An occupancy grid combines weak smart home signals by updating location-specific probabilities as each time-aligned sensor contributes uncertain evidence for or against presence.
A PIR sensor may detect entry quickly but miss someone sitting still, while mmWave, power, sound, door, and environmental signals have different delays and blind spots. The grid divides rooms or zones into cells, maps each observation to affected locations, and accumulates weighted evidence over time. Automation reads probabilities or states derived from them rather than one deviceโ€™s binary output.
Spatial Cells Give Every Observation a Location
The home layout is divided into rooms, zones, or finer cells, each storing an unknown, occupied, or vacant belief. Sensor placement and field of view determine which cells a motion, doorway, pressure, or radio observation can update.
An overview of probabilistic occupancy cells explains that occupancy grids store probabilities rather than hard labels and use sensor-specific hit and miss models. Repeated measurements strengthen or weaken belief for individual cells. This distinction remains visible during later household testing.
Coarse room cells are easier to maintain but cannot separate sofa from doorway activity. Fine cells need better calibration and create more uncertainty when consumer sensors lack precise geometry. The intermediate result must remain inspectable before automation follows.
Sensor Models Convert Weak Events Into Probability Updates
Each signal receives likelihoods describing how expected it is when a cell is occupied or empty. Bayesian or log-odds updates combine the prior belief with new evidence, while decay moves stale cells back toward unknown.
A review of multisensor occupancy fusion describes combining PIR, ultrasonic, microwave, and other modalities because each observes a different consequence of human presence. Fusion gains value when their errors and timing are complementary. That boundary should be measured separately under realistic operating conditions.
A door opening can raise nearby entry cells quickly, and persistent mmWave can maintain a seated occupant. Negative evidence should usually reduce belief gradually because silence from one sensor may reflect its blind spot. The practical consequence appears when several sources compete for limited context.
Correlation and Misregistration Can Create False Confidence
Two sensors may react to the same HVAC cycle, pet, sunlight, or moving curtain, violating the independence assumed by simple Bayesian multiplication. Incorrect room assignment or clock alignment can also add evidence to the wrong cell.
Foundational work on log-odds occupancy updates expresses repeated cell updates in log-odds and shows how inverse sensor models shape the posterior. The mathematics remains only as reliable as the spatial and error models supplied. This dependency should remain explicit in the final interface.
The failure boundary is correlated or systematically biased evidence. Adding more weak signals can increase confidence in the wrong state when their shared cause is counted repeatedly or their fields of view are misregistered. The result must therefore be checked against the original evidence.
Calibrate the Grid With Room-Level Ground Truth
Record cell geometry, sensor field of view, event time, freshness, hit and miss likelihoods, prior, decay, contribution, fused probability, threshold state, and verified occupancy across entry, quiet sitting, sleep, pets, guests, and HVAC cycles. This distinction remains visible during later household testing.
Compare the model with weak presence signals. Run leave-one-sensor-out tests and simulated stale, delayed, contradictory, and correlated inputs while keeping ground truth and automation thresholds fixed. The intermediate result must remain inspectable before automation follows.
Adopt the grid only when it improves both entry response and quiet-occupant retention without raising false presence. Expose evidence contributions and keep consequential automation behind stronger confirmation than lighting convenience. That boundary should be measured separately under realistic operating conditions.
