service uptime, messaging delivery, persistent state, background execution, credentials, logs, and a way to recover when the agent or host restarts.
OpenClaw is naturally aligned with this model because its Gateway is intended to run on your machine or server and bridge AI agents with communication channels. A home-server installation therefore makes sense when the goal is not merely to invoke OpenClaw occasionally but to keep the assistant reachable. If that is the direction you are considering, the OpenClaw home server deployment guide covers the always-on gateway approach.
Hermes provides another strong route to persistent automation. Its scheduler supports one-time and recurring agent jobs, including tasks that load skills and deliver results back through connected channels. The official Hermes scheduled task system makes recurring automation a first-class part of the agent rather than requiring every task to begin with an interactive prompt.
For a comparable self-hosted deployment path, see our guide to self-host Hermes Agent on a home server.
The practical split is therefore conditional. For focused engineering sessions, start with the coding-first tools. For a persistent assistant that should remain available between projects, OpenClaw and Hermes deserve more weight.
Memory and Continuity: Does the Agent Remember More Than the Current Task?
“Memory” is an easy word to compare badly because project instructions, conversation history, resumable sessions, and personal long-term memory are not the same feature.
Codex and Claude Code can retain and reuse project context through their development workflows, instructions, sessions, and extensions. That is valuable when you return to a repository, but it should not automatically be interpreted as the same kind of long-term personal memory used by a persistent assistant.
OpenClaw organizes agents around their own workspace and session state. That architecture is useful when separate agents need separate histories, credentials, or responsibilities.
Hermes makes persistent memory more explicit. Its learning system separates facts the agent should remember from procedures that should become skills. Over time, this is intended to let the agent reuse both what it has learned about an environment and how it previously completed recurring work.
This makes Hermes particularly interesting when continuity itself is a requirement, but it also creates a governance problem: old information can become stale. Persistent memory is useful only when the agent can distinguish a current decision from an obsolete one. A longer memory is not automatically a more accurate memory.
Which Agent Is Safer to Give Shell, Files, and Credentials?
There is no safe comparison that reduces this question to a single “security score.” All four can become dangerous when given permissions broader than the task requires.
A coding agent may be allowed to edit a repository, run shell commands, install dependencies, access Git credentials, or call external tools. A persistent personal agent may add messaging credentials, browser sessions, API keys, private documents, scheduled jobs, and always-on network access. The second environment often has a larger potential blast radius simply because it remains active longer and touches more systems.
The important controls are therefore similar across products: restrict filesystem scope, separate sensitive credentials, require approval for consequential actions, limit network access where practical, review third-party skills and MCP servers, and avoid giving one agent every tool “just in case.”
Codex separates execution restrictions from approval behavior, while Claude Code provides permission rules around tool use and external integrations. OpenClaw and Hermes also expose their own controls for tools, credentials, sandboxes, or plugin behavior. The implementations differ, but the architectural principle is the same: an agent should receive the smallest capability set that can complete the intended job.
This becomes especially important for OpenClaw and Hermes when you turn them into always-on services. The same persistent availability that makes them useful also means a poorly scoped credential or autonomous tool remains available after you have stopped actively watching the session.
Which One Is Easier to Set Up and Maintain?
If you want the shortest path from installation to software work, Codex and Claude Code usually expose fewer infrastructure decisions. You install the development agent, authenticate it, give it access to the project, and begin working. Extensions can be added later.
OpenClaw and Hermes can also be installed quickly, but their value increases as you add persistent components: providers, messaging channels, skills, browser sessions, cron jobs, containers, memory, local model endpoints, or multiple agents. At that point you are maintaining an AI service rather than only invoking a developer tool.
Hardware requirements also split into two separate problems. If OpenClaw or Hermes sends inference to a cloud API, the local machine mainly runs the agent, tools, browser, containers, storage, and supporting services. If the same machine also runs the language model locally, RAM, VRAM, context length, concurrency, and model size suddenly dominate the hardware plan.
For the first case, compare our OpenClaw hardware requirements with the Hermes Agent hardware requirements.
