Local AI inference can hold a GPU near sustained utilization for much longer than a short desktop burst. In a small case, the buying decision must therefore match GPU power, cooler behavior, fresh-air access, exhaust, power cables, and acceptable noise—not merely card length and VRAM capacity.
Convert model requirements into sustained heat
Choose the model size, quantization, context length, batch size, concurrency, and runtime first. These determine VRAM pressure and how continuously the GPU will work. A larger card that fits the model but throttles throughout a long job is not the faster system in practice.
Use the card’s board-power target as a planning input, then include CPU, memory, storage, motherboard conversion losses, and PSU heat in the same enclosure. Compact systems recirculate heat easily because components share a small air volume.
Consider a lower-power GPU, an enforceable power limit, or a slightly larger case when the workload values steady throughput more than peak benchmark speed.
Check geometry beyond the published card dimensions
Verify card length, slot thickness, height, riser position, fan clearance, intake-panel restriction, exhaust path, and the bend radius of every power connector. A nominal fit can still press a cable against the side panel or place GPU fans against a solid surface.
Understand the cooler type. An open-air card releases much of its heat inside the case and needs strong exhaust; a blower sends more heat out the bracket but may be louder. Radiators add pump, tube, mounting, and warm-air-routing constraints.
Use the thermal checklist before selecting the GPU and enclosure as a pair.
| Scenario | Better fit | Decision boundary |
| VRAM fits but heat does not | Lower power or larger case | Sustained output matters |
| Open-air GPU | Direct intake plus exhaust | Prevent hot-air recirculation |
| Long AI workload | Log clocks and hotspot trends | Test after thermal soak |
Measure the temperatures that decide stability
Monitor core, hotspot, memory junction where exposed, fan speed, clock, power, CPU temperature, and ambient room temperature during the intended inference or fine-tuning workload. A short synthetic test may miss enclosure heat soak.
Compare clocks and throughput from the beginning and end of a long run. Falling clocks at high utilization, rising fan noise, errors, or system resets can reveal thermal or power limits even when the displayed core temperature appears acceptable.
A related ZimaSpace local AI GPU checklist connects VRAM and software fit with power, cooling, and physical installation.
An independent airflow and stability guide explains why long loads reveal cooling and power problems that short tests can hide.
Set purchase limits for heat, noise, and serviceability
Define acceptable sustained throughput, room temperature, component temperatures, and sound level before buying. Include summer ambient conditions and dust accumulation rather than validating only in a cool, clean room.
Choose a PSU with the required native connectors and realistic transient margin. Do not compress adapters or sharp cable bends into a hot zone, and keep intake filters, fans, and GPU surfaces accessible for inspection and cleaning.
Approve the build when it sustains the target AI workload without progressive throttling, excessive noise, connector stress, or heat-driven instability. If it fails, reduce power, improve airflow, or enlarge the case before buying a hotter card.
Buying Guide
