Vector-index segments multiply faster than documents when ingestion flushes many small immutable batches or compaction cannot merge replacement and deleted records promptly.
One household PDF can yield hundreds of chunks, and updating it may write new vectors plus tombstones for old ones. Frequent commits, multiple vector fields, metadata indexes, replicas, and retry generations each create physical structures beyond the document count. If background compaction falls behind, these small segments remain visible and accumulate faster than the library grows.
Flush Policy Converts Small Ingestion Batches Into Segments
Many indexes buffer writes in memory and seal an immutable segment when a size, time, transaction, or memory threshold is reached. A watcher that commits each file or chunk can create many underfilled segments. This distinction remains visible during later household testing.
An explanation of immutable index components shows how write-optimized trees flush in-memory data into multiple append-only components. Vector stores differ internally, but the segment-growth signature is the same: segment creation tracks flush count rather than document count.
Compare vectors per segment and flush reason. Small, evenly timed segments implicate commit cadence or memory thresholds; large segments appearing only during bulk imports are normal ingestion structure. The intermediate result must remain inspectable before automation follows.
Updates and Tombstones Create More Records Than New Documents
Replacing one file can write every new chunk while retaining tombstones or obsolete vectors until cleanup. Metadata, sparse, dense, and quantized representations may live in separate segment families, and replicas multiply each family again. That boundary should be measured separately under realistic operating conditions.
A detailed view of segment-size tradeoffs explains how segment size changes the number of files and read/compaction behavior. The relevant denominator is physical records and replicas, not source-document count. The practical consequence appears when several sources compete for limited context.
The signature is high written-vector and deleted-vector counts despite few net documents. Stable segment count with growing tombstones is a different problem from too many newly sealed segments. This dependency should remain explicit in the final interface.
Compaction Backlog and Failed Builds Prevent Consolidation
Compaction needs free space, I/O bandwidth, CPU, and uninterrupted time to read segments and write replacements. Snapshots, query load, low disk space, crashes, or scheduling limits can postpone retirement of inputs. The result must therefore be checked against the original evidence.
An engineering account of segment compaction backlog describes segment-oriented compaction and its read/write amplification tradeoffs. It illustrates why compaction policy must match the lifetime and update pattern of index data. This distinction remains visible during later household testing.
The failure boundary is a temporary segment spike during a healthy merge. Diagnose proliferation only when old segments remain after successful commit and grace periods, or when backlog age and read amplification continue rising. The intermediate result must remain inspectable before automation follows.
Reconcile Documents, Vectors, Segments, and Compaction Jobs
For each ingestion transaction, record source documents, chunks, dense and sparse vectors, metadata records, tombstones, replicas, flush reason, segment size, compaction inputs and outputs, abandoned builds, snapshot references, free space, and oldest backlog age. That boundary should be measured separately under realistic operating conditions.
Use vector-index structure to relate vector count to search cost. Test bulk versus per-file commits, one document update, delete and re-add, compaction pause, and restart while keeping the same content set. The practical consequence appears when several sources compete for limited context.
Pass when segment count returns to the expected level after compaction and every retained segment has an active manifest, snapshot, or pending merge. Tune flush size or compaction resources only after removing abandoned generations and explaining replica multipliers.
What Causes WebSocket Reconnect Loops in a Remote Home AI Interface?
Diagnose WebSocket loops across handshake, proxy, authentication, heartbeat, network path, session recovery, and client backoff layers.
What Causes Backup Checksums to Mismatch After an Interrupted Transfer?
Trace checksum mismatches through source snapshots, chunk manifests, resume offsets, partial files, transforms, storage writes, and final verification.
What Causes Duplicate Household Entities in a Private Knowledge Graph?
Diagnose duplicate knowledge-graph nodes by separating extraction variants, identity keys, resolution thresholds, source lineage, and concurrent merges.
