For a NAS whose goal is safe shutdown rather than hours of continued operation, a short tested UPS window is usually enough. A useful shopping range is often around 5 to 20 minutes at the real connected load, but the correct target is the time needed to detect the outage, wait through brief power flickers, stop applications or virtual machines, shut the NAS down cleanly, and still leave battery reserve. Buy more runtime only when you deliberately want to ride through longer outages or keep network services online.
Decide Whether You Are Buying Shutdown Time or Uptime
The first UPS decision is not VA size; it is what should happen after utility power disappears. A shutdown-only system needs enough battery time to recognize the outage, complete an orderly stop, and retain reserve. A ride-through system is expected to keep operating through short outages, while a continuity system may need to bridge to a generator or much larger battery source.
The ZimaSpace guide for homes with frequent power outages makes the same distinction: the core objective is a controlled stop and predictable recovery, not indefinite battery operation. That is the right baseline for most home NAS buyers.
Write down which services truly need to remain available during a brief outage. File sharing may be allowed to stop immediately, while a router, modem, or home-automation service may be worth keeping online for a few extra minutes. Every device kept on the battery consumes runtime, so continuity should be intentional rather than accidental.
If the household has a standby generator, the UPS may only need to bridge startup and transfer time plus a safety margin. If outages commonly last hours and there is no generator, a small desktop UPS should still be sized around safe shutdown rather than being stretched into an unrealistic whole-home battery.
Measure Watts at the Load the UPS Will Actually See
UPS runtime is determined by the battery system and the connected load, not by the VA label alone. Measure or estimate the real wattage of the NAS with its installed drives, then add any router, modem, switch, external drive, or other equipment that will share the battery output. Use a busy operating state rather than the lowest idle figure.
CyberPower's UPS buying guidance recommends keeping the UPS's watt capacity above the connected equipment load and notes that runtime falls as connected load increases. The exact sizing margin varies by product and buyer, but the purchasing lesson is universal: evaluate the runtime curve at your load, not at zero load or from VA alone.
Include spin-up or active-disk behavior where practical, especially when several hard drives are installed. Also account for network equipment if the NAS receives UPS status over the network or needs connectivity to send alerts before shutdown. A UPS that gives 20 minutes to the NAS alone may provide much less after a modem, router, switch, and another server are connected.
Shortlist UPS models only after you know the approximate watt load. Then compare the manufacturer's runtime estimate or curve at that load and confirm that the unit also has enough output wattage and the required USB, network, or management interface for automated shutdown.
Build a Shutdown Timeline, Then Add Reserve
The minimum runtime should cover the entire shutdown sequence, not just the operating system's final power-off seconds. Add the intentional outage delay, time for containers or virtual machines to stop, database flushing, storage-pool shutdown, and the NAS power-off process. Then leave reserve so the battery is not exhausted at the exact moment shutdown completes.
Synology's current DSM UPS guidance recommends verifying behavior with a power-outage simulation before production use. Even if a buyer uses a different NAS platform, that validation principle is valuable: the configured shutdown path must be proven with the actual UPS and real service stack.
| Shutdown stage | Example planning time | What changes it |
| Outage confirmation | 1–3 minutes | Whether brief flickers are common |
| App / VM stop | 1–5+ minutes | Databases, VMs, backup jobs, containers |
| NAS shutdown | 1–3+ minutes | Platform, storage pool, drive count |
| Reserve | Several minutes | Battery aging, load error, repeated outage |
For example, a system that waits two minutes before shutdown, needs three minutes to stop services, and takes two more minutes to power off already consumes seven minutes before reserve. That does not make 10 or 15 minutes a universal target, but it shows why a measured shutdown timeline is more useful than buying by VA class.
Keep Only Essential Network Gear on Battery
Keeping the router and modem powered can preserve remote alerts, UPS communication, and a short window of internet access during an outage. It can also reduce the time available to the NAS. Decide whether each network device serves the shutdown process or merely keeps optional connectivity alive.
UPS management software can make this trade-off visible. CyberPower's PowerPanel, for example, supports load and runtime monitoring with automatic shutdown. Buyers should look for equivalent management support on the platform they intend to protect, rather than assuming every USB-equipped UPS will integrate with every NAS.
If multiple servers share one UPS, coordinate the shutdown order. A secondary app server can stop early, while the NAS or network device responsible for UPS signaling may need to remain powered longer. The runtime requirement is therefore the duration of the complete dependency chain, not the shutdown time of the first device.
A separate small UPS for networking can sometimes be cleaner than putting every device on one large battery, especially when the NAS should shut down quickly but the household still wants internet or home-automation connectivity. Buy the topology that makes failure behavior understandable, not the topology with the largest headline number.
Account for Battery Aging and Test the Real Outage Sequence
UPS runtime is not permanently fixed. Battery condition, temperature, load, and age change the amount of usable energy available. A shutdown plan that only works when the battery is new and fully charged has too little margin for a storage system that is expected to run unattended.
The ZimaSpace support article on NAS UPS protection during outages explains why clean shutdown and recovery testing matter. Use that as an operating requirement when buying: the UPS must communicate reliably with the NAS and leave enough energy for the configured action to finish.
After installation, run a controlled outage test by removing utility input to the UPS while leaving the protected equipment connected normally. Confirm that the NAS detects the event, waits the intended amount of time, stops services in the right order, shuts down with visible battery reserve, and returns in the desired state when stable power comes back.
Repeat the test after major storage or service changes and periodically as the battery ages. Adding drives, moving more network hardware onto the UPS, or extending the shutdown delay can turn a previously adequate runtime into a marginal one without changing the UPS itself.
Choose Runtime From the Consequence of Waiting
APC's current UPS buying guide describes short battery runtimes in the range of roughly 5 to 20 minutes depending on load and model as typical for systems intended to bridge brief outages or allow graceful shutdown. Treat that as a shopping reference, not a requirement for every NAS.
| Goal | Runtime decision |
| Safe shutdown only | Enough tested time for the full shutdown sequence plus reserve |
| Ride through brief outages | Add the outage duration you intentionally want to tolerate before shutdown |
| NAS plus network gear | Recalculate runtime at the combined watt load |
| Bridge to a generator | Cover generator start/transfer time, failed-start allowance, and shutdown reserve |
| Hours of continuous operation | Consider a larger battery or energy system rather than stretching a small UPS |
The final buying rule is to choose the UPS from actual watts and tested runtime at that load. A larger VA number does not automatically mean enough usable minutes, and an oversized runtime is not automatically valuable if the NAS should shut down after a short outage anyway.
For most home NAS installations, the best UPS is therefore the smallest well-integrated unit that can complete the chosen shutdown policy with comfortable reserve under the real connected load. Buy additional runtime only when you can name the service or outage condition that benefits from staying online longer.
Is a 1500VA UPS automatically better for a NAS?
No. VA is only one part of the specification. Compare the UPS's output watt rating, battery capacity, runtime curve at your measured load, communication support, and shutdown integration. A lower-VA unit with enough watt capacity and verified runtime can be a better fit than a larger unit whose extra capacity is not useful to the NAS.
Should a NAS shut down as soon as utility power fails?
Not always. A short delay can prevent unnecessary shutdowns during momentary flickers or very brief outages, but every minute of delay consumes battery reserve. Set the delay from local outage behavior and then test that the complete shutdown still finishes comfortably before the UPS reaches a low-battery state.
Buying Guide
