NAS and SAN are both networked storage systems, but they solve different problems. NAS gives people and devices shared files over a network. SAN gives servers block-level storage that behaves more like local disks.
For homes, creators, small offices, and most self-hosted setups, NAS is usually the right answer. SAN becomes relevant when servers, virtual machines, or databases need shared low-latency block storage with enterprise-level networking and management.
The Core Difference Is Files vs Blocks
The simplest way to compare NAS and SAN is this: NAS is for shared files, while SAN is for shared disks. A NAS exposes folders and files that users, computers, backup tools, and media apps can open directly. A SAN exposes block storage volumes, often called LUNs, that servers treat like local drives.
IBM describes NAS as file-level storage connected to a network, while SAN is block storage delivered through a dedicated storage network. The SNIA storage education material also frames storage evolution around blocks, files, and objects, which is the right starting point for understanding why NAS and SAN behave differently.
| Storage Type | What It Provides | Typical User |
| NAS | Files and folders | People, PCs, Macs, media apps, backup tools |
| SAN | Block devices / LUNs | Servers, hypervisors, databases |
| Cloud / object storage | Objects, metadata, sync, remote access | Cloud apps, archives, distributed workflows |
The decision should not start with which system sounds more advanced. It should start with what your workload needs: shared files or shared block devices.
NAS Solves Everyday File Problems
NAS is designed for the problems most homes, creators, and small teams actually have: files are scattered across devices, backups need a home, media libraries keep growing, and multiple people need access to the same folders.
A beginner-friendly home NAS setup guide for beginners is a better starting point for these problems than SAN planning, because the goal is usually shared folders, user access, backups, and simple storage management.
| Problem | Why NAS Fits |
| Files scattered across devices | Creates one shared location |
| Family photos need a home | Central archive with folders |
| Mac / PC backups need storage | Works as a local backup target |
| Media library keeps growing | Stores videos, music, photos, subtitles, and metadata |
| Small office needs permissions | Shared folders and user access |
| Home lab needs persistent files | Stores app data, configs, and Docker volumes |
If the problem is “where do we put our files so everyone can use them?”, NAS is usually the cleaner answer.
SAN Solves Server Storage Problems
SAN is not mainly built for people browsing folders. It is built for servers that need shared block storage. The server, hypervisor, or database layer then formats and manages that block storage.
IBM’s overview of storage area networks describes SAN as a dedicated network that connects servers to shared storage using technologies such as Fibre Channel and iSCSI. VMware’s iSCSI best practice resources for SAN storage are also a reminder that SAN design belongs closer to server and virtualization infrastructure than everyday file sharing.
| Problem | Why SAN Fits |
| VM hosts need shared storage | Provides block-level LUNs |
| Database needs low latency | Optimized for server block I/O |
| Enterprise cluster needs HA | Supports redundant storage paths |
| Data center needs storage fabric | Built for dedicated storage networks |
| Multiple servers need shared disks | SAN presents storage as block devices |
If your users need shared folders, start with NAS. If your servers need shared disks, start looking at SAN.
NAS Uses Normal Network File Sharing
Most NAS setups use file-sharing protocols that regular devices already understand. SMB is common for Windows, macOS, and mixed home or office networks. NFS is common in Linux, Unix, server, and container workflows.
AWS’s guide to the difference between NFS and SMB explains how both protocols allow clients to access files over a network, but they are often used in different environments. For most home and small office NAS setups, SMB is the practical default. For Linux servers and some app workflows, NFS may be cleaner.
| Protocol | Common Use |
| SMB | Windows, macOS, shared folders, home and office files |
| NFS | Linux servers, Docker hosts, Unix-style workflows |
| WebDAV / app access | Private cloud and remote file access |
| SFTP | Secure file transfer and admin workflows |
The important point is that NAS speaks in files. Users mount a share, open a folder, copy a photo library, or back up a laptop. That is why NAS feels natural in homes and small teams.
SAN Uses Dedicated Block Storage Protocols
SAN usually introduces a different vocabulary: Fibre Channel, iSCSI, LUNs, multipath, zoning, storage controllers, initiators, and targets. Those terms matter because SAN is not just a shared folder system. It is a storage fabric for servers.
| SAN Term | Simple Meaning |
| LUN | A block storage volume presented to a server |
| iSCSI | Block storage over IP networking |
| Fibre Channel | Dedicated high-performance storage fabric |
| Multipath | Multiple paths to the same storage for redundancy |
| Zoning | Controls which servers can see which storage |
For a data center, those tools can be powerful. For a home media library or small office share, they are usually unnecessary complexity.
NAS Is Easier and Cheaper for Most Users
NAS is usually easier to set up because it is built around shared folders, users, permissions, web management, backup tools, and common network protocols. It can often run on a standard Ethernet LAN without dedicated storage fabric planning.
