A DIY NAS can cost less over time when you already own suitable, efficient hardware, need specialized expansion, and are comfortable maintaining the system. A prebuilt NAS can cost less when its integrated software, warranty, compact design, and lower setup burden prevent extra spending later.
The fair comparison is not the price of an empty enclosure. Compare the same storage capacity, networking, backup plan, electricity use, software, replacement risk, and the amount of maintenance you are genuinely willing to own over the next several years.
Define “Costs Less” Before Comparing Hardware
Start with a five-year ownership model, not a checkout-page price. Your comparison should include the diskless NAS or DIY platform, hard drives, software or subscriptions, electricity, replacement parts, and any network gear required to use the system as intended.
Use the same drive capacity and backup plan on both sides. Hard drives, external backup disks, and off-site storage do not disappear because you choose DIY, so excluding them from one option makes the result look cheaper without making it more useful.
A practical formula is: five-year cost = platform + drives + software/services + electricity + expected replacements + optional value of your maintenance time. You do not need to put a dollar value on every hour of administration, but you should decide whether weekend troubleshooting is part of the hobby or an unwanted cost.
Price the Same Starting Point
Match capacity, bays, and connectivity first
A low-cost DIY build is not automatically comparable to a prebuilt NAS with different drive-bay capacity, faster networking, or NVMe expansion. Before comparing prices, decide how many drives you need now, how many you expect to add, whether you need 2.5GbE or 10GbE, and whether active projects need an SSD tier.
For DIY, include every required item: case, motherboard, CPU, RAM, power supply, boot drive, cooling, operating system, network adapter, cables, and any storage controller. For a prebuilt NAS, check what is included versus what still needs to be added.
Reuse changes the equation only when the parts are suitable
A modern spare PC can make DIY genuinely inexpensive because its purchase cost is already sunk. An old desktop that needs a new power supply, additional SATA connectivity, more RAM, or repairs is not free hardware—it is the beginning of a parts list.
If the five-year totals are close, the hardware trade-offs between a ZimaCube and a ground-up build matter more than a small difference in initial price.
Electricity Is a Recurring Cost, Not a Footnote
A NAS that runs all day turns small wattage differences into a recurring expense. Use average measured wall power where possible, rather than CPU TDP or the maximum rating printed on a power supply. The ENERGY STAR Small Network Equipment test procedure is a useful reminder that repeatable power measurements need defined operating conditions.
Use this calculation: annual electricity cost = average watts ÷ 1,000 × 8,760 × local electricity rate per kWh. For example, a 40W average-power difference equals 350.4 kWh per year. At $0.20 per kWh, that difference is about $70.08 each year, or $350.40 over five years.
That does not mean every prebuilt NAS uses less electricity. A carefully selected low-power DIY system may be efficient, while an older desktop or enterprise server can cost more to run. Drives, sleep settings, always-on applications, cooling, and power-supply efficiency all affect the measured result.
To calculate your own number from the hardware you are considering, use the annual electricity formula for a NAS that runs around the clock with your local rate rather than relying on a generic annual-cost claim.
Account for Software, Support, and Replacement Risk
Included software still has value
A prebuilt NAS usually bundles its operating system, update path, mobile access tools, and basic storage-management interface. A DIY system may use free software, paid software, or a combination of services. Neither route is automatically better, but the cost comparison should include any license, remote-access service, or backup feature you actually plan to use.
Repairability and support solve different problems
DIY hardware can be easier to repair because a failed fan, power supply, or network card can often be replaced individually. A prebuilt NAS can reduce the time needed to identify a fault by offering a defined hardware and software environment plus a single warranty path.
Choose DIY if sourcing parts and diagnosing failures is acceptable to you. Choose prebuilt if predictable setup and support reduce a cost you would otherwise pay in time, outside help, or disrupted access for the household.
Capacity Growth Can Reverse the Decision
For a small household archive, buying more expansion than you will use can make either option unnecessarily expensive. A compact prebuilt NAS may be the lower-cost route when the required capacity, number of users, and services are stable.
DIY becomes more compelling when you know that you need an unusual number of bays, additional PCIe cards, ECC memory, a particular operating system, or several services beyond storage. In those cases, the ability to choose each component can prevent a costly platform change later.
Plan expansion before the first purchase. Ask whether the next capacity increase means adding drives, replacing all existing drives, adding a network card, buying an expansion unit, or rebuilding the platform. The answer is often more important than a small discount on the initial enclosure.
Put a Realistic Value on Your Time
Time is not a universal dollar figure. Some owners enjoy building, tuning, and learning from a NAS; for them, maintenance is part of the return on a DIY build. Others want family backups, shared files, and media access to work with minimal intervention.
List the tasks you are accepting: assembly, operating-system installation, updates, user permissions, remote access, backup testing, drive replacement, and recovery practice. A prebuilt NAS can reduce the number of decisions; a DIY NAS can provide more control over every decision.
The lower-cost choice is the one whose required maintenance matches your comfort level. A system that is inexpensive to buy but never properly updated or backed up is not economical when it holds important data.
Which Cost Profile Fits a ZimaCube Setup?
A ZimaCube can make sense when you want an integrated starting point but still need room to separate large-capacity media from fast active storage. The ZimaCube hardware overview documents six SATA bays and four M.2 NVMe bays, a layout that can support an HDD capacity pool alongside a faster workspace tier.
Choose that type of prebuilt platform when the cost of validating separate DIY parts, adding expansion later, and managing a custom software stack outweighs its purchase-price difference. It is especially relevant when the NAS will be shared by people who need dependable access rather than another project to maintain.
Choose DIY when you already have efficient compatible parts, need a custom number of bays or cards, or want the system itself to be part of your homelab. Neither route wins for every buyer—the five-year model should reflect your capacity plan, local electricity price, and maintenance preference.
Is a DIY NAS always cheaper if I already own an old PC?
No. Old hardware can remove the platform purchase cost, but its average power use, noise, required upgrades, and reliability may still make it more expensive over time. Measure or estimate those items before assuming the old PC is the cheaper option.
How do I calculate a NAS’s five-year electricity cost?
Multiply the average watts by 8,760, divide by 1,000 to get yearly kWh, multiply by your local electricity rate, then multiply by five. Use average measured power under your expected workload when possible.
Should hard drives be included when comparing DIY and prebuilt NAS costs?
Yes, but use the same drives and backup plan for both options unless the storage architecture is meaningfully different. The most useful comparison isolates the platform cost while still showing the complete amount you will spend to store and protect your data.
Buying Guide
How to Choose a Home Server for Jellyfin and Kodi
Kodi can reduce Jellyfin transcode demand when clients Direct Play well, so size the server from fallback conversion, storage, network, and shared services.
How to Choose SSD, HDD, and Backup Capacity for Jellyfin
Size Jellyfin storage by role: SSD for active app data and scratch, HDD for media capacity, and independent backup space for retained recovery points.
Before Buying a Jellyfin Server: Can Your Old PC Pass the Workload?
Reuse an old PC only after it passes the real Jellyfin workload, power, noise, storage, and recovery checks a new server would need to...
