Plex performance can change when another container starts because both services begin competing for the same CPU, memory, storage, or network headroom.
Container boundaries isolate processes and packaging, not the physical resources underneath them. A downloader can saturate storage, a backup can fill page cache, and an AI job can consume CPU or GPU time while Plex is still “healthy.” Diagnose the shared host before tuning Plex in isolation.
CPU Contention Can Change Transcode Latency
A second container can increase run-queue pressure even if Plex CPU percentage looks similar at a glance. Software transcoding, subtitles, and background analysis are sensitive to the latency of getting CPU time when they need it.
A host-wide utilization and saturation check distinguishes a busy CPU from one with a persistent runnable queue.
Start the competing container during a repeatable Plex workload and record CPU saturation and playback stability. If latency follows the second workload, allocate or schedule CPU before changing Plex quality settings.
Memory Pressure Can Change Cache Behavior
A newly started service can consume memory that previously held Plex database or filesystem cache. The server may then perform more storage reads even though Plex itself did not change.
Warm data can become cold when another workload needs memory because of normal page-cache behavior.
Compare memory pressure, major faults, and app-data latency before and after the second container starts. If the effect disappears after the workload ends and cache warms again, treat it as shared-memory pressure.
Storage Contention Can Hide Behind Low CPU
Downloaders, databases, and backup jobs can create queues on the same SSD or HDD used by Plex state. The symptom may look like slow navigation or delayed scans rather than a storage error.
Shared I/O becomes a normal design concern when a multi-service media stack places several writers around the same media workflow.
Pause the competing writer while repeating the same Plex task. If storage latency collapses, separate the state path or reschedule the write-heavy job. A separate persistent app-data layout makes shared-storage contention easier to measure because Plex state is not mixed with every other container write.
GPU Sharing Needs Its Own Test
When Plex and another container share a GPU, hardware queues and device memory become another contested resource. The fact that both containers can open the device does not prove they can meet their peak latency at the same time.
The exact acceleration path matters more than a generic GPU label because Plex hardware-transcoding behavior can vary across Ryzen generations.
Run the hardest Plex transcode while the second GPU workload is active, then compare to a Plex-only baseline. Keep a fallback path documented before committing both services to the same accelerator.
