A scratch SSD is worth adding to a creator NAS when cache files, previews, proxies, temporary renders, or other disposable working data are measurably slowing the active workflow or competing with the main storage pool. It is not a default requirement for every photography or video NAS. If source media already streams smoothly, application caches live on fast workstation storage, and exports are CPU- or GPU-limited, another SSD may add capacity and complexity without removing the real bottleneck.
Start With the Slow Stage, Not the Empty SSD Slot
A creator workflow can touch several storage paths at once: original footage, project files, thumbnails, preview renders, media cache, proxies, autosaves, exports, and long-term archives. The scratch tier should be purchased only when one of the temporary paths is the slow stage. A fast SSD cannot shorten a render that is limited by the CPU, fix a saturated 1GbE client link, or make a poorly optimized codec easier to decode.
Puget Systems separates source media, cache, and scratch behavior because these workloads do not stress storage in the same way. Its storage guidance for video editing notes that cache files benefit from SSD-class storage and that the best scratch location depends on the application. That is a better buying signal than assuming every creator NAS needs another flash tier.
Run one representative job while watching where time is lost. Scrub a dense timeline, generate previews, import a large shoot, build proxies, and export while the NAS is doing its normal background work. If the timeline pauses while temporary files are being read or written and the CPU, GPU, and network still have headroom, storage isolation becomes a credible upgrade.
If the problem appears only on one workstation, test a local scratch SSD before adding shared scratch storage to the NAS. A NAS-level scratch tier makes more sense when several workstations, render nodes, or server-side creative tasks need the same low-latency temporary space.
Keep Scratch Separate When Temporary I/O Competes With Valuable Media
The strongest case for a scratch SSD is often isolation rather than headline speed. A large preview generation job, proxy build, thumbnail rebuild, or transcode can create bursts of reads and writes that interfere with people opening original media from the same HDD pool. Moving disposable I/O to flash can keep the archive tier focused on source files and completed projects.
Adobe's shared-storage guidance distinguishes working media from cache behavior and recommends keeping Media Cache Files and the Media Cache Database on the system drive or a separate fast directly attached SSD for many Premiere workflows. That cache-placement boundary is important for a NAS buyer: a server-side scratch SSD is useful only when the workload actually belongs on the server.
For one editor, local cache is often simpler and faster. For a small creative team, the NAS can still host shared source media and completed outputs while each workstation keeps its own latency-sensitive cache. Add shared scratch only when a common proxy, render, ingest, or automation workflow makes local-only scratch inconvenient.
The ZimaSpace creator NAS guide for large assets uses the same two-tier logic: expensive performance storage should carry the hot working set, while large HDD capacity remains the better home for archives and colder project data.
Size Scratch From the Largest Temporary Working Set, Not the Project Archive
Scratch capacity is not the same as project capacity. A multi-terabyte camera archive may need only a fraction of that space for cache and previews, while a proxy-heavy or compositing workflow can create temporary data close to the size of the source media. The correct number comes from the largest temporary working set that must exist at one time, plus free-space margin.
Scratch requirements grow with project length, complexity, preview quality, proxy strategy, and the number of projects kept active at once. Treat free capacity as part of performance rather than filling the device to its advertised limit; a scratch tier that repeatedly reaches near-full conditions is undersized even if its average usage looks comfortable.
Measure one busy project. Record peak cache, proxy, preview, temporary render, and autosave usage, then decide how many active projects can overlap. Preserve enough unused space that garbage collection and temporary bursts do not push the SSD into a nearly full state during the heaviest day.
A smaller high-quality SSD that is regularly purged can be a better scratch tier than a very large SSD that slowly becomes a second archive. If files are irreplaceable or expected to survive a failed scratch device, they do not belong only on the scratch tier.
Write Endurance Matters More When the Scratch Tier Is Constantly Rebuilt
Scratch data is disposable, but the SSD is not. Proxy creation, render cache, large previews, transcoding, and repeated deletion can create far more writes than ordinary file serving. A creator who rebuilds hundreds of gigabytes of temporary data every day should consider endurance as part of the purchase, not just peak read speed.
