Thank you to u/-KTO- for sharing a first homelab built from a used HP ProDesk mini PC, external hard drives and ZimaOS. The machine has a specific household purpose: run Immich for photos and Nextcloud for files, using hardware small enough to sit beside the drives on a shelf.
The original Reddit post includes two photos and a candid installation follow-up. It captures an early working arrangement, including inexpensive printed drive stands and a temporary attempt to reduce vibration. It also shows why a first server becomes a practical learning project once applications, storage and physical placement come together.
A Used Mini PC with Two Familiar Applications
The creator identifies the computer as an HP ProDesk 400 G3 Mini with an Intel Core i5-7500T and 16 GB of RAM. ZimaOS provides the software environment, while Immich and Nextcloud give the server its initial jobs. The owner reports paying €50 for the computer at the time of the post.
That purchase price describes a particular used machine, rather than a current shopping recommendation or a complete build cost. The drive-capacity wording and the separate cost breakdown in the discussion do not line up cleanly enough to establish a verified total. The useful starting point is the component arrangement the owner actually describes.
| Part | Reported detail |
| Computer | HP ProDesk 400 G3 Mini |
| Processor | Intel Core i5-7500T |
| Memory | 16 GB RAM |
| Server operating environment | ZimaOS |
| Initial applications | Immich and Nextcloud |
| External storage | Two 3.5-inch hard drives connected over USB |
| Drive mounting | Small printed stands with temporary cushioning underneath |
ZimaOS Gives the Computer a Defined Household Job
Immich and Nextcloud make this more specific than simply installing a server operating system on an old desktop. One application organizes a photo collection; the other gives files a service of their own. That makes it easier for a beginner to judge progress through everyday tasks rather than a long app inventory.
A useful first milestone would be to upload a small test collection, find it again from another device and confirm where the files were stored. Those are suggested checks for someone following the story, not a test log supplied by this creator. They help connect an application’s interface with the storage it depends on.
Our budget i3 ZimaOS family-server story offers a related example of assigning media and photo duties to a modest computer. The comparison is about the intended household jobs, rather than evidence that different used PCs will behave identically.
The Installation Was Less Straightforward Than Expected
The owner was drawn to the interface and features and initially expected installation to be easy. In a reply, however, the creator says it was not. The discussion does not provide enough detail to identify the cause or reconstruct a reliable fix.
That makes the reply an important part of the story. A photograph of a completed installation cannot tell a new builder which firmware setting, boot medium or storage condition caused an earlier problem. Presenting this build as effortless would remove the part the owner specifically corrected.
Someone working through a similar first installation can keep a simple record of the hardware model, installer version, selected target drive and exact error message. That information makes a support question more useful. It should be treated as a general troubleshooting habit, rather than a solution discovered in this thread.
USB Storage Keeps the Drives Outside the Mini PC
The storage is physically separate from the ProDesk, connected through SATA-and-power-to-USB adapters. The second photo shows the cable side of the arrangement. It explains how a very small computer can be paired with larger desktop drives without fitting those drives inside its chassis.
The external arrangement also gives maintenance a physical dimension. Moving the computer, unplugging an adapter or changing a power connection can affect the applications using that disk. For another builder, labeling each drive and its cables would help keep a later replacement or troubleshooting session understandable.
The source does not establish a RAID configuration, a measured USB throughput result or an independent backup destination. Two visible drives therefore tell us how storage is attached, without proving that a particular redundancy or recovery policy has been configured.
Vibration Became an Early Physical Problem to Solve
The owner uses printed stands and places cardboard and bubble wrap underneath in an attempt to reduce drive vibration. The post asks whether that temporary arrangement could cause a problem. It does not supply operating temperatures, a noise measurement or a long-term assessment.
The photograph is useful precisely because it shows an unfinished practical decision. A drive stand has to support the hardware, while the surrounding arrangement also needs to leave connections and ventilation manageable. The thread does not validate this particular cushioning method as a design to reproduce.
For a reader, the sensible lesson is to observe the physical setup as carefully as the dashboard. Check whether a drive can move, whether a cable is strained and whether its operating temperature remains within the drive manufacturer’s specification. These are review questions, not results reported for this machine.
Photo and File Services Need a Recovery Plan of Their Own
Once a first server holds family information, the next milestone is being able to recover that information independently of the working installation. The original post does not describe a completed backup or restore routine, so it would be misleading to add one to the creator’s achievements.
For Immich, the official backup and restore documentation explains why the database and the photo/video assets both matter. Preserving a database alone does not preserve the original images. That is a useful distinction before a temporary test collection becomes the only copy of a family archive.
Nextcloud has its own requirements. Its administration backup guide identifies the application’s data, database and configuration among the components to preserve. A recovery plan should follow the installed application’s documented needs rather than assume that copying one visible folder will rebuild everything.
The ZimaBlade family-photo troubleshooting story explores that relationship between an application and its underlying data in more detail. Readers comparing a mini-PC-plus-USB arrangement with an integrated NAS can also use the ZimaCube 2 product page as a separate hardware reference. The creator’s computer here remains the HP ProDesk.
What hardware runs ZimaOS in this build?
The creator identifies an HP ProDesk 400 G3 Mini with an i5-7500T processor and 16 GB of RAM. The storage drives are connected externally over USB.
Which applications give the server its initial purpose?
Immich handles the photo-service role and Nextcloud provides file services. The post does not document a broader workload benchmark.
Was installing ZimaOS effortless?
No. Although the owner expected an easy start, a follow-up explicitly says installation was not easy. The cause and resolution are not documented sufficiently to reproduce them.
Is the temporary drive cushioning a verified recommendation?
No. It is the owner’s experiment to reduce vibration, accompanied by a question. The thread does not establish thermal performance or long-term suitability.
Conclusion
-KTO-’s first homelab gives a used mini PC a clear new role through ZimaOS, Immich and Nextcloud. Its two original photos also preserve the practical work around external drives, cabling and vibration. The useful next steps for a similar beginner are to understand where application data lives, stabilize the physical arrangement and verify a recovery copy before the server becomes a household dependency.
Zima Campaign Hub
A ZimaBoard 2 Prototype with Two 22 TB Drives on the Test Bench
Explore sabitech2k’s early ZimaBoard 2 drive test, the reported power conditions, and the existing ZimaBoard used for Proxmox backups.
A Quiet ZimaCube and ZimaBoard Homelab with Debian and Docker
A ZimaCube and ZimaBoard split everyday applications from smart-home services, with Debian, Docker, Pi-hole and a Homepage dashboard.
A LEGO Rack for a First ZimaBoard 2 Home Server
See how a first-time builder organized a ZimaBoard 2 and two SSDs in a LEGO rack, with Home Assistant and home-office storage planned next.
