How Does Reciprocal Rank Fusion Combine Keyword and Vector Search?
Reciprocal rank fusion combines keyword and vector search by adding rank-based contributions instead of trying to compare their incompatible raw relevance scores.
A home knowledge query may need BM25 to find an exact model number while dense retrieval finds a paraphrased troubleshooting note. Their scores use different scales, so averaging them directly is unstable. RRF instead converts each candidateโ€™s position into a value such as `1/(k + rank)`, sums contributions across lists, and sorts the combined total.
Each Retriever Produces an Independent Ranked List
Keyword search ranks lexical matches using term frequency and document statistics, while vector search ranks semantic proximity in embedding space. Filters and candidate depth are applied before fusion, producing lists that may overlap partly or not at all.
A hybrid-search explanation of hybrid candidate fusion describes a broad keyword-plus-vector candidate stage followed by precision reranking. The separation clarifies that fusion decides which evidence survives into the shared pool. This distinction remains visible during later household testing.
RRF needs ranks and document identity, not comparable scores. Duplicate chunks must use a stable key so the same evidence can collect support from both retrievers. The intermediate result must remain inspectable before automation follows.
Reciprocal Contributions Reward High Positions and Agreement
For every list containing a candidate, RRF adds the reciprocal of a constant plus its rank. A result near the top receives more weight, and a result appearing in both lists accumulates two contributions even if neither raw score is numerically comparable.
An overview of rank-based score fusion explains how ranked results from keyword and vector retrieval become one ordering. The rank constant smooths the difference between adjacent positions and prevents the first result from overwhelming every lower candidate.
A candidate found by only one retriever can still rank well if its position is strong. Agreement helps, but RRF does not require intersection and therefore preserves complementary lexical or semantic evidence. That boundary should be measured separately under realistic operating conditions.
Candidate Depth and the Rank Constant Shape the Output
Fusion cannot recover a relevant document excluded from both input lists. Deeper candidate pools improve opportunity but add latency and noise; the rank constant controls how sharply top positions differ, while duplicate-heavy lists can distort representation.
A production account of keyword and vector complementarity shows why keyword retrieval can recover exact plan and feature terms that semantic search handles poorly. It also places fusion before downstream selection rather than treating the fused score as final evidence quality.
The failure boundary is poor first-stage recall or inconsistent filtering. RRF rearranges supplied candidates; it cannot repair missing permissions, stale chunks, weak embeddings, or a lexical analyzer that never emitted the relevant document. The practical consequence appears when several sources compete for limited context.
Evaluate Fusion Against Both Single Retrievers
Build judged queries covering exact names, abbreviations, paraphrases, multilingual terms, OCR errors, and no-answer cases. Save keyword ranks, vector ranks, fused contributions, candidate depth, filters, final order, and any reranker scores. This dependency should remain explicit in the final interface.
Compare the candidate architecture with NAS hybrid search. Measure recall before fusion, fused precision, citation coverage, latency, and the fraction of relevant results contributed uniquely by each retriever. The result must therefore be checked against the original evidence.
Keep RRF when it improves held-out evidence coverage at an acceptable context-noise cost. Tune candidate depth and constant on the test set, then investigate retriever-specific misses instead of endlessly adjusting fusion for absent evidence. This distinction remains visible during later household testing.