Crucial defines SSD endurance as the amount of data that can be written over the device's life, commonly expressed as TBW. Its SSD endurance explanation provides the useful comparison metric: estimate annual scratch writes, multiply by the intended service life, and leave margin for larger future projects.
Do not overreact and buy enterprise flash for a light home studio. If the scratch tier writes 100GB on a busy day but is idle most of the week, normal consumer TLC endurance can still be ample. The reason to move up is a measured sustained write budget, not the word “creator.”
Also protect thermals. Sustained writes can heat small NVMe devices enough to reduce performance. A scratch SSD that repeatedly throttles during long proxy or cache jobs may need better airflow or a heatsink before it needs a faster interface.
An All-SSD NAS Is Usually a Different Purchase Decision
Adding one scratch SSD does not mean the archive should move to flash. Large media libraries, completed jobs, backups, and source footage that already stream fast enough often gain little from paying SSD prices across every terabyte. Hybrid storage is usually the more efficient creator design.
StorageReview's current SSD-versus-HDD placement guide makes this distinction explicit: active work benefits from flash latency and throughput, while bulk media and backup remain capacity-driven workloads where HDD economics still matter.
Use the scratch SSD for data that is hot, temporary, and easy to recreate. Use the main protected pool for original media, project files that matter, exports, and archives. If the majority of daily work becomes random I/O against small active datasets, then an all-SSD app or project pool becomes a separate decision rather than an automatic extension of the scratch purchase.
The practical upgrade test is simple: remove or relocate the scratch workload for one trial and compare project responsiveness. If the measurable improvement is small, spend the budget on faster networking, more RAM, larger protected capacity, or workstation storage instead.
Pay for Shared Scratch Only When the NAS Is Already Part of the Active Workflow
A shared scratch tier is most valuable when the NAS is not merely an archive but an active production node. Examples include server-side proxy generation, centralized transcodes, several editors using the same high-speed project tier, shared ingest automation, or a render pipeline that produces large temporary files on the server.
Independent editor Daniel Grindrod describes using a dedicated SSD for Premiere cache and scratch while managing cache growth so the device does not need to be enormous. That dedicated-scratch workflow illustrates the economic point: the SSD earns its place by serving a defined temporary workload, not by duplicating the whole media library.
| Creator workflow | Scratch SSD value | Better first upgrade if not |
| Single photographer, local catalog and cache | Low to moderate | Local workstation SSD or more archive capacity |
| Single video editor, NAS source media | Moderate if previews/proxies hit NAS | Faster client link if network is saturated |
| Shared proxy/transcode workflow | High | Confirm CPU/GPU is not the bottleneck first |
| Several editors on active shared projects | High when temporary I/O causes contention | 10GbE or faster active storage path may also be required |
| Archive and backup NAS only | Low | Capacity, redundancy, and independent backup |
A ZimaBoard 2 fits a compact creator NAS when two SATA drives cover the protected library and PCIe expansion can add a defined NVMe working tier. Choose the 832 for a straightforward first NAS and lighter apps; the 1664 makes more sense when media indexing, containers, virtual machines, or more application state share the platform.
A ZimaCube 2 is the clearer route when a creator already needs six HDD bays, a long-lived archive, and a separate SSD tier inside the same chassis. Standard is enough for lighter active workflows; Pro becomes justified when stronger CPU headroom, 10GbE, and the faster 7th-bay SSD path are real requirements. Buy the scratch SSD when it removes a measured temporary-I/O constraint, not because the NAS has room for one.
Buying Guide
How to Choose a Plex Server for a Multi-User Household
A scenario-fit guide for households that turns “many users” into concrete playback, uptime, storage, and recovery requirements.
How to Choose Plex Server Hardware for Multiple Simultaneous Streams
A sizing-first buying guide for multi-stream Plex servers that prioritizes the workload bottleneck and deweights specs that do not raise real capacity.
Do You Need a Dedicated Plex Server? Who Should—and Shouldn’t—Buy One
A scenario-fit buying guide that makes “keep using your current PC” a valid answer when Plex does not need its own always-on hardware.
