A write-ahead log records index mutations durably before dependent state changes, allowing a crashed AI index to replay acknowledged work into a consistent structure.
A home indexer may acknowledge a new document after updating an in-memory graph, metadata map, or memtable whose durable segment has not been written yet. If power fails, source files still exist but freshness and deletion state can diverge. The WAL preserves an ordered mutation record for recovery, while periodic checkpoints limit how much log must be replayed.
Log-First Ordering Separates Durability From Main-Index Writes
Before an update is reported durable, the system appends enough information to redo or otherwise recover it and flushes the required log boundary. Main index pages or segments can be written later in larger, more efficient batches.
RocksDB writes each update to both a memtable and write-ahead log, using the log to restore memory-resident changes after process failure. This illustrates the core log-before-data ordering used beneath many index services. This distinction remains visible during later household testing.
A WAL is not merely a debug event stream. Its record format, ordering, checksums, transaction identifiers, and sync semantics are part of the index's recovery protocol. The intermediate result must remain inspectable before automation follows.
Replay Rebuilds the Gap After the Last Durable Checkpoint
On restart, the index loads the latest valid checkpoint or committed segment generation, scans subsequent log records, ignores incomplete tails, and reapplies mutations in order. Sequence numbers prevent old records from being applied to the wrong generation.
A database engineering explanation shows how WAL replay restores changes logged before a crash but not yet reflected in main structures. Recovery correctness depends on knowing which operations were acknowledged and which checkpoint already includes them.
AI-specific records may include source version, chunk IDs, vector payload or recomputation reference, metadata changes, tombstones, and model identity. Replaying an embedding generated under an unknown model can restore structure while corrupting semantic consistency. That boundary should be measured separately under realistic operating conditions.
Durability Settings Define What the Log Actually Promises
Appending to an operating-system buffer is weaker than forcing storage to stable media. Group commit amortizes sync cost across several updates, trading a bounded window of possible loss for higher ingest throughput. The practical consequence appears when several sources compete for limited context.
A practical WAL analysis emphasizes that every acknowledged write must cross a defined durability boundary. The statement is meaningful only when the filesystem, drive cache, and application agree on what a completed flush guarantees. This dependency should remain explicit in the final interface.
The failure boundary is disk corruption, lost source data, incompatible index code, or a log and checkpoint copied from different generations. A WAL is not a backup and cannot reconstruct state outside its retained mutation history.
Crash-Test the Acknowledgment and Replay Contract
Record mutation ID, source version, model version, log append, sync completion, acknowledgment, memory update, segment flush, checkpoint, and log truncation for each index operation. The result must therefore be checked against the original evidence.
Connect recovery to incremental index state. Inject termination before and after every boundary, truncate the final record, duplicate replay, restore an older checkpoint, and verify active vectors, tombstones, metadata, and source lineage. This distinction remains visible during later household testing.
Pass when every acknowledged mutation survives or has an explicitly documented loss window, incomplete operations do not appear committed, and repeated replay is safe. Keep independent backups for media loss and historical restore. The intermediate result must remain inspectable before automation follows.
