Content-defined chunking places backup boundaries from byte-pattern fingerprints, preserving matching chunks after insertions or deletions shift a file's later offsets.
A large home video project or disk image may change by only a few megabytes between NAS snapshots. Fixed-size blocks after an early insertion all move and appear different even when their contents remain unchanged. CDC scans the byte stream for boundary patterns, hashes the resulting chunks, and stores only unseen content, improving cross-version deduplication while adding computation and chunk metadata.
Rolling Content Signals Choose the Boundaries
A rolling hash or gear function updates as the chunker advances through bytes. A boundary is declared when selected fingerprint bits match a rule, subject to minimum and maximum sizes that prevent pathological tiny or oversized chunks.
FastCDC describes content-defined boundaries as a key technique for finding redundancy and improves the speed of byte-by-byte boundary selection. The boundary depends on local content rather than an absolute file offset. This distinction remains visible during later household testing.
Changing one region usually shifts boundaries only until another content pattern is found. Later unchanged regions can therefore recover their previous chunk hashes instead of being retransmitted wholesale. The intermediate result must remain inspectable before automation follows.
Deduplication Separates Chunk Identity From File Layout
The backup stores each unique chunk by a cryptographic fingerprint and records a manifest that reconstructs every file version from an ordered chunk list. Renames and duplicate copies can reuse stored payloads while retaining distinct paths and metadata.
The FastCDC design paper explains how deduplication efficiency balances redundancy detection with chunking speed. Average chunk size changes the deduplication, index-memory, metadata, and restore-read tradeoff. That boundary should be measured separately under realistic operating conditions.
CDC is not delta compression: it reuses identical chunks but does not encode the byte-level difference between two nonidentical chunks. Compression and delta coding may operate as separate layers. The practical consequence appears when several sources compete for limited context.
Backup Format and Encryption Can Limit Reuse
Small average chunks find more shared regions but create more fingerprints, manifests, lookups, and scattered restore reads. Large chunks reduce metadata and can restore sequentially, but a small change invalidates more stored bytes. This dependency should remain explicit in the final interface.
Research on backup chunk tradeoffs quantifies how chunk size and metadata affect duplicate elimination in backup streams. It shows why the highest deduplication ratio is not automatically the fastest or cheapest restore design. The result must therefore be checked against the original evidence.
The failure boundary is data transformed before chunking by random encryption, compression, or format-wide rewriting. Small logical edits then change most bytes, leaving CDC little stable content to recognize despite higher CPU cost. This distinction remains visible during later household testing.
Test Deduplication and Restore Together
Prepare a base file, renamed copy, inserted prefix, middle edit, recompressed archive, encrypted version, and realistic directory snapshot. Record unique bytes, chunk count, metadata, CPU, backup time, temporary space, and network transfer. The intermediate result must remain inspectable before automation follows.
Use rename-resistant chunking to verify rename stability. Restore full and partial datasets while measuring throughput, seek behavior, cache use, missing-chunk detection, and manifest verification. That boundary should be measured separately under realistic operating conditions.
Choose chunk parameters from total backup and restore cost, not deduplication ratio alone. If encryption destroys similarity, chunk before encryption with protected metadata or accept that cross-version reuse will fall. The practical consequence appears when several sources compete for limited context.