SAN usually requires more specialized design. The storage network, paths, LUNs, redundancy, server access, and host configuration all need to be planned carefully. That is useful in enterprise infrastructure, but it is rarely the best first step for everyday storage.
| Setup Area | NAS | SAN |
| Beginner setup | Easier | Much harder |
| User file sharing | Native | Needs file server layer |
| Network | Standard LAN often enough | Dedicated storage design |
| Cost | Low to moderate | High |
| Management | Home / SMB friendly | Enterprise admin skill |
| Apps and media | Common | Not the main purpose |
NAS is not less useful because it is simpler. It is simpler because it is solving a different, more user-facing problem.
SAN Is Powerful, but Usually Overkill Outside Enterprise
SAN can be extremely powerful when the environment needs it: many servers, shared VM storage, databases, low-latency block I/O, redundant paths, storage fabric design, and dedicated administration.
But SAN is not a shortcut for simple file sharing, Plex, Time Machine, family photos, or a small office document folder. If the main question is “where should we store files?”, SAN is probably the wrong starting point.
| If Your Problem Is... | Start With... |
| Family files are scattered | NAS |
| Mac and PC backups need a target | NAS |
| Plex or Jellyfin needs media storage | NAS |
| A VM cluster needs shared block storage | SAN |
| A database needs low-latency shared storage | SAN |
| A data center needs storage fabric | SAN |
The more human-facing the storage problem is, the more likely NAS is the right fit. The more server-facing the storage problem is, the more likely SAN becomes relevant.
Performance Depends on the Workload, Not the Acronym
It is tempting to say SAN is always faster than NAS, but that is too simple. Performance depends on the workload, network, storage pool, SSD or HDD layout, protocol, latency, CPU, client behavior, and whether the data is accessed as files or blocks.
A NAS can be very fast for large file copies, media streaming, backups, and shared folders when the network and drives are designed well. A SAN can be better for VM datastores, databases, and block-level workloads where latency and IOPS matter more than folder browsing.
| Workload | Real Bottleneck |
| Large file copy | Network and drive throughput |
| Media streaming | Direct Play, client support, network, transcoding |
| Backup | Schedule, snapshots, disk writes |
| VM storage | Latency, IOPS, multipath, block access |
| Database | Consistent writes and low latency |
| Photo library | Metadata, thumbnails, small-file performance |
The right question is not “Which one is faster?” It is “Which one matches the access pattern?”
NAS Is the Better Fit for Home, Studio, and Small Office Storage
Most home users, creators, and small offices need shared files, not shared block devices. They want one place for photos, videos, project folders, backups, media libraries, and private documents.
NAS solves those problems directly. It gives users folders, permissions, media access, backup targets, and local storage control without requiring SAN administration.
| User Problem | Better Fit |
| Family photos need one archive | NAS |
| 4K media library | NAS |
| Mac / PC backup | NAS |
| Small studio project files | NAS |
| Home lab apps | NAS / personal server |
| VM cluster datastore | SAN |
| Enterprise database storage | SAN |
If you do not run clustered servers, hypervisors, or enterprise databases, SAN is usually solving a problem you do not have.
Backup Works Differently on NAS and SAN
NAS can directly receive file-level backups from Macs, PCs, phones, and applications. SAN is lower-level. It provides storage blocks to servers, but backup is usually handled above that layer by the host, hypervisor, filesystem, snapshot system, or backup software.
The ZimaSpace guide to 3-2-1 backup strategy for home NAS users is useful here because it keeps the boundary clear: NAS can be a strong local backup target, but it still needs another copy and an offsite layer. SAN also does not become a complete backup system just because it is enterprise storage.
| Backup Question | NAS | SAN |
| Can receive file backups directly | Yes | Not usually directly |
| Can host Time Machine / PC backups | Yes | Needs file server layer |
| Protects against drive failure | Depends on RAID/layout | Depends on array/layout |
| Protects against deletion | Needs snapshots/versioning | Needs backup/snapshots |
| Needs offsite copy | Yes | Yes |
Both NAS and SAN need a backup strategy. Storage availability is not the same as data recovery.
Media Libraries Belong on NAS, Not SAN
Media libraries are file problems. Plex, Jellyfin, Emby, smart TVs, laptops, and phones need access to movies, shows, music, photos, subtitles, posters, and metadata. NAS gives those apps a direct file storage layer.
SAN can support media storage indirectly, but it usually needs a server layer above it to expose files. For home and creator media workflows, that adds complexity without solving the core problem better.
| Media Need | Why NAS Fits |
| Movies and TV shows | Stored as folders and files |
| Music library | Shared across playback devices |
| Family videos | Central long-term archive |
| Plex / Jellyfin | Reads media paths directly |
| Photo archive | Organized folder structure and backup |
For larger media workflows, a ZimaCube 2 NAS is closer to the real need than SAN. In ZimaSpace benchmark testing, ZimaCube 2 reached 68 fps and 1.13x processing speed in 4K60 H.264 VAAPI hardware transcoding, which makes it relevant for media server, Jellyfin, and Plex NAS discussions.
