An AI router usually selects the smallest eligible model whose predicted capability, latency, privacy, and risk satisfy the requestโs declared service threshold.
A household command such as formatting a calendar event may fit a small model already loaded on the home server, while long code synthesis or ambiguous research may need a larger local or remote model. The router extracts task and context signals, applies hard policy constraints, predicts likely success and cost, then dispatches or escalates when confidence falls short.
Policy Gates Remove Ineligible Models Before Scoring
Data residency, tool permissions, context length, modality, user tier, hardware availability, and deadline can rule out candidates immediately. A cloud model should never enter the score competition when sensitive files must remain local. This distinction remains visible during later household testing.
A practitioner account of a local specialist routing describes a small always-loaded classifier dispatching code, reasoning, and general tasks to specialists. The design illustrates why routing begins with a capability inventory rather than one universal model ranking.
Hard constraints should be deterministic and inspectable. Letting a probabilistic classifier override privacy or permission policy turns routing error into a security decision. The intermediate result must remain inspectable before automation follows.
A Scorer Estimates Difficulty, Quality, and Serving Cost
The router can use rules, embeddings, a small classifier, prior task labels, or response-quality predictors. It estimates whether each eligible model will meet the requested quality while accounting for queue time, cold load, memory pressure, and token cost.
Research on confidence-driven model routing surveys routing and cascading strategies that use uncertainty and external quality evaluation. These approaches optimize expected quality and cost rather than assuming query length alone represents difficulty. That boundary should be measured separately under realistic operating conditions.
The decision can be request-level or subtask-level. Retrieval query rewriting may stay small while final synthesis escalates, provided the workflow preserves provenance and does not expose restricted context. The practical consequence appears when several sources compete for limited context.
Fallback Converts Uncertainty Into a Second Chance
A small model can produce structured confidence, fail validation, or trigger a verifier that requests escalation. The router may retry the larger model with the original evidence, but bounded budgets prevent endless cascades and duplicate tool actions.
An explanation of routing and fallback signals highlights complexity, context, metadata, and fallback as routing signals. It reinforces that selection is a service policy combining model capability with operational constraints. This dependency should remain explicit in the final interface.
The failure boundary is a router trained on unrepresentative tasks or stale model performance. A confident misroute can silently lower answer quality, so consequential workflows need deterministic validation or direct assignment rather than predicted difficulty alone.
Build a Cost-Quality Routing Confusion Matrix
Label a representative request set with privacy class, modality, context length, task family, risk, deadline, smallest acceptable model, and verified outcome. Replay it under realistic queue and memory conditions. The result must therefore be checked against the original evidence.
Compare the architecture with local model routing. Record chosen model, route reason, cold-start cost, TTFT, completion latency, quality score, validation result, escalation, resource use, and policy violations. This distinction remains visible during later household testing.
Set thresholds from false-small and unnecessary-large routes separately. Pin high-risk tasks to validated paths, retrain or revise rules when workload drift appears, and expose the selected model and fallback state to users. The intermediate result must remain inspectable before automation follows.
