Content-defined chunking recognizes a renamed file because its chunk boundaries and fingerprints derive from file bytes rather than the pathname stored by the NAS.
If a family archive moves `scan.pdf` into a year folder and gives it a descriptive name, a path-keyed index may treat it as new. A content-defined pipeline scans the bytes, finds the same boundary patterns, and reproduces the same chunk hashes. Those matches can reuse stored blocks, OCR, embeddings, or captions while provenance updates to the new location.
Rolling Fingerprints Choose Boundaries From Content
A content-defined chunker moves a window across the byte stream and declares a boundary when the rolling fingerprint matches a rule, subject to minimum and maximum sizes. The chosen cut points depend on local byte patterns, not absolute offsets or filenames.
The content-derived chunk boundaries design explains why byte-derived boundaries resist the boundary-shift problem that affects fixed-size chunks. When a local insertion occurs, later boundaries can resynchronize with unchanged content. This distinction remains visible during later household testing.
A pure rename changes neither bytes nor cut points, so the chunk sequence should reproduce exactly. Metadata-only updates remain separate unless metadata is deliberately included in the content stream. The intermediate result must remain inspectable before automation follows.
Chunk Hashes Match Existing Content Across Paths
Each chunk receives a strong fingerprint used as a content key. Reprocessing the renamed file yields the same sequence, allowing the store to reference existing chunks instead of writing or recomputing equivalent artifacts. That boundary should be measured separately under realistic operating conditions.
A hands-on explanation of chunk fingerprint reuse shows how chunk fingerprints let new file versions reuse stored data. The deduplication index cares about known content units, while a separate manifest maps those units to the current file.
For AI indexing, the cache key must also include parser, OCR, embedding, and normalization versions. Equal source bytes do not justify reusing an artifact produced by incompatible transformation settings. The practical consequence appears when several sources compete for limited context.
A Manifest Preserves File Identity and Provenance
Chunk matches establish content continuity, but they do not decide whether a rename represents the same logical document, a duplicate copy, or two authorized references. Manifests track current path, stable file ID, chunk sequence, version, ownership, and lineage separately.
An introduction to content-based chunking contrasts content-based boundaries with fixed offsets and explains why only new chunks need uploading. That reuse mechanism works across names because storage identity is separated from directory identity. This dependency should remain explicit in the final interface.
The failure boundary is a container or encryption change that rewrites bytes. Two files can be semantically identical yet produce unrelated chunks after recompression or randomized encryption, while identical chunks across paths still require independent permission checks.
Verify Rename Reuse Without Losing Provenance
Index an original file, a pure rename, a moved copy, a one-paragraph insertion, a recompressed version, and an encrypted version. Record file IDs, paths, chunk boundaries, hashes, cache keys, reused artifacts, and active provenance records.
Use file fingerprint reuse to separate content identity from source lineage. Confirm that the rename avoids redundant processing while search citations resolve only to current authorized paths. The result must therefore be checked against the original evidence.
Pass when unchanged chunks reuse compatible work, modified regions generate new artifacts, and deletions or moves retire stale path records. Never collapse two user-visible documents merely because their byte chunks match. This distinction remains visible during later household testing.
