What Causes Backup Checksums to Mismatch After an Interrupted Transfer?
Backup checksums mismatch after interruption when resumed output no longer represents the exact byte sequence or chunk manifest hashed at the source.
A home NAS transfer may stop after writing part of a large image, archive, or backup pack. On resume, the tool can trust an incorrect offset, reuse an incomplete chunk, read a source file that changed, or apply compression and encryption with different boundaries. A completed filename and expected size do not prove that its bytes match the original verification domain.
Resume State Can Point to the Wrong Byte or Chunk Boundary
A transfer records completed ranges, chunk hashes, temporary-file length, and sometimes a remote upload session. If that state is not committed atomically, restart can skip an unwritten range, append duplicate bytes, or accept a truncated cached chunk.
The block-checksum transfer algorithm explains how block checksums identify matching data while transferring changed files. Its design shows why block identity and destination position must stay consistent across resume. This distinction remains visible during later household testing.
A mismatch confined near the interruption offset implicates range state. Differences scattered through the file point more strongly to source change, transformation, memory, transport, or storage faults. The intermediate result must remain inspectable before automation follows.
The Source or Transformation May Change Between Attempts
Without a snapshot, an application can modify the source after the first half was read. Compression, encryption, sparse-file expansion, newline conversion, archive timestamps, or nondeterministic metadata can also make a resumed logical backup differ from a prior hash.
An integrity discussion of backup integrity validation distinguishes transfer verification from later storage verification. The key diagnostic is whether both sides hash the same representation: source bytes, transformed stream, chunks, or final container. That boundary should be measured separately under realistic operating conditions.
Compare source identity, size, mtime, inode or file ID, snapshot generation, transformation settings, and manifest version. A changed source should create a new backup object rather than resume the old checksum contract. The practical consequence appears when several sources compete for limited context.
Successful Transfer Completion Does Not Exclude Storage Corruption
Data can be acknowledged by a client, network stack, controller, or cache before durable media verification. Faulty RAM, cables, disks, power loss, or filesystem errors can alter bytes after transfer logic reports success. This dependency should remain explicit in the final interface.
A case analysis of filesystem checksum detection describes filesystem checksum detection and the need for redundant good copies to repair damaged blocks. This is a different layer from an application’s end-to-end backup hash. The result must therefore be checked against the original evidence.
The failure boundary is a mismatch caused by intentionally different checksum scopes or algorithms. Chunk hashes, encrypted-object ETags, and whole-file cryptographic hashes are not interchangeable; compare identical algorithms over identical bytes before declaring corruption. This distinction remains visible during later household testing.
Locate the First Divergent Range and Verification Domain
Preserve the failed destination and compare source snapshot ID, source hash, chunk manifest, resume state, temporary-file length, transfer ranges, transformation configuration, destination hash, filesystem scrub result, and durable-write logs. Find the first differing byte or chunk.
Use backup chunk identity to distinguish chunk boundaries from whole-file identity. Repeat with an immutable source snapshot, fresh full transfer, interrupted resume, and another destination while keeping algorithm and transform settings fixed. The intermediate result must remain inspectable before automation follows.
Resume safely only when source identity and manifest match. Restart into a new temporary object when they do not, verify before atomic rename, and investigate storage hardware when fresh full transfers produce changing mismatches at different offsets.