If your plan is to consolidate persistent agents, storage, containers, and optional local inference on one expandable server, the hardware becomes part of the agent architecture. A dedicated local AI agent hardware platform such as ZimaCube 2 Personal Cloud Home NAS can provide the storage and expansion base, but the GPU and memory you actually need still depend on the local model rather than on Codex, OpenClaw, or Hermes alone.
Codex vs Claude Code vs OpenClaw vs Hermes: Which One Should You Choose?
Choose Codex if software engineering is the main job and you want an OpenAI-centered coding workflow. It is the most natural fit when your prompts usually begin with a repository, a bug, a feature, a test suite, or another concrete engineering objective.
Choose Claude Code if software engineering is the main job and you prefer the Claude ecosystem. Its strengths become especially relevant when you want a coding-native agent that can be extended with skills, subagents, hooks, and MCP-based tools while staying closely aligned with Claude.
Choose OpenClaw if you want the agent to become an always-available personal gateway. It makes more sense when messaging channels, multiple providers, remote interaction, automation, and a self-hosted service are central requirements rather than optional additions to a coding tool.
Choose Hermes if you want a persistent, customizable agent where memory, reusable skills, model flexibility, and recurring tasks are part of the core workflow. It is especially interesting when the objective is to build a personal agent environment that becomes more useful across repeated tasks rather than optimize only one coding session.
The four products are therefore not arranged on one ladder from weakest to strongest. They occupy different points on a workflow spectrum:
| Your Primary Need | Better Starting Point |
| OpenAI-centered software development | Codex |
| Claude-centered software development | Claude Code |
| Always-on personal assistant and messaging gateway | OpenClaw |
| Persistent memory, skills and customizable agent workflows | Hermes |
| Maximum model/provider choice | OpenClaw or Hermes |
| Minimum infrastructure ownership for coding | Codex or Claude Code |
Codex and Claude Code start from software development. OpenClaw and Hermes start from the idea that the agent may still be working for you after the coding task is finished. That difference is more useful for choosing between them than any single benchmark score.
Which is better for coding: Codex, Claude Code, OpenClaw, or Hermes?
If coding is the primary task, start by comparing Codex and Claude Code. Both are designed around repository understanding, file modification, command execution, debugging, and software-development workflows. OpenClaw and Hermes can participate in coding tasks, but their broader value appears when coding must connect to persistent automation, messaging, memory, or other long-running agent work.
Is OpenClaw a coding agent like Codex or Claude Code?
Not exactly. OpenClaw can run technical and coding workflows, but its architecture is broader: it is a self-hosted gateway that connects agents to messaging channels, model providers, workspaces, and persistent services. Treating it only as a Codex replacement misses much of what makes OpenClaw different.
Can OpenClaw or Hermes use local AI models?
Yes, both are better suited than a tightly vendor-centered workflow when model/provider flexibility is a requirement. The practical challenge is hardware: connecting an agent to a local endpoint is easy compared with providing enough RAM or VRAM for the model, context length, concurrent agents, and other services. Decide on the local model first, then size the server around that workload.
Which is better for an always-on self-hosted AI agent?
OpenClaw and Hermes are the more natural starting points. OpenClaw emphasizes the always-available Gateway and communication-channel model, while Hermes combines persistent memory, skills, messaging, and scheduled agent tasks. Codex and Claude Code can be automated, but always-on personal infrastructure is not the main reason most users choose them.
Do I need powerful local AI hardware to run these agents?
Not necessarily. If the agent calls a hosted model API, the local machine mainly needs enough resources for the agent runtime, browser automation, containers, storage, and other tools. Powerful local AI agent hardware becomes important when you also want to run model inference locally, especially with larger models, long context windows, GPUs, or multiple simultaneous agents.
Product Comparisons
Plex With Overseerr vs a Standalone Plex Stack: Which Fits Better?
Choose Overseerr only when request management solves a recurring household workflow. Otherwise standalone Plex keeps fewer services, secrets, and recovery step
More CPU Cores vs Faster Cores for Plex: Which Matters More?
Choose Plex CPU shape by the actual bottleneck: parallel software work favors more cores, while other paths may favor speed, media engines, or storage.
How to Threat-Model Plex Remote Access: Public Exposure vs Private VPN
Compare public Plex exposure with VPN access as security boundaries: attack surface, client support, revocation, routing, and operational failure all matter.
