ZFS can justify itself on a two-bay NAS, but not because two drives make it automatically safer. Its value comes from end-to-end checksums, scheduled verification, snapshots, and repair from a healthy mirror member. The cost is a storage stack that asks for deliberate RAM budgeting, monitoring, and recovery practice.
The right comparison is therefore not “ZFS versus no overhead.” Every filesystem needs memory, maintenance, and backup. The useful question is whether ZFS exposes and manages the failure modes that matter for this small system better than a simpler filesystem and mirror layer.
Start With the Integrity Requirement
Choose ZFS when the NAS holds data whose silent corruption matters: family archives, business records, project files, or backups that must remain readable years later. Checksums let the filesystem detect a block that no longer matches what was written; a mirror gives it another copy from which to repair.
A scrub is not generic “disk exercise.” The OpenZFS scrub documentation explains that a normal scrub verifies every block checksum and can repair detected damage when replicated data is available. That is a real integrity function, but it also creates sustained I/O that should be scheduled and observed.
If the NAS contains replaceable media and downtime is cheap, a simpler stack plus a verified backup may be enough. ZFS does not earn its complexity merely by being technically stronger.
Price the RAM With the Whole Workload
ZFS uses available memory for its adaptive replacement cache, but the popular “one gigabyte per terabyte” rule is not a universal minimum. The practical limit is whether the operating system, file service, containers, and ZFS can coexist without sustained memory pressure.
Test the NAS during its busiest overlap: client transfers, media indexing, backup jobs, and a scrub. Watch swap activity, eviction, application latency, and kernel memory rather than only the amount shown as used. A cache that releases memory under pressure is not itself a problem; repeated swapping or killed services is.
On a fixed-memory appliance, leave explicit headroom before enabling deduplication or adding application workloads. Deduplication is not required for checksums, snapshots, scrubs, or mirrors, and it should not be enabled as a default feature experiment.
Understand the Two-Bay Recovery Boundary
A two-drive mirror can survive one member failure, but there is no spare bay for an online replacement. Recovery requires a compatible replacement drive, a healthy remaining member, time to resilver, and a backup if the second copy fails or the pool becomes unavailable.
Document which physical serial number maps to each pool member. Practice exporting and importing a disposable pool, replacing a simulated failed member, reading scrub results, and restoring a file from backup. Recovery familiarity is part of the ownership cost.
Snapshots on the same pool do not cover theft, controller failure, accidental pool destruction, or a disaster affecting both drives. Keep at least one independent copy and test it before treating the mirror as dependable.
When a Simpler Stack Wins
Choose a simpler filesystem or appliance-managed mirror when the hardware has tight memory, the owner will not monitor scrub and pool health, recovery must be supported by a vendor wizard, or the stored data is easy to recreate. Simplicity can be a reliability feature when it reduces operator mistakes.
Client protocol remains a separate choice. This SMB-versus-NFS comparison helps decide how systems reach the share without confusing access protocol with on-disk integrity.
Neither option removes the need for backup. The lower-overhead choice wins only if its detection, restore, and downtime behavior still meet the data requirement.
Final Decision
ZFS is justified when a two-bay mirror protects meaningful data, the NAS has measured memory headroom, scrubs can run without breaking service, and the owner has rehearsed replacement and restore. Choose the simpler stack when those operating commitments will not be maintained.
Does ZFS require ECC memory on a two-bay NAS?
ECC is preferable for storage systems, but ZFS is not uniquely unsafe without it. Use reliable hardware, preserve backups, and do not assume any filesystem can correct bad data before it is checksummed.
Does every scrub shorten drive life?
A scrub adds a full read workload, so schedule it sensibly and watch temperatures and errors. Its purpose is to discover unreadable or corrupt data while another good copy may still exist.
Product Comparisons
1GbE Line Rate vs Real NAS Throughput: When Is the Gap Normal?
About 110–120 MB/s can be normal for large wired transfers; a wider gap needs link, protocol, storage, CPU, or client tests before an upgrade.
NAS OS vs General Linux After a Boot-Drive Failure: Which Rebuilds More Predictably?
A NAS OS wins with a tested configuration restore; general Linux wins when storage and services are declarative and portable off-host.
LXC vs Docker on Proxmox for App Updates and Rollbacks
Docker gives app-level version control; LXC gives guest-level rollback. The better fit follows the smallest state unit you can restore safely.
