A NAS is a strong fit for digital artists when large project files have outgrown one workstation or a pile of direct-attached drives, but the right system depends on whether the NAS will hold active work, finished archives, or both. If your current desktop storage is still fast, organized, and easy to protect, keep the active files local and buy network storage for centralization rather than assuming every asset must move onto the NAS. The decision changes when active projects, shared libraries, or long-term growth repeatedly exceed what one machine can manage.
Decide Whether the NAS Is an Active Workspace or an Archive
Start with the role of the storage, because “large assets” can describe very different I/O patterns. A painter with layered PSD or PSB files may open a few huge files at a time, while a 3D artist can touch thousands of textures, caches, references, and render outputs in one project. An archive-focused NAS mainly needs dependable capacity and retrieval; an active-work NAS has to feel responsive while applications repeatedly save, relink, preview, and autosave.
A useful purchasing boundary comes from this network-attached storage guide: network speed and drive configuration have to be considered together. A fast Ethernet label cannot make a slow storage pool behave like a local NVMe drive, and a fast pool cannot help if every workstation reaches it through a slower link.
For many solo artists, the safest default is a two-tier workflow. Keep scratch files, caches, and the hottest project data on a local SSD, then use the NAS as the authoritative project library, versioned backup target, and shared asset repository. That avoids paying for workstation-like performance across every terabyte of cold textures, reference packs, renders, and completed client work.
Move active work fully onto the NAS only when that change removes a real friction point: several workstations need the same assets, projects are too large to keep replicated locally, or local-to-NAS copying has become a daily bottleneck. If none of those conditions is true, prioritize capacity, backup, and organization before higher-end networking.
Size Capacity From Growth and Version History, Not Today’s Folder
Digital art libraries grow in bursts. A new client can add source references, alternate compositions, texture variants, exports, simulation caches, and delivery versions long after the “final” artwork appears finished. Capacity planning should therefore include current source files, working versions, generated outputs, and the years you expect to keep them.
Backblaze’s NAS capacity planning guidance recommends building future growth into the purchase rather than sizing only for the data already on hand. The exact multiplier should come from your own history, but the principle is more important: measure how much your library grows per month or year, then reserve room for versions and redundancy before choosing drive count.
Drive bays become a decision variable when growth no longer fits comfortably inside a two-drive design. More bays can give you room to increase usable capacity without replacing every disk at once, but they also raise enclosure, drive, power, and maintenance costs. A larger chassis is justified by sustained growth or a long retention horizon, not simply because the current asset folder looks intimidating.
Do not count RAID or mirroring as extra backup capacity. Redundancy can keep a storage pool available after a drive failure, but deleted layers, overwritten project folders, corruption, theft, and accidental synchronization can still affect the live copy. Budget capacity for both the primary NAS and at least one independent recovery copy.
Match Network Speed to the Part of the Workflow You Actually Feel
Network speed matters most when the NAS participates directly in opening, saving, previewing, or rendering active projects. If the NAS mainly receives overnight backups and completed jobs, even a modest network may be acceptable. If large layered files are opened dozens of times a day, a slower link can turn every save or relink into visible waiting.
ZimaSpace’s guide to choosing NAS speed for active creative work is useful even when your output is illustration or 3D rather than video: the whole path matters, including client NICs, switch ports, cabling, the NAS interface, and the storage pool behind it. Upgrade the path that is actually saturated rather than buying the fastest interface first.
Shared production adds another trigger. OWC’s article on automating shared-storage workflows shows why centralized media becomes more valuable when several roles need the same source files and backups. For a digital-art studio, the equivalent is avoiding duplicate texture libraries, conflicting project folders, and manual handoffs between a workstation, render machine, and laptop.
A practical buy rule is to test one representative project before upgrading the network tier. Time a large save, a project open with many linked assets, and a batch export while another machine is using the NAS. If the network is not the bottleneck, spend first on storage layout, local scratch capacity, or backup; if it is repeatedly saturated, faster networking becomes a workflow purchase rather than a specification purchase.
Protect Working Files and Finished Art Beyond the NAS Chassis
Centralization makes asset management easier, but it also makes the NAS more important. A bad permission change, ransomware event, accidental folder move, or failed application can affect a large body of work at once. The purchase therefore needs a recovery path that survives the primary server, not only redundant disks inside it.
The 3-2-1 backup model remains a useful baseline: keep multiple copies across separate devices or media, with one copy off-site. For an artist, that can mean local active work, a NAS copy with version history, and an independent off-site or offline copy that cannot be destroyed by the same event.
Version history deserves special attention because creative files are often damaged logically rather than physically. A PSD may save correctly but lose needed layers; a 3D scene can reference a texture that later gets replaced; a folder sync can propagate an unwanted deletion. Snapshots or versioned backups can shorten recovery, but they still need retention rules so useful history is not silently pruned too soon.
If client work is irreplaceable, recovery testing should be part of the buying decision. Restore a representative large project, confirm linked assets reopen, and measure how long a useful recovery takes. A NAS that is fast during normal work but painful to restore from is not a complete fit for professional assets.
Map the Workload to a Zima System Only After Those Thresholds Are Clear
For a digital artist whose active scratch space stays on the workstation and whose central library still fits a two-drive plan, ZimaBoard 2 1664 is the more natural ZimaBoard 2 starting point. Its dual SATA ports and dual 2.5GbE networking suit a compact creator NAS, while the 1664 model provides more memory headroom when file services share the box with indexing, sync, media, or other containers.
The decision flips toward ZimaCube 2 Standard when the real problem is multi-drive capacity, longer growth, or keeping more large projects online at once. Its six HDD bays create a different expansion envelope than a compact two-drive server, so the upgrade is justified by storage shape and retention rather than by the word “creator.”
ZimaCube 2 Pro is the stronger fit when the NAS becomes an active production tier and a faster end-to-end path is already justified. The current product configuration adds 10GbE and higher-speed SSD expansion for more demanding active projects; that matters when measured workflow tests show the standard storage or network path is limiting work. The Creator Pack should be reserved for a separate requirement for local GPU or AI compute, not treated as the default answer to large files.
Do not buy a new server if your current workstation plus a reliable backup already solves the workflow. Buy ZimaBoard 2 when compact centralized storage and moderate creator services are enough; step up to ZimaCube 2 when bay count, retained capacity, concurrent access, or active-work bandwidth crosses a clear threshold.
Final Buy Check
Write down the largest active project, the current full library, annual growth, required version history, number of simultaneous workstations, and the recovery copy that will exist outside the NAS. Those six facts will eliminate more bad purchases than comparing CPU names alone.
If the NAS is mostly an archive, optimize for usable capacity, redundancy, quiet placement, and backup. If it is an active workspace, test the storage and network path with real saves and asset relinks before paying for a faster tier. The large-project NAS checklist is also useful when those assets must move between a studio and remote machines. If it serves several machines, include permissions and shared-folder design in the ownership cost.
The strongest purchase is the smallest system that clears today’s workload while leaving a credible growth path. Oversizing every tier at once can strand budget in unused bays, network gear, and compute; undersizing the storage shape can force an early migration that is far more disruptive than adding a workstation SSD.
For digital artists with genuinely large assets, the key decision is not “NAS or no NAS.” It is which data belongs on the network, how fast that tier must be, how quickly it grows, and how it will be restored when the primary copy is unavailable.
Buying Guide
