Thank you to u/pocholabs for sharing ZimaOS Monitor, a community-built service that sends a ZimaBoard 2’s system metrics into Home Assistant through MQTT. The project turns CPU, memory and storage readings into entities that can be viewed alongside the rest of a home’s monitoring information.
The original Reddit announcement explains the motivation: a friend’s retro AT-style ZimaBoard 2 case needed live information for its small display. Pocho Labs built the ZimaOS-side service to expose those readings. The result is useful beyond that one enclosure because Home Assistant can receive the same information without a dedicated front-panel screen.
A Display Idea Creates a Reusable Monitoring Service
The creator describes ZimaOS Monitor as a Go service that collects host statistics and publishes them over MQTT with Home Assistant discovery. Its initial purpose was to supply real system information for a maker project, rather than show decorative numbers on a display.
Our retro AT-style ZimaBoard 2 case story follows the enclosure and creative workflow. The monitoring project provides the software connection that makes the system readings available to Home Assistant. The creator links its source in the Pocho Labs zimaos-monitor repository.
The ZimaBoard 2 is the demonstrated hardware reference for this story. In the announcement, the author invites testing on other Zima devices but says they do not have those machines to confirm compatibility. That distinction matters when reading a project description that names several possible hosts.
CPU, RAM and Storage Become Named Entities
The announcement lists CPU temperature and power, RAM utilization and capacity, per-disk used percentage and free space, and installed-versus-latest ZimaOS version information. These readings cover different operational questions. A warm processor, a nearly full data volume and an available software update call for different kinds of attention.
The original screenshot makes those categories tangible. It shows a device identified as ZimaBoard2, a set of CPU and memory readings, and separate storage readings for the system volume and an SSD volume. The numbers are observations captured in that image, not a benchmark or a promise about another device’s idle consumption.
| Reading | Question it helps answer |
| CPU temperature | How is the reported processor temperature changing? |
| CPU power | What does the supported processor telemetry report? |
| RAM usage and availability | How much memory is in use or still available? |
| Storage use and free space | Which monitored volume is approaching its capacity? |
| ZimaOS update information | How does the installed version compare with the reported available release? |
CPU power is especially easy to misread. The project uses Intel RAPL for that metric, so the displayed value should not be presented as a wall-socket measurement of the board, disks, adapter and other equipment together. The measurement source defines what the number can tell a reader.
MQTT Discovery Reduces Repetitive Entity Configuration
The creator’s Home Assistant announcement describes a minimal configuration centered on the MQTT broker, with a 30-second reporting interval in its example. Device details and storage information are detected by the service rather than typed separately for every sensor.
Home Assistant’s MQTT documentation explains the underlying publish/subscribe integration and discovery mechanism. The broker carries messages between the service and Home Assistant. Discovery describes the entities; subsequent readings supply their changing states.
That is the useful meaning of the project’s “no manual YAML” claim: the owner does not need to define every Home Assistant sensor individually. A working MQTT broker and a functioning connection are still part of the arrangement. The project is a community service with its own configuration, not evidence that a stock ZimaOS installation automatically appears in every Home Assistant instance.
History Gives a Reading More Context
A current temperature answers what the sensor reports now. A history graph makes changes over time visible. The repository’s original screenshot shows a temperature trace with short peaks against a steadier baseline, providing a different view from a single number on the device page.
A graph can help an owner relate a change to another event, such as an application task or a change in room conditions. It does not identify the cause by itself. The pictured history also does not document an automatic fan controller or a response rule; it demonstrates visibility into a sensor’s past readings.
This makes the monitoring service a useful starting point for a household dashboard. Before adding an automation around a reading, the owner can first observe the normal pattern and confirm that the value updates as expected. That is a practical use of the exposed data, rather than an automation claimed to be installed in the creator’s screenshot.
A Version Entity Informs the Owner About an Update
The original project documentation includes an update-entity screenshot with installed and available ZimaOS versions and a release-announcement link. Those version numbers belong to the historical screenshot. They are not a statement of the current ZimaOS release or an instruction to downgrade a system.
The current repository documentation also distinguishes update information from installation: ZimaOS releases are installed through the ZimaOS interface. A notification that another version exists should not be confused with a demonstrated remote update action from the original device page.
The Community Feedback Helps Define the Boundary
Replies to the announcement include owners whose device did not appear after configuration. The author asks for service logs, configuration details, ZimaOS version and visible MQTT topics, with sensitive information removed. That is a more useful troubleshooting starting point than assuming the absence of a device proves the sensors themselves are unsupported.
Our small homelab story from u/jc-21 also shows why a clear inventory matters. For monitoring, that inventory includes the host service, broker and receiving application. Knowing which link is working narrows the next question.
Is ZimaOS Monitor an official built-in feature?
The source describes a community-built Go service from Pocho Labs. Its repository provides the project documentation and source.
Has every Zima device been tested by the creator?
No. The original announcement reports testing on ZimaBoard hardware and asks others to try additional devices. It does not establish confirmed testing across the whole product family.
Does the CPU power sensor measure the whole server?
No. It uses processor telemetry through Intel RAPL. A complete system’s power at the socket is a different measurement.
Do the screenshots show configured automations?
The original device page shows sensor and update information, with no device automations added. Monitoring data can inform later work, but the screenshot does not prove an automatic response was deployed.
Conclusion
Pocho Labs turned a request for a small display into a reusable connection between ZimaOS and Home Assistant. The project’s value is practical visibility: named readings, storage information, history and update awareness in a familiar interface. Keeping the measurement sources and tested hardware clear makes that visibility easier to use and the community project easier to evaluate.
Zima Campaign Hub
Before First Boot: A ZimaBlade 7700 NAS Plan with Six Drives
A first ZimaBlade 7700 assembly pairs a six-drive cage with plans for TrueNAS, Jellyfin and Minecraft, before power and storage configuration are verified.
A ZimaBoard LEGO Prototype Looking for a Permanent Enclosure
A temporary LEGO support holds a ZimaBoard and NVMe card while the owner plans a low-cost enclosure for two extra SSDs without a 3D...
A Printed Ten-Inch ZimaBoard 2 Rack with Four Drive Trays
Gerrit3D documents a printed ZimaBoard 2 rack from threaded rails to drive trays and cabling, with original construction photographs and clear limits.