Self-Hosted Apps Usually Want NAS or Local Storage First
Home lab and self-hosted apps usually need persistent folders, app volumes, databases, metadata, logs, and configuration files. That is closer to NAS or local server storage than enterprise SAN design.
Nextcloud, Immich, Jellyfin, Home Assistant, Vaultwarden, Docker stacks, and private AI tools all need reliable data paths. Some data belongs on HDD archive storage. Other data, such as databases and thumbnails, works better on SSD or NVMe.
| Self-Hosted App Need | Better Storage Layer |
| User files | NAS HDD pool |
| App database | SSD / NVMe |
| Media originals | NAS HDD pool |
| Metadata and thumbnails | SSD preferred |
| Docker volumes | Local SSD / NAS depending on workload |
| AI models and datasets | NVMe / SSD for active data, HDD for archive |
A ZimaBoard 2 compact x86 personal server fits these home lab workflows well. Its benchmark profile includes Intel N150, dual 2.5GbE, dual SATA 6Gbps, PCIe 3.0 x2, USB 10Gbps, and QSV 4K transcoding at 134 fps in a Jellyfin test environment.
Cost and Maintenance Decide More Than Theory
NAS and SAN are not only technical choices. They are also cost and maintenance choices. NAS usually requires an enclosure or personal server, drives, a backup plan, and sometimes faster networking. SAN usually requires storage arrays, dedicated networking, host adapters or NICs, multipath configuration, licensing, redundancy planning, and storage administration.
| Cost Area | NAS | SAN |
| Hardware | Lower | Higher |
| Network | Standard LAN | Dedicated storage network |
| Setup | Easier | Complex |
| Admin skill | Moderate | High |
| User access | Direct | Needs file server layer |
| Enterprise scale | Limited | Strong |
For home and small-team storage, the extra SAN complexity usually does not pay back. For enterprise infrastructure, that complexity may be exactly what the workload needs.
Choose NAS If This Is Your Problem
Choose NAS if the storage will be used by people, devices, and apps that need shared files. This includes home backups, family photos, 4K media libraries, private cloud folders, small office documents, creator archives, Docker apps, home lab services, and local AI documents or model storage.
| Choose NAS If You Need... |
| Shared folders for people and devices |
| Mac, PC, or phone backup target |
| Family photos and videos in one archive |
| Plex, Jellyfin, or home media storage |
| Private cloud or self-hosted apps |
| Docker volumes and app data |
| Local AI documents, models, and datasets |
NAS is the right answer when the storage problem is file-centered and user-facing.
Choose SAN If This Is Your Problem
Choose SAN if the storage will be consumed mainly by servers and hypervisors, not people opening folders. SAN makes sense for VM clusters, enterprise databases, shared block storage, low-latency transactional workloads, and data center storage designs with a dedicated IT team.
| Choose SAN If You Need... |
| VMware / Hyper-V cluster datastore |
| Shared block devices for multiple servers |
| Low-latency transactional workloads |
| Dedicated storage fabric |
| Multipath and enterprise HA storage design |
| Storage administration budget and expertise |
SAN is not a shortcut for simple file sharing, Plex, home backup, or a small office folder. It is an enterprise storage architecture for server-facing block workloads.
Practical Decision Table
| Question | Choose NAS If... | Choose SAN If... |
| What do you need to share? | Files and folders | Block devices |
| Who accesses storage? | People, devices, apps | Servers and hypervisors |
| Main workload | Backup, media, files, self-hosted apps | VMs, databases, enterprise apps |
| Protocol | SMB, NFS, WebDAV | iSCSI, Fibre Channel, NVMe-oF |
| Setup skill | Home / small office | IT / storage admin |
| Budget | Lower / moderate | Higher |
| Remote access | VPN / private cloud | Usually not user-facing |
| Best fit | NAS / personal server | Enterprise storage fabric |
Final Takeaway
NAS and SAN are not two versions of the same product. NAS solves shared file storage. SAN solves shared block storage.
For home users, creators, small offices, media libraries, backups, private cloud, and self-hosted apps, NAS is usually the right answer. SAN becomes the answer when servers, not people, need shared disks for virtualization, databases, and enterprise workloads.
Is NAS the same as SAN?
No. NAS provides file-level storage over a network. SAN provides block-level storage to servers.
Which is faster, NAS or SAN?
It depends on the workload and infrastructure. SAN can be faster for enterprise block workloads, but NAS is often fast enough for files, backups, media, and home servers.
Do home users need SAN?
Usually no. Most home users need shared files, backups, media storage, and private cloud workflows, which are better served by NAS.
Can a NAS replace a SAN?
For file sharing, backup, media, and small self-hosted apps, yes. For enterprise VM clusters, databases, and shared block storage, no.
Can SAN be used for media storage?
It can, but it usually needs a file server layer above it. NAS is simpler and more direct for media libraries.
Should I choose NAS or SAN for backups?
Choose NAS for most file-level backup workflows. SAN still needs a backup system above the block storage layer.
Product Comparisons
