Thank you to u/AdAcrobatic603 for sharing a ZimaBlade that serves as both a NAS and a small Linux desktop. Running Zorin OS 17.2 Lite, the build combines a 2 TB SSD, a reused desk-clamp USB-hub housing and a custom fan mount, with remote desktop access already working through NoMachine.
The original Reddit post and its edit document a useful progression: first getting the desktop running, then addressing warmth and reorganizing the hardware. The creator was still using a portable monitor when describing the setup; moving it next to the router as a headless remote desktop was the intended next step.
A NAS That Also Has a Local Desktop
A NAS is a role, and this ZimaBlade takes that role while running a desktop operating system. The creator reports being happy with Zorin OS Lite as both a file-serving machine and a portable DIY desktop. That makes the display connection part of the project rather than an accessory used only during installation.
The software version places the story in its original context. This is a Zorin OS 17.2 Lite build, not a claim about the latest Zorin release and not a ZimaOS installation. Zorin’s original 17.2 release announcement provides the historical release background.
For another builder, combining the two roles creates a practical question: what happens to shared files when someone restarts the desktop? Using one small computer for both jobs can reduce the number of devices on a desk, but a desktop maintenance action can also interrupt the NAS role. That dependency is worth making explicit before other people rely on the files.
An Old USB-Hub Housing Becomes the Enclosure
The enclosure began as a USB 3.0 hub designed to clamp to a desk. The creator reused its housing to contain the ZimaBlade and the 2 TB SSD. It is a small, specific reuse project: an existing object supplied a shape that could hold the computer and its storage together.
The photographs show the arrangement from the front, side and back. They are useful because they reveal the relationships between the components: where the fan sits, how cables leave the housing and where the SSD is positioned. A finished front view alone would leave much of that work invisible.
| Component or change | What the creator reports |
| ZimaBlade | NAS and portable desktop duties |
| Zorin OS 17.2 Lite | The installed desktop operating system |
| 2 TB SSD | Storage housed alongside the board |
| Reused desk-clamp USB-hub housing | Container for the assembled hardware |
| Fan on a custom faceplate | Added cooling, with a reported average temperature reduction |
| Portable monitor and NoMachine | Local display and working remote access |
The ZimaBlade hardware page is the relevant product reference for this story. The custom housing and faceplate belong to the creator’s modification; they should not be mistaken for accessories included with the board.
The Fan Mod Follows an Initial Temperature Observation
In the initial post, the creator reported CPU temperatures around 55–65°C and said the unit felt warmer than the number suggested. A Noctua fan and heatsinks were being considered. The later edit confirms a fan installed on a custom faceplate and reports an average reduction of 5–8°C.
That is a useful before-and-after observation from one owner, rather than a controlled thermal benchmark. The post does not establish matched workloads, ambient temperatures or a fixed measurement interval. It also does not confirm that every component originally in the shopping cart was installed. The supported result is the reported reduction after the fan modification.
What makes the change interesting is its sequence. The creator first noticed a behavior, then changed the physical build and checked the reported temperature again. For a similar project, recording workload and room temperature alongside the reading would make the comparison easier to interpret. Fan placement also needs to be considered with cable routing so that an enclosure modification remains serviceable.
NoMachine Connects the Desktop to Its Future Location
At the time of the update, a portable monitor was attached and NoMachine remote access worked. The plan was to move the system next to the router and use it as a headless remote desktop. Those are two different stages: remote connectivity was demonstrated, while the permanent headless placement was still described as a future arrangement.
NoMachine’s official getting-started guide explains the distinction between the computer being controlled and the connecting client. In this story, the ZimaBlade remains the computer running the desktop. A remote session provides access to that desktop from another device.
Before removing a local display from a similar system, a useful check is whether remote access works after a restart and whether the host can still be found on the network. This is an operational check for anyone adapting the idea, rather than a test result reported in the post. Keeping a temporary display available can also make a failed remote connection easier to diagnose.
The SSD Makes the Small Enclosure More Useful
The 2 TB SSD gives the combined desktop and NAS a storage component beyond the board itself. The rear photograph makes its place in the assembly visible. The source does not specify a mirrored second data disk or an independent backup destination, so the capacity should not be presented as a complete data-protection arrangement.
Our Proxbox 360 recycled-hardware story looks at another enclosure reuse project, while the ZimaBlade family photo server story explores the maintenance side of household storage. Together they give context for the two concerns visible here: fitting useful hardware into a small space and keeping its everyday role dependable.
Is this build running ZimaOS?
No. The creator explicitly reports Zorin OS 17.2 Lite. The official ZimaBlade overview provides separate hardware and operating-system background.
What did the creator reuse for the case?
An old desk-clamp USB 3.0 hub housing holds the board and 2 TB SSD. The fan was added to a custom faceplate.
How much did the fan reduce temperatures?
The creator reports an average drop of 5–8°C. The post does not provide the conditions needed to treat that result as a repeatable benchmark.
Was the system already running headless?
NoMachine access was working, but the update still described an attached portable monitor. The router-side headless desktop was the planned next stage.
Conclusion
This ZimaBlade project combines a working Linux desktop, a NAS role and a reused enclosure in a small assembly that the owner continued improving. Its clearest lesson is the value of documenting each stage: the original temperature observation, the fitted fan, the existing remote connection and the placement still to come. That progression makes the build useful to follow as well as interesting to look at.
Zima Campaign Hub
Before First Boot: A ZimaBlade 7700 NAS Plan with Six Drives
A first ZimaBlade 7700 assembly pairs a six-drive cage with plans for TrueNAS, Jellyfin and Minecraft, before power and storage configuration are verified.
A ZimaBoard LEGO Prototype Looking for a Permanent Enclosure
A temporary LEGO support holds a ZimaBoard and NVMe card while the owner plans a low-cost enclosure for two extra SSDs without a 3D...
A Printed Ten-Inch ZimaBoard 2 Rack with Four Drive Trays
Gerrit3D documents a printed ZimaBoard 2 rack from threaded rails to drive trays and cabling, with original construction photographs and clear limits.
