A NAS makes sense for home security cameras when you want local retention, multiple camera streams, or one storage system that is easier to expand than individual SD cards or a small recorder. Do not choose capacity from camera resolution alone, and do not assume local AI is required for basic recording. The purchase changes mainly with total stream bitrate, camera count, retention days, recording mode, and whether the NAS also has to analyze footage in real time.
Translate the Camera System Into a Sustained Storage Workload
Security storage is different from a typical family file share because cameras can write for hours without stopping. Four cameras that record only on events behave very differently from eight cameras recording continuously, even if the camera boxes advertise similar resolution. Start with the streams you actually plan to store.
Backblaze’s guide to video surveillance storage requirements identifies the variables that matter: camera count, resolution, frame rate, retention period, and recording behavior. Treat those as inputs to the NAS decision instead of buying a drive size first and hoping the retention fits.
Bitrate is the best bridge between camera settings and storage. Two cameras at the same nominal resolution can consume different space because compression, scene motion, image quality, and frame rate differ. Record the average bitrate from each configured camera or NVR profile, then calculate daily storage and multiply by the retention window.
Add margin for busy scenes, firmware changes, additional cameras, and periods when event activity rises. If your capacity estimate only works when every camera stays at an ideal average, the NAS is undersized before it is installed.
Choose Retention and Recording Mode Before Choosing Drive Bays
Retention is a policy decision with a hardware consequence. A household that needs a week of event clips may fit comfortably on a small system; continuous recording across several cameras for a month or more can turn retention into the dominant storage cost. Longer is not automatically better if nobody ever reviews the oldest footage.
Axis notes in its surveillance compression guidance that lowering bitrate reduces storage but can remove useful detail if pushed too far. That is why retention should be tuned with image quality and evidence needs together rather than treated as a simple “more days” target.
Event-based recording can reduce capacity demand dramatically in quiet environments, but it also depends on detection rules working as expected. Continuous recording consumes more storage yet preserves context before and after events. Many households use a hybrid approach: continuous lower-bandwidth recording with higher-quality event clips, or continuous recording only for the most important cameras.
Drive-bay count should follow the usable-capacity and redundancy calculation that comes out of this policy. If a two-drive system meets the retention target with growth room, more bays may be unnecessary. If the target requires several drives now or will do so soon, buy the larger storage shape before the camera count grows into a forced migration.
Separate Recording Reliability From Optional AI Analytics
Recording and analytics are different workloads. A NAS can reliably receive and store camera streams without recognizing people, pets, vehicles, or packages. Adding local detection introduces CPU, memory, accelerator, and application requirements that should be justified by a feature you actually plan to use.
ZimaSpace’s article on local AI for home security cameras shows the value of keeping analysis near the footage, but local processing does not make every camera system an AI-NAS purchase. If your goal is simply dependable retention and playback, prioritize storage endurance, network stability, and recovery first.
Analytics becomes a purchase trigger when the server must process several streams, run Frigate or similar software, classify objects, search events, or integrate detections with Home Assistant. Even then, test how many streams the intended application processes at the chosen resolution and detection rate rather than using raw camera count as the compute estimate.
Keep a stop boundary: if your cameras already perform the needed detection at the edge and the NAS only stores their recordings, do not pay for GPU-class hardware solely because “AI cameras” sounds future-proof. Add compute when central analytics creates a real automation or review benefit.
Match Drive Type and Redundancy to Continuous Camera Writes
A camera NAS spends much of its life writing sequential video while older footage expires. That differs from a general home server that may host documents, databases, media, containers, and backups at the same time. The drive choice should reflect whether the storage pool is dedicated to surveillance or shared with other workloads.
ZimaSpace’s guide to choosing drives for a NAS distinguishes surveillance HDDs for camera recording from NAS HDDs for general home storage and RAID. That distinction matters when a single server is expected to hold both continuous footage and family files: the best drive for one workload is not automatically the best mixed-use default.
Redundancy protects availability when a drive fails, but it does not make archived footage a backup. Decide which recordings are worth preserving after the normal retention window—such as a confirmed incident—and export those clips to another device or off-site location. Most routine footage can continue to expire according to policy.
Also reserve capacity for rebuilds and maintenance. A pool that operates permanently at the edge of its capacity has less room for retention spikes, temporary exports, and background storage work. Buy enough headroom that normal variation does not force emergency deletion.
Map Camera Count, Retention, and Analytics to the Right Zima Tier
For a small camera setup where Home Assistant, local recording, and limited detection all fit inside a two-drive capacity plan, ZimaBoard 2 1664 is the stronger ZimaBoard 2 choice. It has dual SATA for direct storage, dual 2.5GbE, and PCIe expansion; the current product page also positions the platform for local Home Assistant and Frigate use with an accelerator when needed.
If the cameras only need recording and the service stack is light, the 832 can be enough; do not choose 1664 only because cameras are involved. Conversely, a two-drive platform stops being the right storage shape when continuous footage, retention, and growth require more disks. That is a storage threshold, not a CPU threshold.
Move to ZimaCube 2 Standard when multi-bay capacity and longer retention are the primary need. Its six HDD bays provide more room for a sustained recording pool and future cameras, while still supporting other home-server roles. ZimaCube 2 Pro or Creator Pack should be considered only when heavier concurrent services, 10GbE, faster active storage, or dedicated GPU analytics are separately justified.
If an existing NVR already meets retention, playback, and reliability requirements, keep it. A new NAS is most valuable when it solves a clear limit—insufficient retention, difficult expansion, fragmented camera storage, or a deliberate move toward local smart-home integration.
Final Buy Check
Record the number of cameras, measured average bitrate for each recording profile, hours recorded per day, required retention days, and whether recording is continuous, event-based, or hybrid. Convert those inputs into a usable-capacity target before comparing NAS models.
Then decide whether the server only stores footage or also performs detection, automation, media, backups, or other household services. Storage scale chooses the bay class; analytics and concurrent applications choose the compute tier. Keeping those decisions separate prevents overbuying.
ZimaSpace’s existing camera recording and smart-home buying guide provides the adjacent boundary: combining continuous video with automations increases both storage and service responsibility. If you only need one of those jobs, size for that job rather than inheriting the combined workload.
The right camera NAS is the smallest system that meets measured retention with headroom, stays reliable under sustained writes, and adds only the compute you need for local analysis. Camera resolution is an input, but bitrate, retention, and workload separation make the purchase decision.
Buying Guide
