Private RAG citations often open slowly over a home VPN because each source view adds network round trips, connection setup, and server-side rendering work.
A local answer may appear quickly because generation runs beside the index, yet clicking its PDF citation sends a browser through an encrypted remote path to the NAS. DNS, tunnel routing, TLS, authentication, range requests, and preview generation can occur before the relevant page appears. Latency matters more than headline bandwidth when the viewer needs several dependent exchanges.
Citation Opening Is a Chain of Dependent Round Trips
The citation click is rarely one transfer. The browser resolves a name, reaches the VPN route, negotiates or reuses transport security, authenticates to the document service, requests metadata, and then fetches the source bytes or page range needed by the viewer.
A browser performance model shows why dependent network round trips multiply round-trip delay even when payloads are small. A high-throughput home uplink cannot remove waiting time between a request and the response required to issue the next request.
RAG generation may avoid that path because the model and vector index communicate locally. The visible mismatch therefore does not mean retrieval was fast over the VPN; it means the citation viewer begins a separate remote transaction after the answer is already available.
Tunnel Routing and MTU Can Delay Individual Source Chunks
A VPN adds encryption, encapsulation, and routing decisions. If traffic takes a relay or full-tunnel path instead of a direct route, every request travels farther; if the encapsulated packet exceeds the usable path MTU, loss and retransmission can delay the exact byte range the viewer needs.
An engineering analysis of path-MTU discovery shows how oversized packets can disappear when path-MTU discovery fails, producing stalls that look disproportionate to average bandwidth. VPN headers reduce the payload available inside the same outer packet, making a previously safe size cross the boundary.
PDF viewers frequently request headers, cross-reference tables, fonts, thumbnails, and page ranges independently. One lost response can block rendering even while a bulk speed test looks healthy, so bytes per second and citation-open time measure different parts of the path.
Source Rendering Can Dominate After the Tunnel Is Healthy
The home service may need to wake a disk, check permissions, decompress a file, run OCR layout lookup, or render a page preview. Those operations occur after the VPN request arrives and can dominate latency for a cold document while a recently opened citation feels immediate.
An authenticated tunnel design emphasizes a small authenticated tunnel interface and modern cryptographic construction, but it cannot eliminate application work behind the endpoint. Encryption overhead, network delay, storage delay, and preview delay remain separable layers in the observed click time.
The failure boundary is blaming the VPN whenever citations are slow. If the same source opens slowly on the home LAN, or server tracing shows most time before the first response byte, storage and rendering are the limiting stages rather than the remote encrypted path.
Build a Citation-Open Waterfall Across Both Paths
Choose cached and uncached citations from small HTML files, large PDFs, OCR scans, and sleeping disks. Record click time, DNS, connection reuse, authentication, time to first byte, range-request count, bytes transferred, server render time, and time until the cited passage is visible.
Repeat each source on the LAN and through the VPN using network-latency effects as a comparison model. Test direct and relayed paths, two MTU values, and warm versus cold previews without changing several variables in one run.
Treat the VPN as responsible only when the remote-minus-LAN delta appears in network phases. If server rendering dominates both paths, cache safe previews or improve source serving; if many round trips dominate, reduce dependent requests before buying more bandwidth.
