What Causes WebSocket Reconnect Loops in a Remote Home AI Interface?
WebSocket reconnect loops occur when the connection repeatedly fails or closes while the client retries without correcting the underlying handshake, session, or path condition.
A remote home AI interface may load over HTTPS yet continually flash โ€œreconnectingโ€ because ordinary page requests and upgraded WebSocket connections follow different proxy behavior. Idle timeouts, missing upgrade headers, expired tokens, NAT changes, heartbeat failures, or broken state replay can close the socket. Immediate retries then recreate the same condition and may overload the server.
Handshake and Authentication Failures Prevent a Stable Upgrade
The browser begins with an HTTP upgrade request carrying origin, cookies or tokens, protocol headers, and a WebSocket key. A reverse proxy, tunnel, or backend can reject the path, strip headers, redirect, or accept with an authentication state that expires immediately.
A troubleshooting account of proxy upgrade failures shows a self-hosted interface repeatedly reconnecting when its WebSocket path through a proxy is not established correctly. The signature is repeated handshake status codes before any stable session duration.
If the connection opens and carries messages for a predictable interval, the initial upgrade succeeded. Shift attention to idle timeout, token lifetime, heartbeat, or path changes rather than repeating header changes blindly. This distinction remains visible during later household testing.
Timeouts and Heartbeat Gaps Close Otherwise Healthy Sessions
Proxies, load balancers, NAT devices, VPNs, and backends maintain different idle timers. If neither side sends useful traffic or ping-pong frames within the shortest timer, an intermediary can drop state and leave one endpoint unaware until its next write.
An engineering explanation of WebSocket keepalive timing connects long-lived sockets, keepalive, and proxy timeouts. The diagnostic signature is a consistent connection lifetime or closure during quiet periods rather than at handshake. The intermediate result must remain inspectable before automation follows.
Remote path changes between Wi-Fi, cellular, VPN, and relay routes can create similar closes without a fixed period. Record close codes and heartbeat round trips from both endpoints; browser errors alone often omit the failing intermediary.
Retry and State Recovery Can Sustain the Loop
A client that retries immediately with no cap can synchronize tabs or household devices into a reconnect storm. Even after transport succeeds, missing subscription state, rejected sequence numbers, or an expired resume token can make the application close and reconnect again.
A guide to backoff and state recovery recommends exponential backoff, jitter, and explicit session restoration. Those controls do not repair the root failure, but they prevent retries from amplifying it while diagnostics and recovery proceed.
The failure boundary is a deliberate reconnect after network movement or server deployment. A loop requires repeated failure without useful session progress; occasional bounded recovery with state replay is expected remote-interface behavior. That boundary should be measured separately under realistic operating conditions.
Classify the Loop by Connection Lifetime and Close Stage
Record DNS, TLS, upgrade request and response, proxy route, authentication expiry, socket-open time, heartbeat, message sequence, close code, backend log, VPN or NAT change, retry delay, session resume result, and concurrent client count for each attempt.
Compare LAN and remote behavior with remote home-server paths. Test direct LAN, reverse proxy, VPN, idle traffic, token expiry, server restart, and network handoff separately while preserving the same browser build. The practical consequence appears when several sources compete for limited context.
Fix the earliest failing stage: handshake routing, timeout and heartbeat, authentication refresh, or state replay. Add capped exponential backoff with jitter in every case so one home-network outage cannot turn a recoverable disconnect into a self-sustaining request flood.
