A secret broker keeps credentials out of prompts by authenticating the agentโs workload and injecting scoped authorization only at the external request boundary.
A home AI agent may need to read a calendar or upload a backup, yet placing API keys in its prompt, memory, environment, or tool output makes them reachable through injection. A broker verifies workload identity and approved task context, obtains a short-lived credential, attaches it inside a controlled proxy or tool adapter, and returns only the service result.
Workload Identity Replaces Possession of a Static Key
The agent proves which approved process, container, service account, or signed workload is making the request. The broker maps that identity to policies instead of trusting a bearer key stored where generated code or model context can read it.
An analysis of workload identity for agents explains attestation and machine-to-machine authentication for agents that should not hold persistent credentials. The identity proof lets authorization depend on the runtime workload rather than conversational claims. This distinction remains visible during later household testing.
Identity alone does not grant every service. Policy still binds the workload to user, destination, operation, resource scope, and time window. The intermediate result must remain inspectable before automation follows.
The Broker Issues or Injects a Narrow, Short-Lived Credential
After policy approval, the broker exchanges identity for a scoped token or retrieves a secret in protected memory. A proxy adds the authorization header to the outbound request after the model-generated parameters have been validated.
Security guidance for short-lived brokered credentials recommends starting with no credentials and using a broker to provide short-lived tokens for the specific task. This limits both exposure duration and the operations available after compromise. That boundary should be measured separately under realistic operating conditions.
The model sees a tool schema and sanitized response, not the token. Logs, errors, traces, command lines, and retries must also redact authorization material or the architecture merely moves the leak. The practical consequence appears when several sources compete for limited context.
Policy and Revocation Bound Credential Misuse
Destination allowlists, method restrictions, resource identifiers, user approval, rate limits, audience claims, expiry, and one-time tokens constrain how the injected authority can be used. The broker can revoke future issuance without rebuilding prompts or images.
An explanation of credential injection boundary argues that any secret entering the context window becomes exposable and places credential handling outside the agent. The pattern reduces disclosure risk while preserving controlled authenticated calls. This dependency should remain explicit in the final interface.
The failure boundary is an overbroad broker policy or proxy that signs arbitrary agent-chosen requests. Hidden credentials do not prevent a prompt-injected agent from misusing legitimate authority, so request semantics and side effects still need validation.
Trace One Credential From Identity to Expiry
For each agent tool, document workload identity, requesting user, destination, permitted operation, resource scope, approval state, token audience, lifetime, injection point, response redaction, audit identifier, revocation path, and fallback behavior. The result must therefore be checked against the original evidence.
Compare the control with agent tool permissions. Test prompt requests for secrets, environment dumps, redirected destinations, replay after expiry, broadened resource IDs, error logging, tool retries, and a compromised sandbox process. This distinction remains visible during later household testing.
Pass only when raw credentials never enter model-visible data and unauthorized request variants fail at the broker or proxy. Keep tokens short-lived, policies task-specific, logs redacted, and irreversible operations behind independently bound approval. The intermediate result must remain inspectable before automation follows.
