Constrained decoding produces schema-valid JSON by masking every next token that would leave the partial output outside the schemaโs accepted language.
A local agent may need an object containing a permitted tool name, required arguments, enums, arrays, and numeric fields. Prompting asks the model to imitate that shape, while constrained decoding inserts a grammar engine into sampling. The engine tracks the current parser state and allows only token continuations that can still complete a valid instance.
The Schema Becomes an Executable Output Grammar
A compiler translates supported JSON Schema constructs into grammar or automaton states representing legal keys, types, delimiters, enums, nesting, and required fields. Compilation can be cached for repeated tool schemas. This distinction remains visible during later household testing.
A broad benchmark of schema-constrained generation separates schema compliance, coverage, efficiency, and generated content quality. That separation matters because an engine can enforce simple schemas while rejecting or weakening advanced features. The intermediate result must remain inspectable before automation follows.
Schema support is not all-or-nothing. Conditional branches, recursion, numeric constraints, or unrestricted objects may exceed a backendโs supported subset and require validation after generation. That boundary should be measured separately under realistic operating conditions.
Parser State Masks Illegal Tokens Before Sampling
At each step, the grammar engine determines which character sequences can legally follow the current prefix, maps that set to tokenizer tokens, and sets invalid token logits to an impossible value. Sampling then chooses only among legal continuations.
A mechanical explanation of next-token grammar masking details token masking, grammar state, and structured formats including JSON. Enforcement occurs inside generation, so an invalid quote, key, delimiter, or enum cannot be sampled merely because the model assigned it high probability.
Tokenizer tokens can contain multiple characters or partial delimiters, making the token-to-grammar mapping performance-sensitive. Efficient engines cache transitions and avoid reparsing the whole prefix at every step. The practical consequence appears when several sources compete for limited context.
Structural Validity Leaves Semantic Errors Untouched
A valid schema can still contain the wrong device ID, unsafe amount, fabricated path, or logically incompatible field combination. Output truncation can also interrupt a structure if the serving layer stops before the grammar reaches an accepting state.
A production analysis of schema compilation limits explains conversion from schema to grammar and notes that supported features vary between engines. It distinguishes mechanically valid output from application-level truth and policy. This dependency should remain explicit in the final interface.
The failure boundary is treating parse success as action authorization. Deterministic validators, current-state lookup, permission checks, and human approval remain necessary when valid fields can still cause harmful side effects. The result must therefore be checked against the original evidence.
Test Syntax, Schema, Semantics, and Latency Separately
Create flat, nested, optional, enum, Unicode, escaped-text, array, recursive, and unsupported-keyword schemas. Run ordinary prompting and constrained decoding across the intended models, quantizations, temperatures, context lengths, and concurrent load. This distinction remains visible during later household testing.
Relate the results to structured tool output. Measure JSON parse rate, schema compliance, truncation, semantic validity, unsafe target selection, compilation time, time per token, repair attempts, and unsupported-schema failures. The intermediate result must remain inspectable before automation follows.
Deploy only the schema subset verified by the runtime. Reject or escalate semantically invalid objects after parsing, and treat any nonzero structural failure as evidence of bypass, truncation, or unsupported constraints rather than ordinary model creativity.
