Model residency means retaining model weights in host or accelerator memory between requests so the next inference avoids some or all loading work.
A home assistant used every few minutes feels very different when an eight-gigabyte model remains in GPU memory versus being read from storage each time. Residency can exist at several levels: filesystem cache, mapped host pages, pinned RAM, or VRAM ready for kernels. Keeping weights warm reduces startup delay, but it reserves scarce memory and may prevent other models or workloads from running.
Residency Describes Where Reusable Model State Remains
A cold model exists only on storage and must be read, allocated, transformed, and copied before inference. Host-resident weights avoid storage reads, while accelerator-resident weights also avoid the host-to-device transfer and runtime initialization path. This distinction remains visible during later household testing.
NVIDIA's model-streaming analysis separates model loading path from transfer and initialization work, showing why weight location dominates many cold starts. A warm process may still need tokenizer, graph, adapter, or cache initialization. The intermediate result must remain inspectable before automation follows.
Residency is not the same as an active request. A model can remain loaded with no KV cache or user data, ready to serve while consuming memory and some background resources. That boundary should be measured separately under realistic operating conditions.
Warmth Exists Across a Memory Hierarchy
The operating system may retain model pages in its page cache even after a process exits, memory mapping may fault pages lazily, and a serving process may keep tensors in RAM or VRAM. Each warmer level usually reduces latency while consuming a more constrained resource.
ServerlessLLM examines tiered model loading across storage, host memory, and GPU memory and schedules loading to reduce cold-start cost. The hierarchy explains why an apparently unloaded model may restart quickly until cache pressure evicts its pages.
Quantization lowers the bytes required for residency and can let several specialized models coexist. It can also change execution kernels and quality, so memory savings should not be counted as a free capacity increase. The practical consequence appears when several sources compete for limited context.
Eviction Policy Converts Memory Pressure Into Startup Delay
A service can keep frequently used models resident and evict colder ones by recency, predicted demand, priority, or loading cost. Multi-model routing needs admission rules so background work does not displace the voice model that must answer immediately.
FlexGen demonstrates weight offloading across GPU, CPU, and storage for constrained inference. Although aimed at throughput, it makes the core tradeoff explicit: moving weights between tiers saves scarce memory but adds transfer and scheduling cost.
The failure boundary is memory pressure that triggers swapping, OOM restarts, or eviction thrash. Keeping too many weights loaded can make every model slower and less reliable than deliberately warming a smaller working set. This dependency should remain explicit in the final interface.
Set Residency From Reuse Distance and Memory Margin
Measure cold, host-warm, and accelerator-warm startup time for every model, then record request interval, load bytes, VRAM and RAM footprint, idle power, eviction count, and competing workload demand. The result must therefore be checked against the original evidence.
Compare the startup mechanism with memory-mapped startup. Replay a week of arrivals under candidate keep-alive windows and priorities, including bursts, long idle periods, and simultaneous model requests. This distinction remains visible during later household testing.
Keep a model resident when avoided load latency and reuse frequency justify its protected memory. Evict it when the reserved capacity causes queuing or thrash, and preserve an emergency margin for KV cache and transient allocations.
What Is Embedding Drift, and When Does a Private Search Index Need Rebuilding?
Decode model, preprocessing, corpus, and query drift; distinguish monitoring from incompatibility; and decide when a private index needs rebuilding.
What Is Tokenizer Compatibility, and Why Can It Break Model Switching?
Decode vocabulary identity, special-token semantics, chat templates, cached tokens, adapters, and compatibility checks for local model switching.
What Is Speculative Decoding Acceptance Rate, and Why Does It Matter?
Decode the acceptance metric, draft verification, rejection behavior, speedup limits, workload variation, and measurement for local inference.
