What Is Snapshot Consistency, and Why Must Models and Indexes Share a Restore Point?
Snapshot consistency means every restored component represents a compatible logical moment, preventing a model, index, metadata store, and log from disagreeing after recovery.
A home RAG stack can snapshot model files at midnight, vector segments at 00:02, metadata at 00:05, and a write log still accepting changes throughout. Each copy may be individually readable yet collectively invalid: vectors can reference missing chunks or a newer embedding space. A shared restore point records coordinated versions and the replay boundary needed to reconstruct one coherent state.
Readable Copies Are Not Necessarily a Consistent System State
Crash-consistent snapshots approximate an abrupt power loss and rely on journals or recovery. Application-consistent snapshots first quiesce or checkpoint services so invariants across memory, logs, manifests, and data files are represented intentionally. This distinction remains visible during later household testing.
Distributed-checkpoint research defines recovery from a consistent global state recorded across participating processes. The same principle applies when local AI state spans several services even if they run on one server. The intermediate result must remain inspectable before automation follows.
Filesystem atomicity protects the selected volume at one instant, but it cannot coordinate an external object store, another NAS, or a model registry unless the application binds their generations explicitly. That boundary should be measured separately under realistic operating conditions.
Model and Index Provenance Form One Compatibility Set
A vector index depends on embedding model revision, tokenizer, preprocessing, dimension, normalization, chunking, source generation, and often a reranker configuration. Restoring weights without the matching index manifest can produce valid vectors that are semantically incomparable.
Classic rollback-recovery work explains how independent checkpoint inconsistency arise when independently captured components exchange state. Versioned provenance turns those hidden dependencies into a restore manifest that can be checked before service starts. The practical consequence appears when several sources compete for limited context.
Generative model weights may be independent of retrieval embeddings, but the serving stack still needs compatible templates, adapters, and routing. The manifest should distinguish hard compatibility requirements from components that can be safely regenerated. This dependency should remain explicit in the final interface.
A Restore Point Includes Logs and In-Flight Operations
Coordinated recovery either pauses writes, establishes a barrier, or records sequence numbers so post-snapshot mutations replay exactly once. Temporary segment files and incomplete model downloads must remain outside the committed manifest. The result must therefore be checked against the original evidence.
An overview of checkpointed runtime state shows how saved state supports recovery and migration while emphasizing the need to capture the relevant runtime boundary. For AI stacks, the durable unit is broader than one process image.
The failure boundary is a snapshot set without a verifiable manifest or replay position. Matching timestamps are insufficient when clocks drift or asynchronous writes complete out of order; recovery must reject ambiguous combinations rather than start with silent semantic corruption.
Restore the Manifest, Not a Folder Collection
Record snapshot ID, component generation, content hash, schema, model and tokenizer revision, index manifest, metadata sequence, WAL position, source catalog, encryption key version, and dependency edges. This distinction remains visible during later household testing.
Test the coordinated design described in coordinated checkpoints. Restore into an isolated server, replay only records after the barrier, run compatibility checks, and compare retrieval, citations, deletions, and model routing with the pre-snapshot baseline. The intermediate result must remain inspectable before automation follows.
Promote the restore only when every dependency resolves and repeat restoration yields the same logical state. If one mandatory component is missing, rebuild the dependent index or select an earlier complete restore point. That boundary should be measured separately under realistic operating conditions.
